    Augmented Reality Plug-in for Google Sketch-Up released
    extensions
    112 Posts 37 Posters 68.6k Views 37 Watching
      sepo
      It seems quite good value for money...it is less than 100Euros.
        mirjman
        I second the need to control the scale of the displayed model. I also noticed that the software had trouble recognizing the marker at very shallow angles- is there any way to overcome this problem by using two markers on planes that are perpendicular to each other? (a "floor" plane and a "wall" plane)? otherwise I noticed that the plug-in worked as advertised, thanks!
        • Graziano TerenziG Offline
          Graziano Terenzi
          The ARplug-in as such does implement basic augmented reality functionalities.
          However it is possible to introduce further functionalities like the ones you are mentioning. Both scaling the model and allowing bottom-up perspective by using two orthogonal markers can be integrated in the plug-in. Thank you for sharing with us suggestions which we will surely be implemented in a future upgrade of ARplug-in.
          With reference to a comment by BTM
          •BTM on Wed Dec 17, 2008 10:00 pm
          Any mac versions out yet/ set to come out soon?
          we plan to release a mac version not soon, but we will surely release one.
          Graziano Terenzi
          CEO @ Inglobe Technologies
          • MALAISEM Offline
            MALAISE
            Quite impressive plugin, I allready see some purposes around technical explanations for complex devices.
            Great. I'll test this plugin very soon.
            MALAISE
            • JClementsJ Offline
              JClements
              Chris: please read your personal messages.
              Graziano: Would your display paper "substrate" work on a vertical surface? For instance, to display an instrument panel.
                matteo
                graziano,
                that's utterly fantastic!
                complimenti.
                /matteo
                hire me: http://www.nonsolo3d.it/ !
                • Chris FullmerC Offline
                  ok, I had a chance to test it out. AWESOME! Very cool indeed! I have no idea what I would use it for, but who cares! Its great. I had recently seen this technology showcased somewhere else and thought it was way cool, too bad I'd never use it. Then within a week you come posting the plugin for my favorite (only) 3d software. Very cool, thanks!
                    Graziano Terenzi
                    Thank you again. Any suggestion for improving the ARplugin is welcome. So feel free to comment. I have seen many portfolios of ours...you are doing great work with Sketchup! This is really a lively comunity.
                    Graziano
                    Graziano Terenzi
                      JClements
                      Graziano:
                      What can you tell us about running an animated model.
                      I saw one animation on You Tube. Can the animation be controlled (started, stopped) from within SketchUp?
                      Are there plans to enhance animation capabilities?
                        I tried it with an animated dynamic component. It didn't work. I think my DC made me wait until it was done animating before I was allowed to activate anything else - including the arplugin. It would be cool.
                          Graziano Terenzi
                          Well, with reference to animated models I have to remark that the general framework of ARmedia allows the visualization of animated models as well as the definition of suitable control actions over the models themselves. For what concerns Sketchup, we are studying to which extent Sketchup is compatible with the treatment of animations within our framework and enventually which steps should be taken in order to extend the Plugin.
                          Graziano
                          Graziano Terenzi
                          • chrisglasierC Offline
                            chrisglasier
                            For what concerns Sketchup, we are studying to which extent Sketchup is compatible with the treatment of animations within our framework ...
                            Another quick example to the one posted before in this thread shows animation of a Sketchup component made and controlled by html and javascript in a Sketchup web dialog box: [flash=425,344:3n0xxamk]http://www.youtube.com/v/kDtHvf4wd8w[/flash:3n0xxamk]
                            I too would be interested whether there could be any interoperability with ARmedia.
                            Edit: BTW please note that a number of component instances can move along different paths at different speeds at the same time.
                              Wow, Chris, I'd really like a loo like that. Moving around in the apt would be cool while potting! I even thought you'd go downstairs in that elevator...
                              Joking aside; really cool animation 👍
                              (I saw the other one with the vertical bath tub the other day and funny ideas came to my mind as well)
                                chrisglasier
                                @gaieus said:
                                ... I even thought you'd go downstairs in that elevator...
                                Can you wait a couple of weeks?
                                I think I should explain that I don't have a sanitaryware fetish, I use its components because they have the most awkward sizes and shapes, have multiple plumbing connections, strange relationships with accessories like toilet roll holders and all have to be fitted into the smallest of spaces. I hope I have made my case (or do you think I'm overcompensating?)
