    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Working faster on large models
    7 Posts 5 Posters 1.0k Views 5 Watching
      David M
      I am working on a really large model at the moment and it is becoming very slow. I would like to know if it is possible to export an object from the large model for example a reception counter to a new file so that I can add dimensions and text and if I make any changes to the object then it will automatically be updated in the large model.
      • rodrigonotorR Offline
        rodrigonotor
        Hi David M, look in here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=11437 in the List of Sessions
        then in the link "work with large models",
        • Sketchando.net • www.arqcad.net •
          Hi David and welcome!
          If you create a component (which is practically a SketchUp file) of some geometry within your model, you can right click > Save as (...a separate skp file).
          Now you can work on this file separately by simply opening it then when finished save it, go back to your original model, right click on the component again > Reload. A file browser window pops up, navigate to your file and open it.
          Edit; I moved your topic out of the wish list to the main SU Discussion forum.
            anglaret
            http://fr.youtube.com/watch?v=hnhkei2dSrY
            This is the address of an excellent video from SU last basecamp
            Marc
              rodrigonotor
              Gaius and David M, sorry, my answer seems to be a little offtopic. I imagine something like Autocad Xref`s. We should have SU Xrefs or .... we have??? 😲
                There is an Xref manager plugin by TIG (afaik) but haven't ever used it so I cannot comment on that.
                  creator 3d
                  I have worked for many years in the simulation industry and worked with MultiGen Creator. This 3D modeling tool had a very nice option called ā€œIsolate selectā€. If you are working on a complex model or scenery and having difficulty with speed or parts that are blocking your view when going around it than this option is very useful.
                  Just select the part you need to work on and type ā€œIā€ and a new workspace opens, it is also possible to switch between the two workspaces.
                  Henri
