    Manhattan sketchup model
    60 Posts 21 Posters 26.9k Views 21 Watching
    • C
      chango70
      It is behaving strangely! None of the buildings caste shadow except for the bridges and some of them have the trianglated geometry that reminds of 3ds import... I'll try and see if I can clean it up.
      • GaieusG
        I couldn't even open the file (3.8 GHz processor, 2 Gigs of RAM) 😲
        • C
          chango70
          Oh wow. This can't be a native sketchup model!? It has 2 surfaces for everything!! and missing surfaces for large part of the gound...
          • N
            nightzombie
            i think the person who made the model
            converted it from some other application.
            i had no idea it was double faced 😆
            it usually takes my laptop about 5 minutes of freezing sketchup to load
              Simon B
              Could an Okino converter or something similar strip out the double faces?
              • K
                kwistenbiebel
                Looks like it is done in Rhino (or another solid modeler) as often geometry is imported double (disconnected edges).
                Probably the author forget to convert his model to a mesh and weld the edges....
                • brodieB
                  brodie
                  Quite disappointing. I was sort of excited when I saw the original image. Anyone have a similar city model they'd like to share? I looked a bit on the warehouse but didn't run across anything very appealing.
                  -Brodie
                    Simon B
                    I wonder if somone in the sketchup team has access to one? I am working on a game project and wanted to use a model like Manhattan to compare relative sizes of very large objects. Hope it's not too much of a big ask if anyone is listening.
                    If not, I will have a bash at tidying this model - but don't hold your breath...
                    • B
                      bubbalove
                      I would be willing to clean the model but I can't get the damn thing to open... if someone can just clean it to where I can open it without sketchup crashing... i'll finish the rest!
                      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                        Simon B
                        I found this resource in the meantime:
                        Not Found
                        (www.3dcadbrowser.com)
                        And this utility may help to remove double-faces (haven't tested):
                        http://www.deep-shadows.com/hax/3DRipperDX.htm (3d Studio Max and Maya only)
                        • B
                          bordominc
                          I noticed the double faces were on separate layers then the one below it. I deleted all of the "poly surface" (I think thats what they were called, I don't want to open the original again to find out) layers, now the model is much easier to use.
                          http://www.mediafire.com/file/2gjmkd0yanh/manhatten_v5_.skp
                            remus
                            cheers bordominic, its pretty usable now 👍
                            • B
                              bubbalove
                              Thank you Bordominc!
                              • brodieB
                                brodie
                                Great job! It's working great now.
                                BTW, there's still some purging that can be done and the option for shadows to be displayed "On Faces" is turned off.
                                Great model
                                -Brodie
                                • B
                                  bubbalove
                                  There are a bunch of extra lines and missing faces but it is fun to play around with!
                                  • soloS
                                    Don't try this with Sketchup, your machine will explode.
                                    I converted the .skp to .3ds, imported into Vue, added displacement to every building and then added 2500 trees to Central park, rendered in 6m 35s, using a basic spectral atmosphere.
                                    http://img90.imageshack.us/img90/2725/nyc1va0.jpg
                                    • david_hD
                                      david_h
                                      Once again Pete. . .you just fail to impress. . . ho-hum
                                      (jus kiddin'! 💚 😆 )
                                      • soloS
                                        Thanks mate.
                                        America 2019, we never saw the Somalian pirates coming.
                                        http://img301.imageshack.us/img301/7600/nyc11ed7db3.jpg
                                        • K
                                          kwistenbiebel
                                          He he, Great!
                                          Just wonderful. 👍
                                          • GaieusG
                                            Pete, that's sick. You are a pervert. 😄
                                            (I like it though)
                                            • 2 / 3