                                  @chrisglasier said:
                                  I think I should explain that I don't have a sanitaryware fetish, ... (or do you think I'm overcompensating?)
                                  I didn't mean that... just joking... 😉
                                    ScottPara
                                    I am wondering about the capabilities of this plugin in regards to:
                                    are the file size limitations to this plugin? whether it be number of faces or overall file size. We ran a large model (400+mb) at it and it never recognized the model before the 30 second limitation was up.
                                    Can there be multiple markers within a single model? Meaning, can we have one marker for a conference room and then transfer to a marker in an office without loading a seperate model? Other AR's offer a function like this I am just wondering if this could be a possibility with this plug in.
                                    What else is offered with a purchased license that we not have with the demo?
                                    Scott
                                    Love the fact that some HATE my avatar.....
                                    • MALAISEM Offline
                                      MALAISE
                                      Hi Graziano
                                      I'm encountering some difficulties when using ARplugin. I'm asked for connecting a cam whereas it's already connected but not recognized.
                                      Questions : do we have to use Sketchup V7 ? ( I still use V6 )
                                      Is the size of the skp file is involve into image calculation ( more then 30 s are needed) ?
                                      Does the cam automatically switch on, when the plugin is running ?
                                      I tested a similar software and it had worked (ARTAG demo).
                                      Thanks for any, even short advices
                                      MALAISE 😄
                                        Graziano Terenzi
                                        Hi Scott,
                                        I'm going to answer your questions:
                                        Talking about the recognition capabilities of the plugin, models size is not a limitation nor it is the models complexity. Of course users must have enough resources to treat such big models like in any real-time application. Specifically, one point that deserves attention is texturing: many 3D graphic cards that cannot treat non-power of 2 textures dimensions, usually will try to rescale textures on-the-fly each time the model should 'appear' on screen, so if there are lots of such textures and not enough video memory, you could experience delays before the object is actually displayed. I'd like to remark that models that should be rendered in real-time deserve attention both in keeping a low polygons count and in using 'standard' size textures.
                                        Basically, our framework allows to have the same object associated to many markers, as well as to have many objects associated to the same marker or different markers. It also allows to have some relationship among markers for the same objects. If you mean to have two distinct models associated with two distinct markers, it is possible within ARmedia, even though it is not yet implemented in the ARplugin as such. This functionality will surely come with a future upgrade. On the other hand, if you refer to a single distributed application running on two or more machines at the same time, this also could be implemented on demand but would be far beyond the scope of a basic version of ARplugin.
                                        Scott
                                        The licensed version allows you to have a customizable message, no time limit. We are also adding other functionalities that will be released soon after this first market test, that will be provided to customers of the previous release with no additional cost.
                                        I hope I covered each point
                                        Regards
                                        Graziano
                                        Graziano Terenzi
                                          Graziano Terenzi
                                          Hi Malaise,
                                          with reference to your basic problem
                                          maybe you are using a computer (e.g. a laptop) with two webcam installed. In this case you should try to make sure of having only one webcam enabled, the other must be disabled.
                                          No, Sketchup V6 works fine.
                                          As I have remarked in a previous post, model size is not a problem for the plugin. However if teh model is very big, it could take more than 30 sec to load. This is not a limitation of the full version.
                                          This depends on the settings of your computer, not on the plugin. Generally it does.
                                          Feedback is always welcome
                                          Graziano
                                          Graziano Terenzi
                                          • Mike LuceyM Offline
                                            Mike Lucey
                                            Hi Guys,
                                            I have yet to try out the great plug-in. I have been thinking about exactly what it is and I suppose the name, Augmented Reality, pretty much discribes the product. http://en.wikipedia.org/wiki/Augmented_reality
                                            I imagine 'Virtual' Prototyping might be another way of describing the product? Then again 'Prototyping' doesn't mean a lot to non tech people in general.
                                            Now don't laugh ..... PLEASE!!!! I think it should be called Magic Model! I can imagine showing a client / customer, with NO CLUE about this stuff, a video of the model JUST APPEARING after I utter the words Abracadabra or Hocus Pokus! It could be fun 😉
                                            Mike
                                            • 2 / 6
