    Augmented Reality Plug-in for Google Sketch-Up released
    extensions
    112 Posts 37 Posters 71.4k Views 37 Watching
    • Chris FullmerC Offline
      I tried it with an animated dynamic component. It didn't work. I think my DC made me wait until it was done animating before I was allowed to activate anything else - including the arplugin. It would be cool.
      • Graziano TerenziG Offline
        Graziano Terenzi
        Well, with reference to animated models I have to remark that the general framework of ARmedia allows the visualization of animated models as well as the definition of suitable control actions over the models themselves. For what concerns Sketchup, we are studying to which extent Sketchup is compatible with the treatment of animations within our framework and enventually which steps should be taken in order to extend the Plugin.
        Graziano
        Graziano Terenzi
        CEO @ Inglobe Technologies
        • chrisglasierC Offline
          chrisglasier
          For what concerns Sketchup, we are studying to which extent Sketchup is compatible with the treatment of animations within our framework ...
          Another quick example to the one posted before in this thread shows animation of a Sketchup component made and controlled by html and javascript in a Sketchup web dialog box: [flash=425,344:3n0xxamk]http://www.youtube.com/v/kDtHvf4wd8w[/flash:3n0xxamk]
          I too would be interested whether there could be any interoperability with ARmedia.
          Edit: BTW please note that a number of component instances can move along different paths at different speeds at the same time.
            Wow, Chris, I'd really like a loo like that. Moving around in the apt would be cool while potting! I even thought you'd go downstairs in that elevator...
            Joking aside; really cool animation 👍
            (I saw the other one with the vertical bath tub the other day and funny ideas came to my mind as well)
              chrisglasier
              @gaieus said:
              ... I even thought you'd go downstairs in that elevator...
              Can you wait a couple of weeks?
              I think I should explain that I don't have a sanitaryware fetish, I use its components because they have the most awkward sizes and shapes, have multiple plumbing connections, strange relationships with accessories like toilet roll holders and all have to be fitted into the smallest of spaces. I hope I have made my case (or do you think I'm overcompensating?)
                @chrisglasier said:
                I think I should explain that I don't have a sanitaryware fetish, ... (or do you think I'm overcompensating?)
                I didn't mean that... just joking... 😉
                  ScottPara
                  I am wondering about the capabilities of this plugin in regards to:
                  are the file size limitations to this plugin? whether it be number of faces or overall file size. We ran a large model (400+mb) at it and it never recognized the model before the 30 second limitation was up.
                  Can there be multiple markers within a single model? Meaning, can we have one marker for a conference room and then transfer to a marker in an office without loading a seperate model? Other AR's offer a function like this I am just wondering if this could be a possibility with this plug in.
                  What else is offered with a purchased license that we not have with the demo?
                  Scott
                  Love the fact that some HATE my avatar.....
                  • MALAISEM Offline
                    MALAISE
                    Hi Graziano
                    I'm encountering some difficulties when using ARplugin. I'm asked for connecting a cam whereas it's already connected but not recognized.
                    Questions : do we have to use Sketchup V7 ? ( I still use V6 )
                    Is the size of the skp file is involve into image calculation ( more then 30 s are needed) ?
                    Does the cam automatically switch on, when the plugin is running ?
                    I tested a similar software and it had worked (ARTAG demo).
                    Thanks for any, even short advices
                    MALAISE 😄
                      Graziano Terenzi
                      Hi Scott,
                      I'm going to answer your questions:
                      Talking about the recognition capabilities of the plugin, models size is not a limitation nor it is the models complexity. Of course users must have enough resources to treat such big models like in any real-time application. Specifically, one point that deserves attention is texturing: many 3D graphic cards that cannot treat non-power of 2 textures dimensions, usually will try to rescale textures on-the-fly each time the model should 'appear' on screen, so if there are lots of such textures and not enough video memory, you could experience delays before the object is actually displayed. I'd like to remark that models that should be rendered in real-time deserve attention both in keeping a low polygons count and in using 'standard' size textures.
                      Basically, our framework allows to have the same object associated to many markers, as well as to have many objects associated to the same marker or different markers. It also allows to have some relationship among markers for the same objects. If you mean to have two distinct models associated with two distinct markers, it is possible within ARmedia, even though it is not yet implemented in the ARplugin as such. This functionality will surely come with a future upgrade. On the other hand, if you refer to a single distributed application running on two or more machines at the same time, this also could be implemented on demand but would be far beyond the scope of a basic version of ARplugin.
                      Scott
                      The licensed version allows you to have a customizable message, no time limit. We are also adding other functionalities that will be released soon after this first market test, that will be provided to customers of the previous release with no additional cost.
                      I hope I covered each point
                      Regards
                      Graziano
                      Graziano Terenzi
                        Graziano Terenzi
                        Hi Malaise,
                        with reference to your basic problem
                        maybe you are using a computer (e.g. a laptop) with two webcam installed. In this case you should try to make sure of having only one webcam enabled, the other must be disabled.
                        No, Sketchup V6 works fine.
                        As I have remarked in a previous post, model size is not a problem for the plugin. However if teh model is very big, it could take more than 30 sec to load. This is not a limitation of the full version.
