    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 63.6k Views 44 Watching
    • Al HartA Offline
      Al Hart
      We found a way to have SketchUp wait for the tree maker without using up 1/4, 1/2 or almost all of you processing power.
      Look for a new version Monday.
      Al Hart
      IRender nXt from Render Plus
        matthew.robert
        Anyone else getting the error...
        Error Loading File RpTreeMaker_loader.rb
        126; The specified module could not be found.   - C;/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so
        after installing the tree maker with the "Click here to install RpTreeMaker 2_HK24tm.exe" file and starting up SketchUp?
        Any thoughts?
          Jorgensen
          I can't figure out how to make it work with VRAY 😞
          Does it export a aplha channel ?
            Jorgensen
            Ah. I found a solution.
            • Al HartA Offline
              Al Hart
              @tobobo said:
              Al,
              Could you add in standard tree shapes as defaults?
              One of the reasons we released RpTreeMaker as a free product is that we are hoping some SketchUp users will help us create some standard trees and save them on the 3D warehouse to share with other users.
              The definition for each tree can be accessed as a .ArPlant file, and then used as the starting point for changes, or for other trees.
              This doesn't work yet because:
              1. If you use custom leaves or bark, we need to save them in the .SKP file as well. (We plan to do this, but haven;t done it yet). That way the .SKP file for a tree will have everything it needs to recreate the tree, or save similar trees.
              2. We need to write a function to save the .ArPlant file, which defines a tree, from the .SKP file.
              We will get to these things soon. Currently we are trying to get the new version released which allows rotation of the trees and higher resolutions. We should have a new version in the next day or so,
              Also, we are working on a shadow mask for the tree which will make useful shadows in SketchUp, and work better with renderers like Podium and Vray. (The IRender rendering engine already re-processes the trees creating new fractal trees during the rendering process).
              Al Hart
              • Al HartA Offline
                Al Hart
                Any thoughts?
                C:/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so should have been installed as part of RpTreeMaker.
                1. Is SketchUp installed on your machine in: C:\Program Files\Google\Google SketchUp 7
                2. Did SketchUp put RpTreeMaker_loader.rb into C:\Program Files\Google\Google SketchUp 7\plugins or did you copy it there by hand?
                3. Uninstall RpTreeMaker, and reinstall it being careful to select the proper location for SketchUp.
                4. After reinstalling it verify that RpTreeMaker_loader.rb and Win32API.so are located in the SketchUp plugins folder.
                Al Hart
                  matthew.robert
                  Hi Al, tried all those with no luck. For 2, I did not do any manual copying. My SketchUp Pro install is about as clean as it can get BUT I am running it on XP SP3 with Parallels ver. 4 (as a non-bootcamp VM). I have Vista installed via Bootcamp, I will give that a shot.
                  I will attach the files that got installed in my plugins folder. They are either encrypted, corrupt, or both (maybe?). Should a separate treeeditor.exe file be installed somewhere, I am not seeing that.
                  Matt
                  files.zip
                    matthew.robert
                    I must be missing some important step... I had the exact same issue on my Bootcamp Vista partition, which for all practical purposes is a different os its own partitioned HD space.
                    If someone were to send me the necessary files, could I just move them into place manually?
                    Matt
                    • Al HartA Offline
                      Al Hart
                      Matt
                      1. Try typing these two lines into the Ruby Console:
                      require 'Win32API'
                      RegCloseKey = Win32API.new('advapi32', 'RegCloseKey', 'L', 'L')
                      (copy and paste them into the ruby console)
                      1. Are you running on a Mac?
                      Al Hart
                        matthew.robert
                        Ok, tried that. I had to do each line separately, would've that made a difference? Attached is a screen shot of the results.
                        Yup on running a Mac. I have XP running as a VM and Vista that I occasionally boot into natively. Think that might be causing the issues? Its a unibody MBP.
                        Matt
                        • Al HartA Offline
                          Al Hart
                          Matt
                          Hmm.
                          After "require Win32API",
                          if you type in just:
                          Win32API on a Windows machine, it responds with something.
                          Win32API
                              Win32API
                          Win32API.class
                              Class
                          Win32API.id
                              95261808
                          We'll have to see if there is a version of Win32API.so which works on the Mac partition.
