    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 71.1k Views 40 Watching
    • david_hD Offline
      david_h
      Very cool. Thanks.
      • arqpadaoA Offline
        arqpadao
        small detail.
        There are tutorials on how to use the plugins...
        I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
        fernando padão
        arquiteto
        porto alegre - brasil
        http://arqpadao.blogspot.com
        • CadFatherC Offline
          CadFather
          i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
          but in short they are easy to start with - try and see
          draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
          draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
          on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
          trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
          you will also find many tutorials in pdf on Didier Bur's site
          404 Not Found
          (www.crai.archi.fr)
            AthidhiTM
            thanks
            • arqpadaoA Offline
              arqpadao
              thanks
              this will be very good
              fernando padão
              arquiteto
              • F Offline
                Frank0503
                Thanks CADfather, I've already download your ruby in another 4r & it's really really useful. But I wonder why you don't more develop it more, like could I change the style of stair tread like Sketchup?
                  CadFather
                  ..now that we have dynamic components, the stairs might be less important - in any case i'm working on an update..
                  also remember the rubies have been created by the ruby masters - all i did was integrate them into the toolbar with command and icons
                    lorenzo
                    thanks a lot Cadfather!!!
                    that's great!!!
                      CadFather
                      your welcome Lorenzo 😄
                        Ross Macintosh
                        Max - you truly are the CadFather! Your tool bar is a great addition to the neighborhood.
                        I have one little problem relating to the roof tools. On my toolbar the mansard & gable roof buttons are transposed. Clicking the gable produces the mansard etc. -- The tooltips are correct so it seems its just the images are referenced wrong.
                        Regards, Ross
                          bellwells
                          Max, as Ross just pointed out, the icons representing the gable, mansard and hipped roof designs are mixed up. The pyramid roof icon is correct. I have renamed the icon (.png) files appropriately and am attaching a new CD_ICON folder here so others can replace the old folder with this one. I hope this is a permissable act on my part.
                          CD_ICONS.zip
                          EDIT: Ohhh...and thank you very much for a wonderful tool!!
                          Ron
                          • jcdbJ Offline
                            jcdb
                            Thanks CF. What does Pointify do?
                            http://www.acustombuilder.com
                              bellwells
                              I think pointify converts vertexes into construction points. Do a search and you'll find plenty of posts on the subject.
                              Ron
                                CadFather
                                Hi, just back from italy where i had little or no connection - can't believe i did live just the same 😲 - i knew there were a couple of icons out of place but they eventually slipped by.. thanks all for your feedback.. and Ron, i will change the package with the updated icons.. (done)
                                Cheers! 👍
                                • Z Offline
                                  zeal
                                      :sunglasses:
                                  • Z Offline
                                    zamant
                                    thank's a lot!!!!
                                    antonio 😍
                                      chango70
                                      Cadfather, care to do a guide on how to create Icons and use them with rubies? I like icon interface and would love to help out.
                                        arquilevis06
                                        Very Nice Work!!!! muy buen trabajo Bro!!!!
                                        • F Offline
                                          freakinsomnia
                                          thanks cadfather...but,any tutorial about archiland?
                                            This plugin bundles a Sketchup.rb file... it's a file that one doesn't need to bundle, as each SU version has its own.
                                            • 3 / 3