                        This depends on the settings of your computer, not on the plugin. Generally it does.
                        Feedback is always welcome
                        Graziano
                        Graziano Terenzi
                        • Mike LuceyM Offline
                          Mike Lucey
                          Hi Guys,
                          I have yet to try out the great plug-in. I have been thinking about exactly what it is and I suppose the name, Augmented Reality, pretty much discribes the product. http://en.wikipedia.org/wiki/Augmented_reality
                          I imagine 'Virtual' Prototyping might be another way of describing the product? Then again 'Prototyping' doesn't mean a lot to non tech people in general.
                          Now don't laugh ..... PLEASE!!!! I think it should be called Magic Model! I can imagine showing a client / customer, with NO CLUE about this stuff, a video of the model JUST APPEARING after I utter the words Abracadabra or Hocus Pokus! It could be fun 😉
                          Mike
                            Just had a little play around. Worked quite well. Just had to play around with the position of the camera and the lighting in the room in order to make it work smoothly.
                              Mike, if you have a webcam plugged in and working, you seriously have to try this plugin. Its VERY easy to install and get working. And its just a single click of a button that starts the thing inside of SketchUp. Its quite normally.
                              Except on my in-laws computer where I'm on vacation for a while. I installed it here and it all went just fine, but when I tried to run it the first time, it asked me to select a video input device. And it had a list of 2. But I've only got 1 installed. The 2nd one was something like ATI unified stream or something. I really don't rememebr exactly what it said. Anyhow, from the list I selected the quickcam, but it just shows a black screen when the plugin is running. Even the quickcam works great, we use it for videoconferencing. So I'm wondering how to get back to selecting the video input device so I can see exactly what it thinks is installe so maybe I can track it down and disable it. Any ideas how to do that? I'd love to show this to my inlaws. They are doing lots of interior decorating and I could show them some alternatives for fun. Thanks in advance Graziano! This really is a cool plugin,
                                Mike Lucey
                                Chris,
                                My initial problem is that I have to swing over the Bootcamp on the Mac and get things up and running. It no big deal really just a nuisance. Still, I'm looking forward to giving it a bash.
                                I will have a think about the problem you mention and if I come up with anything I will post. Again, I am sure somebody will pipe up soon with advise.
                                Mike
                                  Mike Lucey
                                  Guys,
                                  I wonder if this plug-in could be leveraged to create a movie of a building plot with an SU model in-situ. I have looked at various ways of doing this but it involved expensive complex applications AND a LOT of skills which I don't have presently.
                                  Here is the scenario,
                                  1. Rig up a video camera for making an moving video. I have information on how to make low cost devices that will keep the 'path' of the video camera 'smooth'!
                                  2. Walk or drive past a plot of land that is to be the site of a new building that I am designing and make a video.
                                  3. What I have in mind and investigated is a way (simple) to place the SketchUp model on the video.
                                  This would make this plug-in invaluable when it comes to 'selling' the idea to the Planning Authorities.
                                  Now, this would be a Magic Model 😆
                                  Mike
                                    linea
                                    Mike that is a great idea, it takes the possibilities for this plug in to another level.
                                      Mike Lucey
                                      Hopefully Graziano will be able to let us know if there is any chance of this Plug-In being able to do this 👍
                                        I think the power of this plugin is the ability to work in real time. So no smooth cameras and pre-shooting required. the idea scenario would be to have an empty lot. Put up a big flat wall in the back. Then fix the marker onto it. Then take your client to the site and in real time show them their new building on the site and be able to walkaround portions of it.
                                        This qould require being able to control the scale of the model as it is placed in the video stream though. Definitely do-able in future version I would image?
                                        ps - still no luck on my own fixing the problem. I remain optimistic though.
                                          Ross Macintosh
                                          I've only looked through a small number of youtube videos re augmented reality so my idea might have already been tried -- I don't know...
                                          The idea:
                                          Using multiple referencing 'cards' (I don't know what they are called - but I mean the things the camera see's), imagine clothes made out of them -- so when on camera you are wearing a composite 3d construction. To make this work it would seem the plugin would need to be able to assign different components to different cards. Is that possible now? -- It could turn sketchup artists into virtual fashion designers.
                                          To Chris Glasier -- Your 'Nameset' plugin videos are looking really interestng! Some time ago, When you first wrote about what you were creating I found the ideas very confusing. The videos give me a better understanding of its potential. It seems your postings in this thread are getting lost. It would definitely be cool if your approach to animation (as shown in your video examples) would work while the model was presented as an augmented reality. I can imagine some of the cool effects that would be possible.
                                          Regards, Ross
                                            Ross Macintosh
                                            Another idea:
                                            Imagine creating a Layout presentation of your new design. You meet in the boardroom with the clients to show them a series of printed out & foamcore-mounted Layout-created panels. It's pretty much a traditional presentation. Most of the panels have the usual model views, plans & elevations. But one features the reference graphic for the augmented reality plugin.
                                            You present each panel in succession getting to the one with the reference graphic last. You turn on a monitor in the room and presto the clients will see the model 'attached' to the panel. The camera would have been 'live' through the whole presentation but you'd keep the monitor off until you wanted to display the model.
                                            Regards, Ross
                                            • 2 / 6
