    Augmented Reality Plug-in for Google Sketch-Up released
    extensions
    112 Posts 37 Posters 71.4k Views 37 Watching
      jcostaribeiro
      Dear Graziano,
      I was testing the plugin with a very simple model (a 2x2x2 meter cube).
      So this is not an issue.
      My Sketchup version in 6.0.515 on a Windows XP.
      Best regards,
      João
      • Graziano TerenziG Offline
        Graziano Terenzi
        Dear João,
        to our knowledge there is nothing wrong with the plugin as well as with the version of SketchUp you have been using. Therefore there must be something in your computer settings that makes the plugin work this way.
        Something like that could also take place sometimes when you are using an account which does not grant you the right privileges on your OS. Are you accessing SketchUp as an administrator? If not, try it out.
        Best regards
        Graziano
        Graziano Terenzi
        CEO @ Inglobe Technologies
        • MALAISEM Offline
          MALAISE
          Hi Graziano and Inglobe Team
          A short question : I bought a brand new computer last week. Could you tell us how to transfer the licence to that new computer ?
          Thanks for that incredible program.
          Regards
          MALAISE
            Graziano Terenzi
            Regards
            MALAISE
            Dear MALAISE,
            there are two possibilities to transfer a license from a machine to another:
            1: by uninstalling a registerd version of the plugin: by doing so, after the unistallation process, you'll be automatically provided with a "Release ID" that will be copied into the clipboard. Then you need to paste that ID in the online license manager in order to have your license available again for another installation
            OR
            1. by simply running your local license manager on the machine with the registered version, and:
              a) clicking the "Release a License" button
              b) confirming your intention to release the license (by clicking on "yes")
              c) copying to the clipboard the generated "Release ID"
              d) pasting the "Release ID" on our online license manager in order to have your license available again for a new activation
            If you need further assistance do not hesitate to write. Regards.
            Graziano
            Graziano Terenzi
              tpjonckh
              I noticed an update today?
              Can you tell us what was implemented...
                Graziano Terenzi
                Dear tpjonckh,
                the new update only contains a minor improvement of the licensing interface.
                Thank you
                Graziano
                Graziano Terenzi
                  Graziano Terenzi
                  Dear all,
                  today we have uploaded an update of the ARplugin (29th January, 2009) and of the documentation which includes an upgrade that will surely be of some interest to many of you.
                  The upgrade consists in a functionality which improves objects stability in bad circumstances.
                  As some of you might have noted, in some circumstances you may see your model a bit trilling. This can be due to different reasons, just like the distance between the camera and the marker and a bad adjustment of camera parameters (brightness, contrast etc.), just to mention some.
                  With this upgrade now you can reduce this undesired effect simply by pressing the key "a".
                  You can download both the updated version and documentation from the usual webpage
                  404 Not Found
                  (www.inglobetechnologies.com)
                  For those who bought a license we have prepared a patch that will be available very soon on the same page. By using the patch you won't need to repeat the license activation procedure. So, keep checking our website for updates.
                  Regards
                  Graziano
                  Graziano Terenzi
                    Siebe
                    This is soooo cool! I got it working, using my own Sketchup model. Great stuff.
                    However, the plugin crashes after, say 20 seconds. Anywhere I can report this to the developers?
                    I'm running Windows XP on a MacBook Pro, using the built-in webcam.
                    Does anyone know how to record this, besides running a screen-capturing program?
                    Cheers,
                    Siebe
                    • Chris FullmerC Offline
                      Crashes after 20 seconds or just stops? It is set to run for a short time then turn off. That way you can see what it does and it should entice you to buy the plugin if you want the full functionality (and it won't stop after 20-30 seconds).
                        princedragoncok
                        With regards to animation, we can also think to animate the model. ARmedia allows animation, but it must implemented in association to Sketchup.
                        So is it possible to create a sketchup animation in augmented reality? I am specificlly interested in object animation using morisdov's 'proper animation' plugin. i.e. I would like to make a block move from point A to point B in augmented reality. Is this possible with the current release?
