    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 56.6k Views 61 Watching
      Daniel S
      Now works!!!... but not well!! 😆
      I don`t know how to explain it in english but i attach a video showing that it dosen´t scale well (i put 30 and the result is 76,200cm). But now works!!
      Thank you for looking into this,
      Daniel S.
      PS. It must be only my problem because I remeber in the past I had problems with TIG`s slicer... was working for everyone but not for me and then he fixes the problem and said that was a problem about the comma.
      Video Showing the problem
      • fredo6F
        Daniel S.
        Daniel,
        My fault in the update.
        Can you make a last try for today with the update I made in LibFredo6.
        Thanks again for your patience.
          Daniel S
          Now is working right!
          Amazing Plugin!!
          Thank you Fredo!!!
          Daniel S
          • T
            topherthomas2
            I'm having some issues with the taper scale working on my machine. FreeScale works fine, and TaperScale does not redraw the polygons after I use the TaperScale tool. I can see the polygon shape distort in wireframe preview mode. Any Ideas?
              sabba
              I use a mac too and don't have any luck with the taper tool. ...same problem as the others.
              • fredo6F
                Can you confirm that you have the problem even on a simple cube (drawn from a Rectangle and Push Pull)?
                If so, is it correct that:
                • the Box with the small pad is OK
                • when you drag the handle, the wireframe appears correct
                • But when you click or release to finalize, you get NO deformation
                Just in case, could you drop the attached file in te LIBFREDO6_Dir_30 folder, restart Sketchup, turn on the Ruby console and try again.
                to drop in LIBFREDO6_Dir_30 folder
                • O
                  otb designworks
                  Thanks fredo!
                  After installing the updated script, taper scale works beautifully.
                  I feel like I owe you a bottle of scotch, or something.
                  Awesome script!
                  Cheers, Chuck
                  OTB Designworks is on Youtube
                  • L
                    linea
                    thanks, great script
                    • fredo6F
                      Thanks fredo!
                      Awesome script!
                      Very strange. The change I made is purely in the syntax. I wonder why there was a problem on Mac. But, what matters is that it works.
                      Let's wait for confirmation from other Mac users before opening the bottle !
                      • fredo6F
                        To Mac Users
                        By the way, I am interested to know how the dialog boxes for Default Parametersbehave on Mac. Does it even work?
                        Same for the Translation web dialog box.
                        • urgenU
                          urgen
                          ...THANKS! 👍 👍 👍
                          --pupil forever...------
                          • bigstickB
                            bigstick
                            Wow - awesome work Fredo! If there is a list of essential Ruby scripts somewhere, this really needs to be on it!
                            • CadFatherC
                              CadFather
                              Master Fredo for president!
                              • I
                                ilay7k
                                thank you! 👍
                                • gillesG
                                  gilles
                                  thanks Fredo
                                  I'm a mac user (os 10.4.11) free scaling works well for the moment even when you specify new dimension(pop-up window), but when tapering SU quite immediatly.
                                  To be continue.
                                  • arquitectomaracuchoA
                                    arquitectomaracucho
                                    Thanks fredo!
                                    This tool has changed my life, what is needed, it works great. IS a spectacle. This humble YOU ALL YOU MUST RESPECT. 👍
                                    • O
                                      otb designworks
                                      maybe I am confused, but I never get a pop up window of any kind.
                                      I can, however, customize the dimensions just as I would with the SU scale.
                                      Is there a command to bring up the dialogue pop-up?
                                      What a kick ass script!
                                      Cheers, Chuck
                                      • B
                                        BUDLA
                                        It not showing in windows menu and not working?
                                        BUDLA
                                        • fredo6F
                                          Fredo,
                                          I just now tried your script, but can't get it to work.
                                          I extracted both zip files, both having a file and a folder, to my plugins directory. At startup I get this error:
                                          Error Loading File ZLoader__FreeScale.rb
                                          > C;/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6.rb;30; syntax error
                                          > def LibFredo6.startup
                                          I must add that I am running SketchUp 7 on Ubuntu, which is a Linux distribution, with WINE (a Windows layer that allows for Windows apps to run on Linux). But as you can see it creates a C drive, so I don't think this is the problem.
                                          Coen,
                                          For sure I did not test this platform!
                                          The error you get is very strange, because it signals a syntax error in a statement which is purely Ruby.
                                          And at the stage it reads LibFredo6, nothing of my scripts has been loaded yet.
                                          In order to know more, could you turn the Ruby console on, and then type
                                          load "LibFredo6"
                                          PS: if you continue getting an error, could you comment out lines 24 and 25 of LibFredo6.
                                          Fred
                                            dacad
                                            Fredo6
                                            I'm slaping myself right know to make sure this is true...
                                            Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! THANK YOU!!!
                                            Couple of years ago i asked for a ruby/feature just like this and was never aswer, and yeasterday i was just thinking how that could come in handy right now (for a project i'm working) and you just released it!! HA HA HA HA HA!!
                                            Let me try again: A million bucks would come in handy right now...hmm...
                                            Damn it 😛
                                            Again thank you very very VERY much Fredo6
                                            David
                                            • 3 / 7
