    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 82.0k Views 36 Watching
    • CadFatherC Offline
      CadFather
      sorry about that Stan - eyes are seeing double! new version updated in first post 👍
        stanmarsh
        no trouble, glad we solve the problem.
        • EdsonE Offline
          Edson
          what a present, max! you are very generous. and the videos are something else. i have been using some of those scripts for some time but now i really know more about them. thanks!
          http://www.mahfuz.arq.br
            CadFather
            Thank you Edson - it's good to be able to give something back! 😄
            • free agentF Offline
              free agent
              is that bevel tool the same as sketchy bevel? is it a new version?
                CadFather
                no, still old version - and it can crash.. (also in this version the right click should still be there)
                  BTM
                  about 1/2 of the tools don't seem to run on macs, and the error:
                  (eval);6094; compile error
                  (eval);4921; parse error, unexpected ',', expecting ')'
                  if (n1.between? (n2 - interval), (n2 + interval))
                                                  ^Error Loading File cd_power_extension_m.rb
                                                  ^Error Loading File cd_power_m.rb
                                               appears when sketchup starts.
                  Also, for some reason or another, it seems that after downloading it, the icons for your CD ARCHILAND toolset (which seems to work fine on macs) disappeared.
                  I wish I could tell you more, but I don't know a thing about coding, or anything like that.
                    CadFather
                    BTM, i wish i could help you - unfortunately i do not have a mac
                    it seems to me it's something to do with the way some characters are recognised (though i could easily be wrong)
                    perhaps one of the masters would be able to help..?
                      gaonirico
                      Hello
                      I have problems with the plugin "Copy Path to Nodes" and "Copy to Spacing." When trying to use them instantly breaks.Before I had the plug "along the patch" and he was perfect but the problem appears using CD POWER.
                        CadFather
                        make sure you don't have copies of the originals as well..
                        also try powertoolbar on its own - back up all plugins and empty the folder, now install PT.
                          CadFather
                          you can now find the video tutorials here as well http://www.youtube.com/user/VideoSketchup
                            me3mar
                            First of all many thanks for the power toolbar.
                            i'm having some troubles with half of the funktions of the toolbar, eventhoght there's no problem reports or warnings,
                            i just klick the button, nothing happens! by (devide and portrude) i fill the options, then klick devide, or portrude... nothing happens.
                            the same is happening by the following comands : Portrude, FFD (all 4), and Bevel.
                            any suggestions?
                            thanks again in advance
                            me3mar
                              CadFather
                              ..i need more info - are you using a mac?
                                me3mar
                                i am using pc windows xp pro - Sp 3 -
                                ram 4 g.
                                quad core 2,4 GH.
                                sketchup 7
                                thank you again
                                me3mar
                                  CadFather
                                  if the system is good it should work - if you have multiple copies of the same plugins as the ones included in the powertoolbar (protrude etc) you can get into problems
                                  start from this, making sure these are the only contents in the plugins folder (back up the old one)
                                  if it works reintroduce the others by elimination
                                  301 Moved Permanently
                                  (www.sketchucation.com)
                                    me3mar
                                    i had to move all the rubys manualy and cleanup a little, and it works fantastic!!
                                    thanks CadFather for your help
                                    me3mar
                                    • FletchF Offline
                                      Fletch
                                      Great work on those tus Cadfather! 👍
                                      I realized I'm working with the 'old' protrude... didn't realize it had such great improvements - gotta go get it now 😎
                                      Fletch
                                      • N Offline
                                        numerobis
                                        WOW!!! very cool! thank you! 😄
                                        • EdsonE Offline
                                          Edson
                                          max,
                                          in order to install this toolbar i removed all my plugins and started moving them back carefully in order no to have double copies. in doing so i realized that another toolbar you made (ARCHILAND toolbar) has a folder called CD_ICONS, the same name of the icons folder for the powertoolbar. my question: is it ok to have both folders with the same name? will not there be some confusion between them? what should i do?
                                          • EdsonE Offline
                                            Edson
                                            after all i did not manage to install it. the same error message as BTM reported appears to me.
                                            oddly enough, why does the ARCHLAND toolbar installs without any problems and the POWERTOOLBAR does not?
                                            individually, all the scrips run on my mac.
                                            • 2 / 4