                        I want to create something like this: http://www.youtube.com/watch?v=KtpZLOrijW8&feature=PlayList&p=6D5B6278B032272E&playnext=1&index=1
                        • MALAISEM Offline
                          MALAISE
                          Hi Princedragoncok, Hi Inglobe Team
                             I like very much the way we see the building made stage by stage. I agree you, hopefully we'll soon have this motion implementation in ARplugin . Fantastic Youtube sequence!
                          MALAISE
                            Graziano Terenzi
                            This is a very interesting topic, as we have been implementing animations in our development framework from the beginning. However the extension of animation from our framework to SketchUp is not straigthforward. We plan to extend these animation capabilities to a future release of the ARPlugin, maybe sooner than later.
                            In the meanwhile, we have got our ARplugin to work on MAC OS X. Now, I can anticipate a beta release in the near future.
                            Regards
                            Graziano
                            Graziano Terenzi
                            • BurkhardB Offline
                              Burkhard
                              Great news, let me know if you need some help on this. I'm on Mac 1.5
                              Does the Win license work also on Mac? Or do we need a second one?
                              [http://www.ia-plus.de(http://www.ia-plus.de)]
                              • EddyNLE Offline
                                EddyNL
                                My first try:
                                [flash=425,355:3uwjs6z8]http://www.youtube.com/v/OtvALXXgcTA&hl=nl&fs=1[/flash:3uwjs6z8]
                                I work in this hotel, it's 600 years old.
                                Located in Bergen op Zoom, the Netherlands.
                                viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                  Graziano Terenzi
                                  Nice Job, EduardoNL!
                                  I have seen your models of Bergen op Zoom from another thread about Google Earth models and I have been impressed.
                                  Have you seen ARsights(http://www.arsights.com)? What do you think about it?
                                  Graziano Terenzi
                                    rolcor
                                    I just downloaded the BETA version for Mac OS and I realize that the possibilities are almost endless. I did have a slight bug to report. When using a secondary monitor, after the 30 second trial is over, the plug in crashes. When I use the laptop without the extended monitor, the plug in does not crash after the 30 second trial.
                                    Please release this BETA version soon. I just bought a license but I realize I can only download the Windows OS version. How much longer before the Mac version is released?
                                      Graziano Terenzi
                                      Dear rolcor,
                                      thank you very much for your feedback.
                                      To my knowledge this bug should have been resolved by the latest version of the ARplugin for MAC.
                                      With reference to the Full version release, I can anticipate that it will occurr probably this week. In the meanwhile you can activate your license for Windows XP or Vista (if you have also a Windows PC) and then shift to MAC, as it is always possible to move a license from Windows to MAC, and conversely from MAC to Windows.
                                      Best Regards
                                      Graziano
                                      Graziano Terenzi
                                        Graziano Terenzi
                                        Hi all,
                                        good news for MAC users.
                                        Take a look to this video
                                        [flash=425,344:3mev2woi]http://www.youtube.com/v/5We2cGyyVeA&hl=en&fs=1[/flash:3mev2woi]
                                        ARmedia Plugin is now available also for MAC OSX 10.5
                                        Some new features have been implemented such as the toggle full-screen mode and better real-time rendering optimization.
                                        You can download the free trial from the usual link
                                        http://www.inglobetechnologies.com/en/products/arplugin_su/info.php
                                        Regards
                                        Graziano
                                        Graziano Terenzi
                                          Gjenio
                                          This plugin looks very interesting. But has anyone tried how it works with large scale projects such as houses, museums, ecc..?
                                          Would make me crazy the idea to insert a big project into its natural context and navigate it.
                                          Is it possible with this plugin?
                                            d12dozr
                                            I have been playing with this plugin for Windows...I can't get over how cool it is, so I made a little video with some of my work and models from the 3D warehouse.
                                            The video is here: http://www.youtube.com/watch?v=q-ApS9tsl2U
                                            http://goo.gl/f7ooYh
                                            • 5 / 6
