    Skp Viewer
    18 Posts 12 Posters 15.1k Views 12 Watching
    • BurkhardB Offline
      Burkhard
      Wondering if it is possible to get an image viewer for skp files.
      I have tons of unknown files ( testing scenes )which makes it hard to view and sort it.
      Not XnView, because it doesn't show all. And it needs an Sketchup support! My wish is an image viewer with following:
      Two windows for drag and drop selecting.
      Drag and drop right into Sketchup ( Components ) Not import function only
      Same for Materials ( jpgs, tiffs, bmp, png...)
      Start dirctly out of Sketchup ( and seperate )
      It makes more sense to have it standalone like style builder. This can be an easy one without any image editings. Just select what you're looking for
      http://www.ia-plus.de
      • BurkhardB Offline
        Burkhard
        It is not enough for me. Looking for a better workflow
        • soloS Offline
          Deep exploration.
            totom
            Windows XP and Vista both have thumbnail support for SketchUp. It is installed by SketchUp once you install the actual program.
            I used to see SKP thumbanil with XP.
            Now with VISTA installed, I can't.
            Kind of pain in the arse issue, here.... 😒
            Any clue yet ?
            • jim smithJ Offline
              jim smith
              Totom mentioned above that he can't get thumbnails with Vista. His Vista may need some option tweaking.
              I've been making the transition to Vista and have found it to be XP with a few improvements but mostly just renaming and reorganizing. At least with the latest service pack SU runs on it with no hitches as well as my other major software. One really improved feature, however, is found in "view" which gives several thumbnail options. See attached PDF of a screen shot. It will give a thumbnail view of almost any type of file and on the largest setting, they are quite legible, but, not large enough for really detailed examination.
              vista-thumbnail-screen.pdf
              "Out of clutter find simplicity,
              from discord find harmony,
              In the middle of difficulty lies opportunity"
              Albert Einstein
                Any clue yet ?
                Odd. I get fine Thumbnail in Vista. Do you get thumbnails for other file formats?
                • H Offline
                  HFM
                  Any clue yet ?
                  I had that problem a while back [also with photoshop] And found a solution for photoshop that also fixed the SU thumbnail.
                  Hope it helps πŸ˜„
                  • 3 Offline
                    3eighty
                    "Not XnView, because it doesn't show all. And it needs an Sketchup support!"
                    Wondering what you mean in the above?? I use xnview all the time? Am I missing something..
                    • JoelM3DMJ Offline
                      JoelM3DM
                      I figured it out! There's an easy way. My folders stopped displaying thumbnails so I reinstalled SU, after checking Repair. Now they're back -- Joel
                      || Joel Metzger 3D Modeling
                      || story-shorts.net - Animation with SU
                        troyhome
                        I'd love to see a stand-alone skp viewer that doesn't require you to open the skp before you can preview it, that has multiple panes for organizing, and that can thumbnail a skp file at a variety of sizes (128 pixles x 128 pixels or more).
                        Oh, and it would run on a mac and pc. or just a mac. yeah... just a mac is fine. πŸ˜„
                        IOviz.com
                        SU Pro 2024 PC
                        • X Offline
                          xrok1
                          Error 404 (Not Found)!!1
                          (sketchup.google.com)
                            troyhome
                            SketchUp Viewer is virtually unecessary now that there is a free version of SketchUp (although it is a smaller file size and is very simple to use)- what we need is something like iPhoto or acdsee for skps.
                            IOviz.com
                            SU Pro 2024 PC
                              chango70
                              Adobe Bridge does a fairly decent job.
                              • BurkhardB Offline
                                Burkhard
                                c'mon guys, a simple viewer like it is implemented in the RP ProjectSketch. Just to have a view to your own collection and place it directly into your project. Nothing more or.... the same for mateials.
                                Can be opened in a Web Dialog Browser.
                                EDIT
                                Wrong name corrected. It is ProjectSketch, which has a Dialogbox like an external Material or Component Browser. I would like to see this with an available path to my own folders.
                                  troyhome
                                  mmmmm... ???
                                  IOviz.com
                                  SU Pro 2024 PC
                                  • brookefoxB Offline
                                    brookefox
                                    Jim, your pdf image shows a directory of pdfs rather than skps.
                                    ~ Brooke
                                      brookefox
                                      Did not work for me. Perhaps a reboot will enable.
                                      Though for me Vista 64 MS Explorer does not display skp thumbs, xplorer does, and XnV does. XnV says it will preview as well (the larger image in the third window) but does not for me, now it just shows the thumb in the preview window. Working on that one.
                                      ~ Brooke
                                      • X Offline
                                        xrok1
                                        would be pretty sweet if this could read .skp. http://www.glc-player.net/index.php
                                        http://www.glc-player.net/images/Win_Venus_full.jpg
                                        anyone part of the forum?
