    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 56.6k Views 61 Watching
    • T
      TeKnoel
      this looks great! thanks for your hard work
      • EarthMoverE
        EarthMover
        Holy Sh!t! Just what I was thinking of asking for the other day. I love the taper. Reminds me of the Falloff function in Modo. Thanks Fredo!
        Content Creator at Skapeup
        • G
          gaganraj
          phenomenal tool. works perfectly on my windows machine. same issue as kannonbal on my mac.
          i'm amazed at how intuitive and simple such a great tool can me made. I absolutely love the little green check mark!! such a great idea. This will make SDS proxies so much easier! thanks!
          • fredo6F
            To Daniel S(on problem of dimension dialog box)
            I don't understand what is happening.
            Can you then try the 3 commands below, one by one
            Traductor.string_to_length "20"
            "20".to_l
            Traductor.string_to_float_formula "20"
            Apparently other users have not reported the problem (yet). So it may be something specific to your environment.
            • fredo6F
              To Chuck (Kannonbal) on issues with Taper Scale
              I made an update to LibFredo6 in relation with the issues you signaled.
              Could you download and install again LibFredo6 and advise if you still have the problem
              • fredo6F
                Did anybody see my jaw? I lost it somewhere...
                Fredo, the Taper function looks killer! If it does the job on Nested Components and Groups as well, then people don't have to explode the geometry anymore to perform a Free Form Deformation on it.
                The only thing I didn't understand about the YouTube video was when you scaled that ship. What were you demonstrating there?
                Coen,
                Thanks for your encouragements.
                Taper Scale should work on nested components and groups, but it has to make all components unique and explode all curves. So it's a little bit destructive. No mystery, Tapering is not a transformation that can preserve the unicity of a single definition for components (same rule as for Sketchy FFD).
                For my ship, the purpose was just to show that Free Scale can handle large models full of components and groups, because it is actually just based on regular Scaling. Free Scale is not destructive at all, in contrast with TaperScale. Otherwise nothing special.
                  Daniel S
                  Fredo: This is the ruby console result when I enter the commands:
                  nil
                  "20".to_l
                  7.8740157480315
                  20.0
                  I attach a screenshot too.
                  Daniel S
                  • fredo6F
                    Daniel,
                    I still don't see what it could be, and why you have it specifically in your environment.
                    Just in case, I made a slight change in LibFredo6. So you have to re-install it again and check if it improves. Can you try?
                      Daniel S
                      I tried with the new version of LibFredo6 but have no luck... still can`t use the dimension dialog box.
                      But i find something strange in my Plugins directory: there is a new folder called "DEFPARAM_Dir" and is empty. I delete this folder, but every time that I open a new SketchUp it creates the folder again.
                      I never had this folder before.
                      Daniel S
                      • W
                        Whaat
                        Wow! Another brilliant plugin, Fredo6!
                        • fredo6F
                          Daniel S
                          Daniel,
                          I think I know what it could be. I guess you have a set up where you should use the comma as the decimal separator.
                          I made a change in LibFredo6. Maybe it will clear the issue.
                          Thanks for your patience.
                          PS: DEFPARAM_Dir is just the place where my scripts (today only FreeScale) stores the default parameter. It is a separate folder so that the parameters are not lost when upgrading.
                          • fredo6F
                            Dale,
                            You can be sure that I appreciate the compliment, coming from you.
                              Daniel S
                              Now works!!!... but not well!! 😆
                              I don`t know how to explain it in english but i attach a video showing that it dosen´t scale well (i put 30 and the result is 76,200cm). But now works!!
                              Thank you for looking into this,
                              Daniel S.
                              PS. It must be only my problem because I remeber in the past I had problems with TIG`s slicer... was working for everyone but not for me and then he fixes the problem and said that was a problem about the comma.
                              Video Showing the problem
                              • fredo6F
                                Daniel S.
                                Daniel,
                                My fault in the update.
                                Can you make a last try for today with the update I made in LibFredo6.
                                Thanks again for your patience.
                                  Daniel S
                                  Now is working right!
                                  Amazing Plugin!!
                                  Thank you Fredo!!!
                                  Daniel S
                                  • T
                                    topherthomas2
                                    I'm having some issues with the taper scale working on my machine. FreeScale works fine, and TaperScale does not redraw the polygons after I use the TaperScale tool. I can see the polygon shape distort in wireframe preview mode. Any Ideas?
                                      sabba
                                      I use a mac too and don't have any luck with the taper tool. ...same problem as the others.
                                      • fredo6F
                                        Can you confirm that you have the problem even on a simple cube (drawn from a Rectangle and Push Pull)?
                                        If so, is it correct that:
                                        • the Box with the small pad is OK
                                        • when you drag the handle, the wireframe appears correct
                                        • But when you click or release to finalize, you get NO deformation
                                        Just in case, could you drop the attached file in te LIBFREDO6_Dir_30 folder, restart Sketchup, turn on the Ruby console and try again.
                                        to drop in LIBFREDO6_Dir_30 folder
                                        • O
                                          otb designworks
                                          Thanks fredo!
                                          After installing the updated script, taper scale works beautifully.
                                          I feel like I owe you a bottle of scotch, or something.
                                          Awesome script!
                                          Cheers, Chuck
                                          OTB Designworks is on Youtube
                                          • L
                                            linea
                                            thanks, great script
                                            • 2 / 7
