    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 85.6k Views 36 Watching
    • CadFatherC
      CadFather
      you can now find the video tutorials here as well http://www.youtube.com/user/VideoSketchup
        me3mar
        First of all many thanks for the power toolbar.
        i'm having some troubles with half of the funktions of the toolbar, eventhoght there's no problem reports or warnings,
        i just klick the button, nothing happens! by (devide and portrude) i fill the options, then klick devide, or portrude... nothing happens.
        the same is happening by the following comands : Portrude, FFD (all 4), and Bevel.
        any suggestions?
        thanks again in advance
        me3mar
        • CadFatherC
          CadFather
          ..i need more info - are you using a mac?
            me3mar
            i am using pc windows xp pro - Sp 3 -
            ram 4 g.
            quad core 2,4 GH.
            sketchup 7
            thank you again
            me3mar
            • CadFatherC
              CadFather
              if the system is good it should work - if you have multiple copies of the same plugins as the ones included in the powertoolbar (protrude etc) you can get into problems
              start from this, making sure these are the only contents in the plugins folder (back up the old one)
              if it works reintroduce the others by elimination
              404 Not Found
              (www.sketchucation.com)
                me3mar
                i had to move all the rubys manualy and cleanup a little, and it works fantastic!!
                thanks CadFather for your help
                me3mar
                • FletchF
                  Fletch
                  Great work on those tus Cadfather! 👍
                  I realized I'm working with the 'old' protrude... didn't realize it had such great improvements - gotta go get it now 😎
                  Fletch
                  • N
                    numerobis
                    WOW!!! very cool! thank you! 😄
                    • EdsonE
                      Edson
                      max,
                      in order to install this toolbar i removed all my plugins and started moving them back carefully in order no to have double copies. in doing so i realized that another toolbar you made (ARCHILAND toolbar) has a folder called CD_ICONS, the same name of the icons folder for the powertoolbar. my question: is it ok to have both folders with the same name? will not there be some confusion between them? what should i do?
                      http://www.mahfuz.arq.br
                      • EdsonE
                        Edson
                        after all i did not manage to install it. the same error message as BTM reported appears to me.
                        oddly enough, why does the ARCHLAND toolbar installs without any problems and the POWERTOOLBAR does not?
                        individually, all the scrips run on my mac.
                        • B
                          bellwells
                          @edson said:
                          max,
                          Edson, there will be a problem with 2 folders the same name as you'll be asked if you want to replace the old with the new, which you do NOT want to do! What I did was simply place the contents of the PowerToolbar CD_ICONS into the other CD_ICONS folder (or vice versa) by copy all and paste.
                          Max, thanks for another great addition to SU!!!!
                          Ron
                          • CadFatherC
                            CadFather
                            hi Edson, the two plugins have different subfolders inside CD_ICONS (architect and power). you should have 1 cd_icons folder and inside it, the 2 subfolders.
                            i think the parsing errors reported can be easily fixed but i do not have a mac to check/fix - some kind master with a mac could look into it perhaps?
                            the quick other option is to disable the plugins which cause the error - if you can report the full text of the ruby console i will try later..
                            • C
                              chango70
                              OMG, Cadfather, why can't Google hire you!? I am always amazed by how professionally thought out your tools (interface at least) are! Thank you. 😍
                              • CadFatherC
                                CadFather
                                thanks Chango, though without the masters we would only have a 'nice' interface... 😉
                                (..there's more cooking in the oven..) 😉
                                • X
                                  xrok1
                                  i think it would be great (not that its not great already, but greater yet) if we could have just one SCF Toolbar & then pick and choose which ruby's we want in it, like a visual plugin bar that could be customized with any of the tools from your series of toolbars (mix and match).
                                  any chance of this? 😉
                                    Amazing and cool design! 😎
                                    A list here of Plugs used will be useful 😉
                                    • Chris FullmerC
                                      Tiffs don't work on the forum John. Use a file format more common to the web like jpg, or png works great.
                                      • B
                                        BTM
                                        tiff works on the forum
                                        ...but maybe only on macs... 😉
                                        Anyways, I had the same problem too. I no longer have the SCF powertoolbar.
                                        • Chris FullmerC
                                          That is very interesting. I never knew that. They do not show up on PC's. Good to know,
                                          I've never liked the tiff format and I don't know why.
                                          • B
                                            BTM
                                            I don't like it much either. Same, I don't know why. I like PNG the most 👍
                                            • 2 / 4