                          Try running the two executables (.exe) in C:\Program Files\Render Plus Systems\RpTreeMaker (or it s equivalent). TreeEditor.exe and RpTreeMaker.exe. (If they don't run then we have a long way to go to get this to work.
                          If Win32API is the only problem, we may be able to work around it.
                          Al Hart
                          • Al HartA Offline
                            Al Hart
                            One of the perks I saw was RP Trees, however I found out it creates 2.5D trees, not true 3D trees so it doesn't really fit my needs (Im a landscape designer).
                            For now I am sticking with Kerkythea, I am quite happy with it, however in the future I may check out your pdf tool-I can see that being useful to me.
                            When you make trees with RpTreeMaker, they create 2D trees in SketchUp, but when you render the model with IRender, the 2D tree is re-rendered as a 3D fractal tree. (They aren't "true" 3d because we use a 2D leaf and rotate it around) However, we do get very good results.
                            This is a RpTreeMaker tree rendered with IRender. Note the subtle shadows from the sky on the ground.
                            http://wiki.renderplus.com/images/f/fb/Tree-w-IRender.jpg
                            Al Hart
                              matthew.robert
                              That worked for both my XP VM and Vista BC install. The RpTreeMaker app seemed to run as expected. Must have something to do with running on the Mac hardware?
                              Matt
                                L. Banasky
                                This solved my problem with Vista32, SU7, Win32API.so, and certain plugins.
                                Re: Some plugins don't work SU 7. Organizer.rb at fault?
                                by L. Banasky on Thu Dec 11, 2008 6:06 am
                                CadalogBeamTool.rb is now working. I did a side by side comparison of the files in the main program folder of SU6 and SU7, and moved the missing files from SU6 to SU7 one by one. The file that is required by SU7 that is missing is msvcr71.dll. I tried to enclose the file, but .dll's are not allowed.
                                Thanks again for all your help,
                                Larry
                                • Al HartA Offline
                                  Al Hart
                                  There is a new version 0 see New Version.
                                  I started a new thread for it. I'm not sure why???
                                  Al Hart
                                  • F Offline
                                    firestrike
                                    Hi, this could be a really stupid question, but where are the tree images saved?. I originally found them here
                                    : C:\Users\chris\appdata\Local\Temp\RPS_TreeMaker_Images
                                    but now it doesnt seem to be saving any new tree images their.
                                    thanks for your help and thanks for a great program.
                                    • Al HartA Offline
                                      Al Hart
                                      After placing the tree in SketchUp, load the SketchUp Materials Window, select 'In Model', select the image of the tree, and then select the 'Browse' button to the right of the tree name. It will start browsing in the same folder as the image.
                                      The images to not stay there long. However, to the right of the browse button (in SU 7) there is an "Edit Image" button which will load the image from the material itself into an editor - and then you can save the image somewhere.
                                      Al Hart
                                      • 6 Offline
                                        6284732
                                        oh i can not understand
                                        • Al HartA Offline
                                          Al Hart
                                          After creating a tree and placing it in SketchUp, click Window/Materials.
                                          When the SketchUp Material Window comes up;
                                          • select the "In Model" icon
                                          • select the material for the tree, and
                                          • select the Edit tab
                                          From the Edit tab:
                                          Select the "Edit texture in an external editor" icon, which will load a photo or image editor program.
                                          In the image editor, go to File/Save As.
                                          In the Save As dialog, use the drop down to the right of the folder name to get the complete path of the folder.
                                          Al Hart
                                            AcesHigh
                                            Al, do you think its possible to create Paraná Pines (a type of Araucaria tree that is very common in my area) in RPTreeMaker?
                                            http://bp3.blogger.com/_O_hPd8k6LR8/SGRNVWLcQwI/AAAAAAAAAUE/Inz_iEW0ynY/s320/300px-Pinheiros2.jpg
                                            http://farm1.static.flickr.com/120/368871093_b8bb64e677.jpg
                                            http://image59.webshots.com/159/5/5/59/2467505590073484453RAYfki_fs.jpg
                                            http://lh5.ggpht.com/_cFWifFMbEJA/Rn7Kk2w7m7I/AAAAAAAACAQ/I_dbhCSox_U/s640/Dsc01430.jpg
                                            • 7 / 8
