    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 56.6k Views 61 Watching
    • W
      Whaat
      Wow! Another brilliant plugin, Fredo6!
      • fredo6F
        @daniel s said:
        I tried with the new version of LibFredo6 but have no luck... still can`t use the dimension dialog box.
        But i find something strange in my Plugins directory: there is a new folder called "DEFPARAM_Dir" and is empty. I delete this folder, but every time that I open a new SketchUp it creates the folder again.
        I never had this folder before.
        Daniel S
        Daniel,
        I think I know what it could be. I guess you have a set up where you should use the comma as the decimal separator.
        I made a change in LibFredo6. Maybe it will clear the issue.
        Thanks for your patience.
        PS: DEFPARAM_Dir is just the place where my scripts (today only FreeScale) stores the default parameter. It is a separate folder so that the parameters are not lost when upgrading.
        • fredo6F
          Dale,
          You can be sure that I appreciate the compliment, coming from you.
            Daniel S
            Now works!!!... but not well!! 😆
            I don`t know how to explain it in english but i attach a video showing that it dosen´t scale well (i put 30 and the result is 76,200cm). But now works!!
            Thank you for looking into this,
            Daniel S.
            PS. It must be only my problem because I remeber in the past I had problems with TIG`s slicer... was working for everyone but not for me and then he fixes the problem and said that was a problem about the comma.
            Video Showing the problem
            • fredo6F
              Daniel S.
              Daniel,
              My fault in the update.
              Can you make a last try for today with the update I made in LibFredo6.
              Thanks again for your patience.
                Daniel S
                Now is working right!
                Amazing Plugin!!
                Thank you Fredo!!!
                Daniel S
                • T
                  topherthomas2
                  I'm having some issues with the taper scale working on my machine. FreeScale works fine, and TaperScale does not redraw the polygons after I use the TaperScale tool. I can see the polygon shape distort in wireframe preview mode. Any Ideas?
                    sabba
                    I use a mac too and don't have any luck with the taper tool. ...same problem as the others.
                    • fredo6F
                      Can you confirm that you have the problem even on a simple cube (drawn from a Rectangle and Push Pull)?
                      If so, is it correct that:
                      • the Box with the small pad is OK
                      • when you drag the handle, the wireframe appears correct
                      • But when you click or release to finalize, you get NO deformation
                      Just in case, could you drop the attached file in te LIBFREDO6_Dir_30 folder, restart Sketchup, turn on the Ruby console and try again.
                      to drop in LIBFREDO6_Dir_30 folder
                      • O
                        otb designworks
                        Thanks fredo!
                        After installing the updated script, taper scale works beautifully.
                        I feel like I owe you a bottle of scotch, or something.
                        Awesome script!
                        Cheers, Chuck
                        OTB Designworks is on Youtube
                        • L
                          linea
                          thanks, great script
                          • fredo6F
                            Thanks fredo!
                            Awesome script!
                            Very strange. The change I made is purely in the syntax. I wonder why there was a problem on Mac. But, what matters is that it works.
                            Let's wait for confirmation from other Mac users before opening the bottle !
                            • fredo6F
                              To Mac Users
                              By the way, I am interested to know how the dialog boxes for Default Parametersbehave on Mac. Does it even work?
                              Same for the Translation web dialog box.
                              • urgenU
                                urgen
                                ...THANKS! 👍 👍 👍
                                --pupil forever...------
                                • bigstickB
                                  bigstick
                                  Wow - awesome work Fredo! If there is a list of essential Ruby scripts somewhere, this really needs to be on it!
                                  • CadFatherC
                                    CadFather
                                    Master Fredo for president!
                                    • I
                                      ilay7k
                                      thank you! 👍
                                      • gillesG
                                        gilles
                                        thanks Fredo
                                        I'm a mac user (os 10.4.11) free scaling works well for the moment even when you specify new dimension(pop-up window), but when tapering SU quite immediatly.
                                        To be continue.
                                        • arquitectomaracuchoA
                                          arquitectomaracucho
                                          Thanks fredo!
                                          This tool has changed my life, what is needed, it works great. IS a spectacle. This humble YOU ALL YOU MUST RESPECT. 👍
                                          • O
                                            otb designworks
                                            maybe I am confused, but I never get a pop up window of any kind.
                                            I can, however, customize the dimensions just as I would with the SU scale.
                                            Is there a command to bring up the dialogue pop-up?
                                            What a kick ass script!
                                            Cheers, Chuck
                                            • 3 / 7
