    Windowizer4 now available!
    55 Posts 12 Posters 17.6k Views 12 Watching
      RickW
      No, that was some strange anomaly in the old .zip file, and was unnecessary. You should have the following files in the Plugins folder:
      array_to.rb
      arraysum.rb
      getMaterials.rb
      offset.rb
      windowizer4.rb
      windowizer4stylemanager.rb
      windowizer4-en-US.html
      The first 4 are "library" files that are used by other scripts. The last 3 are unique to Windowizer4. You should also have a subfolder called "windowizer4languages" in your Plugins folder. The localized .html files go in here, and you can safely delete all but your language's .html file.
      Does anything appear in the Ruby Console when you click "Apply"?
      RickW
      www.smustard.com
        RickW
        The sketchup.rb file should be in the Tools folder, not the Plugins folder.
        RickW
        www.smustard.com
        • GaieusG
          BTW - where do I get sketchup.rb? I don't seem to have it at all! 😲
          Me stupid agan. It's in the Tools folder by default.
          Now copied to the Plugins folder but still no avail.
            RickW
            It should stay in the Tools folder. Any messages in the Ruby Console?
            RickW
            www.smustard.com
              seasdes
              Hooray thank you so much for this plugin Rick. So far it works as expected. It even cuts both sides of a wall.
              Trully amazing.
              Walter
              Using Sketchup Pro 2019
              • GaieusG
                I left a copy there...
                Nope.
                • GaieusG
                  Okay, I have figured it out.
                  On my "European" keyboard layout the decimal separator is comma. All the sizes appear with commas except the max wall thicknes which is separated bz a dot (period / full stop - call it as you wish) by default in the webdialog. If I manually change that to a comma, the script works.
                  I guess this will be an issue with other localisations, too.
                  Now I will get into the translation at last.
                    RickW
                    Gai,
                    Glad you figured that out. I'll have to make some notes for using it and humbly ask the great volunteers who helped with the dialog to help once again with translating the documents.
                    Thanks,
                    RickW
                    www.smustard.com
                    • T
                      thinkbuild
                      Dear Rick -
                      I haven't downloaded W4 yet (but I will soon) and I was just thinking - I've got a small project in Sweden, and there, we have triple-glazed windows. Do you think it would be possible to add an option, "# of panes of glass"? In Germany, we also use double-glazing and so on...I was thinking, I could perhaps just make a "thick" single pane but there might be situations in which it would be useful to model the "real" situation...
                      I imagine it might at some point get a bit much, but since you are already working at such a high level of detail...
                      Just a thought.
                      best wishes,
                      Jason
                      • david_hD
                        david_h
                        RICK. I just purchased and am using it. It is awesome. Anyway to put it in a context menu rather than the pull down?
                        It's much more friendlier that way> . . . 💚
                        • C
                          cheffey
                          I just purchased it as well, and that's my only request is to add to a right-click dialog as David mentions.
                          Works flawless though, going to be such a time saver.
                          BROS RŌMAN BRÄUN
                          • C
                            chango70
                            Rick I can't get it to work for some reason. I've unzipped everything into the plugins folder. When I use the Windowizer4 dialogue it creates a single group. Am I doing something wrong?
                            • utilerU
                              utiler
                              Thanks so much Rick, bought it and loving it!!!
                              A few questions:
                              1. Great to see it cuts both faces; when deleting a window, the hole still remains. Is this normal? I just assumes that the whole window would act like a component but it appears that the opening is separate from the window [if grouped]...
                              2. When extracting Windowizer4, i over-road a few rubies, I assume were part of windowizer30b5. Which files do I delete from the plugins folder that are only associated with windowizer30b5? I want to get rid of what i don't need...
                              3. Color selection - there is 7 options for coloring both the frame and glass, is there a way to access the materials palette?
                              Way 😎
                              Just Curious...
                                RickW
                                Sounds like I need to put a right-click menu item in place... 😄
                                No problem - I'll add it to my list.
                                RickW
                                www.smustard.com
                                  RickW
                                  For metric, you need a dot between the number and the units, i.e. 50.mm
                                  Hope that helps.
                                  EDIT: I looked again at the image you posted. My first answer is still correct, but I see something I need to try to fix for default metric users: the default settings are 2" and 4", which are being converted to '~51mm' and '~102mm' without the dot, so that's my problem to fix. But, at least there's an easy workaround - make sure there's a dot. 😉
                                  Thanks for making me aware of that issue.
                                  RickW
                                  www.smustard.com
                                    RickW
                                    @thinkbuild said:
                                    Dear Rick -
                                    Just a thought.
                                    best wishes,
                                    Jason
                                    I could add that if there's enough interest. We use double-glazed windows here, too. I just arbitrarily decided (for the sake of lower poly counts, primarily) that only the outside faces of the glass would be modeled, so I use 1" thick glass (which in reality would be two panes of 1/4" glass with a 1/2" airspace) for my models. The only other option right now is zero-thickness glass, which will draw a single face only. But, like I said, if there's enough interest, I could add it.
                                    RickW
                                    www.smustard.com
                                      RickW
                                      Any suggestions for the Visual Reference PDF?
                                      I wanted everything to be clear and easily cross-referenced, but it's possible I missed something. Is there anything that is not explained well enough?
                                      Also, if there's any feedback on the new Window Styles feature, I'd be glad to hear it. I'm still developing the Styles Manager (including rename/delete/import/export), so if you have any suggestions, now is the time. 😄
                                      Thanks, everyone!
                                      RickW
                                      www.smustard.com
                                      • utilerU
                                        utiler
                                        There is one thing I thought about to do with the dialogue box, Rick....
                                        You have a 'mullion width' and 'mullion height' input. I worked out that one is for horizontal and the other is for vertical sizes. I thought is would be easier to differentiate Mullions from Transom; as they are know in building terms. It would also mean changing the input mode as well for 'Vertical panels' and 'Horizontal panels' to say 'number of mullions' and 'number of transoms" but maybe you have travelled to far down the road with the script to go back and change this..... just a thought, would make it easier to understand.
                                        Just Curious...
                                          RickW
                                          I could change "vertical panes" and "horizontal panes" back to "rows" and "columns", which is the terminology I used previously. Changing mullion height to transom height isn't a big deal as it only affects the dialog and the documentation. Thanks for the comments.
                                          RickW
                                          www.smustard.com
                                          • utilerU
                                            utiler
                                            Cheers Rick.
                                            BTW, any plans for a doorizer? would be real handy to keep it 'in house'..... 👍
                                            Just Curious...
                                            • 1 / 3
