    Manhattan sketchup model
    60 Posts 21 Posters 27.4k Views 21 Watching
    • B
      bubbalove
      If you are able to get it to work... would you mind posting the purged file?
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • C
        chango70
        It is behaving strangely! None of the buildings caste shadow except for the bridges and some of them have the trianglated geometry that reminds of 3ds import... I'll try and see if I can clean it up.
        • GaieusG
          I couldn't even open the file (3.8 GHz processor, 2 Gigs of RAM) 😲
          • C
            chango70
            Oh wow. This can't be a native sketchup model!? It has 2 surfaces for everything!! and missing surfaces for large part of the gound...
            • N
              nightzombie
              i think the person who made the model
              converted it from some other application.
              i had no idea it was double faced 😆
              it usually takes my laptop about 5 minutes of freezing sketchup to load
                Simon B
                Could an Okino converter or something similar strip out the double faces?
                • K
                  kwistenbiebel
                  Looks like it is done in Rhino (or another solid modeler) as often geometry is imported double (disconnected edges).
                  Probably the author forget to convert his model to a mesh and weld the edges....
                  • brodieB
                    brodie
                    Quite disappointing. I was sort of excited when I saw the original image. Anyone have a similar city model they'd like to share? I looked a bit on the warehouse but didn't run across anything very appealing.
                    -Brodie
                      Simon B
                      I wonder if somone in the sketchup team has access to one? I am working on a game project and wanted to use a model like Manhattan to compare relative sizes of very large objects. Hope it's not too much of a big ask if anyone is listening.
                      If not, I will have a bash at tidying this model - but don't hold your breath...
                      • B
                        bubbalove
                        I would be willing to clean the model but I can't get the damn thing to open... if someone can just clean it to where I can open it without sketchup crashing... i'll finish the rest!
                          Simon B
                          I found this resource in the meantime:
                          Not Found
                          (www.3dcadbrowser.com)
                          And this utility may help to remove double-faces (haven't tested):
                          http://www.deep-shadows.com/hax/3DRipperDX.htm (3d Studio Max and Maya only)
                          • B
                            bordominc
                            I noticed the double faces were on separate layers then the one below it. I deleted all of the "poly surface" (I think thats what they were called, I don't want to open the original again to find out) layers, now the model is much easier to use.
                            http://www.mediafire.com/file/2gjmkd0yanh/manhatten_v5_.skp
                              remus
                              cheers bordominic, its pretty usable now 👍
                              • B
                                bubbalove
                                Thank you Bordominc!
                                • brodieB
                                  brodie
                                  Great job! It's working great now.
                                  BTW, there's still some purging that can be done and the option for shadows to be displayed "On Faces" is turned off.
                                  Great model
                                  -Brodie
                                  • B
                                    bubbalove
                                    There are a bunch of extra lines and missing faces but it is fun to play around with!
                                    • soloS
                                      Don't try this with Sketchup, your machine will explode.
                                      I converted the .skp to .3ds, imported into Vue, added displacement to every building and then added 2500 trees to Central park, rendered in 6m 35s, using a basic spectral atmosphere.
                                      http://img90.imageshack.us/img90/2725/nyc1va0.jpg
                                      • david_hD
                                        david_h
                                        Once again Pete. . .you just fail to impress. . . ho-hum
                                        (jus kiddin'! 💚 😆 )
                                        • soloS
                                          Thanks mate.
                                          America 2019, we never saw the Somalian pirates coming.
                                          http://img301.imageshack.us/img301/7600/nyc11ed7db3.jpg
                                          • K
                                            kwistenbiebel
                                            He he, Great!
                                            Just wonderful. 👍
                                            • 2 / 3
