    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 85.6k Views 36 Watching
      Matt666
      Hi CadFather !
      It would be great to have an image of your toolbar, with all tools explained!
      Thank you!
      Frenglish at its best !
      My scripts
        stanmarsh
        hi Cadfather,
        just tested the new one, the first two problems i have earlier was fixed! ๐Ÿ‘
        i found a new problem with the new set, the mirror tool doesn't seem to work, and it crashes sketchup after the second or third click. the first set mirror tool was working fine though.
        btw, i find your tutorials very helpful and very well presented. great work. ๐Ÿ‘
        edit. i forgot to add, the "protrude" in the menu is missing the letter p.
          @matt666 said:
          Hi CadFather !
          Thank you!
          I second this. I like to know what things are before I download and install them.
          • CadFatherC
            CadFather
            there you are folks, updated and imaged (i've done a flipping 23 videos tutorials!) ๐Ÿ˜‰
              stanmarsh
              hi Cadfather,
              something is still wrong with mirror script, it crashes sketchup whenever i use it with 2 to 3 clicks. i only have the scf powertoolbar in the plugins folder, and i still get bugsplat. anybody having the same problem?
              thanks
              • CadFatherC
                CadFather
                did you replace all of the contents?
                  stanmarsh
                  yes, i deleted all the contents of the plugins folder then extracted the scf powertoolbar there. i can click on the mirror toolbar and create the 3 points for the mirror script to work, after clicking the 3 points, i get bugsplat.
                  • free agentF
                    free agent
                    Hi Cad-daddy
                    awsome set again, a comment about the handrails, never used it before but now see its usefullness, wouldnt it be better if the posts are components as the simple rectangle or tube is far too simple for my liking and would be indeed handy if i could just go into one and dump my own baluster??
                    http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                    • CadFatherC
                      CadFather
                      thanks for the feedback everyone!
                      @ Stan - very strange, it works just fine on mine - are you using vista or mac?
                      @ Freeagent, you can - have a look at the tutorials ๐Ÿ˜‰
                        stanmarsh
                        hi Cadfather,
                        im using windows xp sp2 and sketchup 6 & 7 free version, i reinstalled sketchup 7 but the bugsplat persist, i tried it as well on sketchup 6 and it has the same problem. its really weird, maybe my computer has the problem. i will test it on another computer and see if it still happening.
                        edit, i tested it on another machine, using windows xp sp2 sketchup 6, and i get bugsplat too.
                        • CadFatherC
                          CadFather
                          have you still got the original version? does the mirror work?
                          i will try on a fresh xp install
                            stanmarsh
                            hi Cadfather,
                            yes, i still have the first version, i just replace the plugins with the old one and it has the mirror problem also, ๐Ÿ˜ฎ i tested it earlier and its working fine. its really weird, the mover2 which did not work on the first version is working fine. but the drop is still not working and the mirror is now having bugsplat. could be something to do with the mover2 script?
                            • CadFatherC
                              CadFather
                              mm..the behaviour you describe does not surprise me when mixing the different versions (it was just a try)
                              this is what the folder should look like (new version only)
                              i just tried it on a fresh xp install (virtualbox) and it works.. ๐Ÿ˜•
                              check whether your firewall is causing the problem - i had a bug with the copy command in SU7 and online armour 3. downgraded to 2 and it works..
                              • arquitectomaracuchoA
                                arquitectomaracucho
                                wow great tools, true friend you're doing an incredible job. The tool is being mirror problem, can not even play when there is already an accident. Greetings
                                • CadFatherC
                                  CadFather
                                  ..i did say it was beta! ๐Ÿ˜„
                                  will keep looking into it - meantime please post feedback, bugs comments, thanks.
                                    stanmarsh
                                    hi Cadfather,
                                    thank you for the help! everything finally works! i think you can remove the beta now, because everything is perfect. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                    the problem was the mover2.rb inside the plugins folder. its included in the recent zip file so i have problem with bugsplat, but after i removed it following your folder structure, everything is working now.
                                    thanks for the help and for this wonderful toolbar!
                                    • CadFatherC
                                      CadFather
                                      sorry about that Stan - eyes are seeing double! new version updated in first post ๐Ÿ‘
                                        stanmarsh
                                        no trouble, glad we solve the problem.
                                        • EdsonE
                                          Edson
                                          what a present, max! you are very generous. and the videos are something else. i have been using some of those scripts for some time but now i really know more about them. thanks!
                                          edson mahfuz, architect| porto alegre โ€ข brasil
                                          http://www.mahfuz.arq.br
                                          • CadFatherC
                                            CadFather
                                            Thank you Edson - it's good to be able to give something back! ๐Ÿ˜„
                                            • 1 / 4
