    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 50.0k Views 61 Watching
    • fredo6F Offline
      @daniel s said:
      I only have a problem when set the dimension in the dialog box by pressing TAB. It dosen´t accept what I put.. just make a beep 😕
      I attach a video example of this.
      Daniel S
      Daniel,
      Strange. What is the default decimal separator you normally use in your version of Sketchup.
      Just in case, can you turn the Ruby console on to see if anything is displayed.
      Can you also type in the Ruby console the following command:
      Traductor.string_to_length_formula "20"
      and see what it does.
      I don't know if any other users has found that problem?
      I will analyze what it could be in parallel.
      • fredo6F Offline
        @watkins said:
        Dear Fredo6,
        One little known option of the native SU Scale tool is the ability to input final dimensions via the VCB (example: 100mm,100mm,100mm). The scale box is then scaled to those dimensions. Is this something that could be include in your script?
        Kind regards,
        Bob
        Bob,
        Just press TABwhen the scaling handle is highlighted (or use the contextual menu). You should have the Dimension box appearing. For teh time being, I preferred to reserve the VCB to scale values.
        PS: Daniel S. has found some issues with this dialog box. Maybe you can report if found any.
        • fredo6F Offline
          The taper scale tool, however, isn't working at all.
          It displays the bounding box and shows the results of all of the tool manipulations, but it never actually changes the object geometry. Picture attached. Hitting return or clicking outside the box erases the bounding box and the cube remains as is.
          Let me know what I can do to assist diagnosis.
          Thanks again.
          It is clear that there is an error in the execution of the deformation, as shown on your image.
          The best would be to turn on the Ruby console and see what it says. I don't know if it could be related to Mac.
          Also can you tell me if your run SU 7 or 6.
            roadkill
            many thanks dude... that is special!
            • O Offline
              otb designworks
              Hi Fredo!
              Here is the Ruby Console result from attempting to taper scale.
              I am using SU7, OS 10.5.6.
              Cheers, Chuck
              OTB Designworks is on Youtube
                Daniel S
                Fredo:
                When i put in the ruby console
                It returns:
                nil
                When i have open the ruby console and try to use the dialog box don`t report anything.
                I have the same problem with the taper.. it dosen´t accept what i put on the dialog box.
                I attach a screenshoot of my units.
                Daniel S
                  TeKnoel
                  this looks great! thanks for your hard work
                  • EarthMoverE Offline
                    EarthMover
                    Holy Sh!t! Just what I was thinking of asking for the other day. I love the taper. Reminds me of the Falloff function in Modo. Thanks Fredo!
                    Content Creator at Skapeup
                      gaganraj
                      phenomenal tool. works perfectly on my windows machine. same issue as kannonbal on my mac.
                      i'm amazed at how intuitive and simple such a great tool can me made. I absolutely love the little green check mark!! such a great idea. This will make SDS proxies so much easier! thanks!
                      • fredo6F Offline
                        To Daniel S(on problem of dimension dialog box)
                        I don't understand what is happening.
                        Can you then try the 3 commands below, one by one
                        Traductor.string_to_length "20"
                        "20".to_l
                        Traductor.string_to_float_formula "20"
                        Apparently other users have not reported the problem (yet). So it may be something specific to your environment.
                        • fredo6F Offline
                          To Chuck (Kannonbal) on issues with Taper Scale
                          I made an update to LibFredo6 in relation with the issues you signaled.
                          Could you download and install again LibFredo6 and advise if you still have the problem
                          • fredo6F Offline
                            Did anybody see my jaw? I lost it somewhere...
                            Fredo, the Taper function looks killer! If it does the job on Nested Components and Groups as well, then people don't have to explode the geometry anymore to perform a Free Form Deformation on it.
                            The only thing I didn't understand about the YouTube video was when you scaled that ship. What were you demonstrating there?
                            Coen,
                            Thanks for your encouragements.
                            Taper Scale should work on nested components and groups, but it has to make all components unique and explode all curves. So it's a little bit destructive. No mystery, Tapering is not a transformation that can preserve the unicity of a single definition for components (same rule as for Sketchy FFD).
                            For my ship, the purpose was just to show that Free Scale can handle large models full of components and groups, because it is actually just based on regular Scaling. Free Scale is not destructive at all, in contrast with TaperScale. Otherwise nothing special.
                              Daniel S
                              Fredo: This is the ruby console result when I enter the commands:
                              nil
                              "20".to_l
                              7.8740157480315
                              20.0
                              I attach a screenshot too.
                              Daniel S
                              • fredo6F Offline
                                Daniel,
                                I still don't see what it could be, and why you have it specifically in your environment.
                                Just in case, I made a slight change in LibFredo6. So you have to re-install it again and check if it improves. Can you try?
                                  Daniel S
                                  I tried with the new version of LibFredo6 but have no luck... still can`t use the dimension dialog box.
                                  But i find something strange in my Plugins directory: there is a new folder called "DEFPARAM_Dir" and is empty. I delete this folder, but every time that I open a new SketchUp it creates the folder again.
                                  I never had this folder before.
                                  Daniel S
                                  • W Offline
                                    Whaat
                                    Wow! Another brilliant plugin, Fredo6!
                                    • fredo6F Offline
                                      Daniel S
                                      Daniel,
                                      I think I know what it could be. I guess you have a set up where you should use the comma as the decimal separator.
                                      I made a change in LibFredo6. Maybe it will clear the issue.
                                      Thanks for your patience.
                                      PS: DEFPARAM_Dir is just the place where my scripts (today only FreeScale) stores the default parameter. It is a separate folder so that the parameters are not lost when upgrading.
                                      • fredo6F Offline
                                        Dale,
                                        You can be sure that I appreciate the compliment, coming from you.
                                          Daniel S
                                          Now works!!!... but not well!! 😆
                                          I don`t know how to explain it in english but i attach a video showing that it dosen´t scale well (i put 30 and the result is 76,200cm). But now works!!
                                          Thank you for looking into this,
                                          Daniel S.
                                          PS. It must be only my problem because I remeber in the past I had problems with TIG`s slicer... was working for everyone but not for me and then he fixes the problem and said that was a problem about the comma.
                                          Video Showing the problem
                                          • fredo6F Offline
                                            Daniel S.
                                            Daniel,
                                            My fault in the update.
                                            Can you make a last try for today with the update I made in LibFredo6.
                                            Thanks again for your patience.
                                            • 2 / 7
