    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 84.6k Views 36 Watching
      stanmarsh
      hi Cadfather,
      just tested the new one, the first two problems i have earlier was fixed! ๐Ÿ‘
      i found a new problem with the new set, the mirror tool doesn't seem to work, and it crashes sketchup after the second or third click. the first set mirror tool was working fine though.
      btw, i find your tutorials very helpful and very well presented. great work. ๐Ÿ‘
      edit. i forgot to add, the "protrude" in the menu is missing the letter p.
        @matt666 said:
        Hi CadFather !
        It would be great to have an image of your toolbar, with all tools explained!
        Thank you!
        I second this. I like to know what things are before I download and install them.
        • CadFatherC Offline
          CadFather
          there you are folks, updated and imaged (i've done a flipping 23 videos tutorials!) ๐Ÿ˜‰
            stanmarsh
            hi Cadfather,
            something is still wrong with mirror script, it crashes sketchup whenever i use it with 2 to 3 clicks. i only have the scf powertoolbar in the plugins folder, and i still get bugsplat. anybody having the same problem?
            thanks
              CadFather
              did you replace all of the contents?
                stanmarsh
                yes, i deleted all the contents of the plugins folder then extracted the scf powertoolbar there. i can click on the mirror toolbar and create the 3 points for the mirror script to work, after clicking the 3 points, i get bugsplat.
                • free agentF Offline
                  free agent
                  Hi Cad-daddy
                  awsome set again, a comment about the handrails, never used it before but now see its usefullness, wouldnt it be better if the posts are components as the simple rectangle or tube is far too simple for my liking and would be indeed handy if i could just go into one and dump my own baluster??
                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                    CadFather
                    thanks for the feedback everyone!
                    @ Stan - very strange, it works just fine on mine - are you using vista or mac?
                    @ Freeagent, you can - have a look at the tutorials ๐Ÿ˜‰
                      stanmarsh
                      hi Cadfather,
                      im using windows xp sp2 and sketchup 6 & 7 free version, i reinstalled sketchup 7 but the bugsplat persist, i tried it as well on sketchup 6 and it has the same problem. its really weird, maybe my computer has the problem. i will test it on another computer and see if it still happening.
                      edit, i tested it on another machine, using windows xp sp2 sketchup 6, and i get bugsplat too.
                        CadFather
                        have you still got the original version? does the mirror work?
                        i will try on a fresh xp install
                          stanmarsh
                          hi Cadfather,
                          yes, i still have the first version, i just replace the plugins with the old one and it has the mirror problem also, ๐Ÿ˜ฎ i tested it earlier and its working fine. its really weird, the mover2 which did not work on the first version is working fine. but the drop is still not working and the mirror is now having bugsplat. could be something to do with the mover2 script?
                            CadFather
                            mm..the behaviour you describe does not surprise me when mixing the different versions (it was just a try)
                            this is what the folder should look like (new version only)
                            i just tried it on a fresh xp install (virtualbox) and it works.. ๐Ÿ˜•
                            check whether your firewall is causing the problem - i had a bug with the copy command in SU7 and online armour 3. downgraded to 2 and it works..
                            • arquitectomaracuchoA Offline
                              arquitectomaracucho
                              wow great tools, true friend you're doing an incredible job. The tool is being mirror problem, can not even play when there is already an accident. Greetings
                                CadFather
                                ..i did say it was beta! ๐Ÿ˜„
                                will keep looking into it - meantime please post feedback, bugs comments, thanks.
                                  stanmarsh
                                  hi Cadfather,
                                  thank you for the help! everything finally works! i think you can remove the beta now, because everything is perfect. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                  the problem was the mover2.rb inside the plugins folder. its included in the recent zip file so i have problem with bugsplat, but after i removed it following your folder structure, everything is working now.
                                  thanks for the help and for this wonderful toolbar!
                                    CadFather
                                    sorry about that Stan - eyes are seeing double! new version updated in first post ๐Ÿ‘
                                      stanmarsh
                                      no trouble, glad we solve the problem.
                                      • EdsonE Offline
                                        Edson
                                        what a present, max! you are very generous. and the videos are something else. i have been using some of those scripts for some time but now i really know more about them. thanks!
                                        edson mahfuz, architect| porto alegre โ€ข brasil
                                        http://www.mahfuz.arq.br
                                          CadFather
                                          Thank you Edson - it's good to be able to give something back! ๐Ÿ˜„
                                            free agent
                                            is that bevel tool the same as sketchy bevel? is it a new version?
                                            • 1 / 4
