    Profile Builder released!
    125 Posts 41 Posters 65.2k Views 41 Watching
      Great plugin!
      @whaat said:
      Sorry...I could not fix the followme twist in this version. Hopefully next time!
      Actually it was a feature request to addto PB so should not be sorry (yet πŸ˜‰ ).
      Would be nice tho... πŸ‘
      • plot-parisP Offline
        plot-paris
        what a start into 2009! 😍
        • FrederikF Offline
          Frederik
          Yeah - I just bought it...
          Waiting for the download instructions from Smustard... πŸ˜‰
          Cheers
          Kim Frederik
          • StinkieS Offline
            Stinkie
            Just bought it. Thanks, Whaat, and keep 'em coming.
              peweuk
              I just bought and tried this, and I have a query.
              I created a walls profile and it's great. It allows me to create a 2 layer wall with the correct dimensions for the walls and cavity quicker than anything else I have used.
              However I have a problem with the texturing of the walls.
              In the image below the walls were drawn in one operation from front left to back right, but when a texture is applied it orients it differently on the two walls.
              What's the solution? Any ideas?
                dtrarch
                Peweuk
                It looks like a real bug and was the same for me. 😞
                If you explode the group the texture will be as expected.
                dtr
                  Click Draw
                  Thanks so much Dale. Just got it. I think I'll be calling in sick for work tomorrow! 😍
                  Cheers,
                  Jeff
                  Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                    peweuk
                    I was hoping it was not me πŸ˜‰
                      What Whaat is Dale? πŸ˜‰
                      Seems an another task! β˜€
                        steelers05
                        have not tried it yet but it looks awesome. With tools like this and sub+smooth, i may get over the aggrevations of SU and not even bother to try and learn 3ds max....um wait nix that because SU still doesnt support high poly counts. I vote that be the next script that somebody creates. Anyways, great work and cant wait to get my hands on this one.
                          linea
                          Thanks Dale
                          superb!
                          • david_hD Offline
                            david_h
                            just made my purchase. Any special instructions on Installation?
                            Uh . ..never mind! I got the Guide. 😳
                            • utilerU Offline
                              utiler
                              Way cool, I'm going to the shop now.....
                              Just Curious...
                                boilingsnow
                                Hello Whaat,
                                I bought the plugin just now and I'm happy to have the excellent tool in my sketchup.
                                But I also found a problem while using it.
                                If I have a closed path (rectangular for exampleοΌ‰and use the "follow me" tool, the result I get is NOT closed but open at one point. It doesn't work either even when I weld them into a polyline.
                                • dazzaD Offline
                                  dazza
                                  Just bought it and can't wait to get some time to play around with it.
                                  Thanks Dale, great work!!! πŸ‘ πŸ‘ πŸ‘
                                  All people have the right to stupidity but some abuse the privilege.
                                    dtrarch
                                    Howard'L
                                    This is really super and gota have utility but does need some way to get into the Libraries to view / select etc without having to scroll through the profiles one at a time.
                                    They are just ascii files and if anyone knows β˜€ how to view and or convert each to a vector graphic that would be good start.
                                    Not my expertise but sure would be a "Giant Step" (Trane) to make PB more versatile. ❓
                                    dtr
                                      remus
                                      Im starting to run out of cool ways of describing your plugins, i think that says it all really. Thanks again.
                                      • H Offline
                                        Howard leslie
                                        Dale,
                                        Thanks for creating this plug-in - its brilliant.
                                        I'm just trying it out at the moment.
                                        See below - possible bug and a request.
                                        A Possible Bug:
                                        1. When you assign Mark numbers - ie a Prefix or Suffix eg #1,
                                          I was expecting the original Group Name to still remain - is this deliberate or a bug ???
                                          eg Original Group Name = UB_152x89x16
                                          After applying Mark (Suffix) I would expect to see:
                                          UB_152x89x16#1, UB_152x89x16#2, UB_152x89x16#3 etc
                                          What I get is #1, #2, #3 etc
                                          Could you please take a look at this if you get time as this feature will be so useful.
                                          (Make original group name remain by default - unless users actually DO want to get rid of it).
                                        2. Something for you to ponder:
                                          I have folders containing many profiles. One skp file = One Profile. I'm sure I'm not alone.
                                          (eg Steel Sections).
                                          Traditionally, this would be imported into a skp file (it would now be a component) and then extruded manually. Profile Builder gives us the ability to do our extruding a bit smarter and quicker than this - Halleluljah !!!.
                                        My request is, could you either:
                                        a. Add in a feature to import profiles from a directory THAT ARE INDIVIDUAL *.skp files into a Profile Library (profiles retaining their skp filenames minus the *.skp file extension ie UB_123_567.skp = UB_123_567 in profile library OR
                                        b. A feature so that these profiles can be utilised directly (ie without importing them).
                                        The alternative to this at the moment is to add all profiles one by one. This is possible but tedious.
                                        Any help you can give much appreciated
                                        Thanks once again for all your hard work with this script.
                                        Regards
                                        Howard L'
                                          seasdes
                                          Thanks for the plugin. Can I explain to a simpleton how I can have the walls intersect and mitre correctly when the the walls are created separately.
                                          Walter
                                          Using Sketchup Pro 2019
                                          • utilerU Offline
                                            utiler
                                            Thanks Dale, I'm having heaps of fun with this....
                                            One questions: when creating a closed profile member, picking the point where you started doesn;t merge the profile. [see attached] I understand I could do it 'building along a predefined path' but seems it appears to be the long way around....
                                            Thanks in advance.
                                            Just Curious...
                                            • 1 / 7
