    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 84.1k Views 36 Watching
    • CadFatherC Offline
      CadFather
      did you replace all of the contents?
        stanmarsh
        yes, i deleted all the contents of the plugins folder then extracted the scf powertoolbar there. i can click on the mirror toolbar and create the 3 points for the mirror script to work, after clicking the 3 points, i get bugsplat.
        • free agentF Offline
          free agent
          Hi Cad-daddy
          awsome set again, a comment about the handrails, never used it before but now see its usefullness, wouldnt it be better if the posts are components as the simple rectangle or tube is far too simple for my liking and would be indeed handy if i could just go into one and dump my own baluster??
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            CadFather
            thanks for the feedback everyone!
            @ Stan - very strange, it works just fine on mine - are you using vista or mac?
            @ Freeagent, you can - have a look at the tutorials ๐Ÿ˜‰
              stanmarsh
              hi Cadfather,
              im using windows xp sp2 and sketchup 6 & 7 free version, i reinstalled sketchup 7 but the bugsplat persist, i tried it as well on sketchup 6 and it has the same problem. its really weird, maybe my computer has the problem. i will test it on another computer and see if it still happening.
              edit, i tested it on another machine, using windows xp sp2 sketchup 6, and i get bugsplat too.
                CadFather
                have you still got the original version? does the mirror work?
                i will try on a fresh xp install
                  stanmarsh
                  hi Cadfather,
                  yes, i still have the first version, i just replace the plugins with the old one and it has the mirror problem also, ๐Ÿ˜ฎ i tested it earlier and its working fine. its really weird, the mover2 which did not work on the first version is working fine. but the drop is still not working and the mirror is now having bugsplat. could be something to do with the mover2 script?
                    CadFather
                    mm..the behaviour you describe does not surprise me when mixing the different versions (it was just a try)
                    this is what the folder should look like (new version only)
                    i just tried it on a fresh xp install (virtualbox) and it works.. ๐Ÿ˜•
                    check whether your firewall is causing the problem - i had a bug with the copy command in SU7 and online armour 3. downgraded to 2 and it works..
                    • arquitectomaracuchoA Offline
                      arquitectomaracucho
                      wow great tools, true friend you're doing an incredible job. The tool is being mirror problem, can not even play when there is already an accident. Greetings
                        CadFather
                        ..i did say it was beta! ๐Ÿ˜„
                        will keep looking into it - meantime please post feedback, bugs comments, thanks.
                          stanmarsh
                          hi Cadfather,
                          thank you for the help! everything finally works! i think you can remove the beta now, because everything is perfect. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                          the problem was the mover2.rb inside the plugins folder. its included in the recent zip file so i have problem with bugsplat, but after i removed it following your folder structure, everything is working now.
                          thanks for the help and for this wonderful toolbar!
                            CadFather
                            sorry about that Stan - eyes are seeing double! new version updated in first post ๐Ÿ‘
                              stanmarsh
                              no trouble, glad we solve the problem.
                              • EdsonE Offline
                                Edson
                                what a present, max! you are very generous. and the videos are something else. i have been using some of those scripts for some time but now i really know more about them. thanks!
                                edson mahfuz, architect| porto alegre โ€ข brasil
                                http://www.mahfuz.arq.br
                                  CadFather
                                  Thank you Edson - it's good to be able to give something back! ๐Ÿ˜„
                                    free agent
                                    is that bevel tool the same as sketchy bevel? is it a new version?
                                      CadFather
                                      no, still old version - and it can crash.. (also in this version the right click should still be there)
                                        BTM
                                        about 1/2 of the tools don't seem to run on macs, and the error:
                                        (eval);6094; compile error
                                        (eval);4921; parse error, unexpected ',', expecting ')'
                                        if (n1.between? (n2 - interval), (n2 + interval))
        ^Error Loading File cd_power_extension_m.rb
        ^Error Loading File cd_power_m.rb
        appears when sketchup starts.
                                        Also, for some reason or another, it seems that after downloading it, the icons for your CD ARCHILAND toolset (which seems to work fine on macs) disappeared.
                                        I wish I could tell you more, but I don't know a thing about coding, or anything like that.
                                          CadFather
                                          BTM, i wish i could help you - unfortunately i do not have a mac
                                          it seems to me it's something to do with the way some characters are recognised (though i could easily be wrong)
                                          perhaps one of the masters would be able to help..?
                                            gaonirico
                                            Hello
                                            I have problems with the plugin "Copy Path to Nodes" and "Copy to Spacing." When trying to use them instantly breaks.Before I had the plug "along the patch" and he was perfect but the problem appears using CD POWER.
                                            • 1 / 4
