    Windowizer4 now available!
    55 Posts 12 Posters 17.6k Views 12 Watching
    • GaieusG
      Hi Rick,
      I have unzipped everything simply to the Plugins folder (or should I have installed it differently?). After opening SU, I found windowizer 4 in the plugin menu and tried to run but the webdialog says "The page cannot be displayed" (practically a 404 eror). When I right click and go to Properties, I see the below URL
      res;//C;\WINDOWS\System32\shdoclc.dll/dnserror.htm#file;//C;\Program%20Files\Google\Google%20SketchUp%206\Plugins\windowizer4-en-US.html
      Also see my screenshot (the webdialog and the propertie panel in Hungarian).
      BTW - how am I supposed to select my language?
      Sorry for being a pain with this...
        RickW
        When you unzipped the files, did you retain folder names? All the .html files (except windowizer4-en-US.html) should be in a subfolder called "windowizer4languages".
        After verifying that, close the dialog, open the Ruby Console, then select Plugins>Windowizer4 from the menu. If there are any errors in the Ruby Console, please copy & paste them in a message to me (either here or in email).
        Windowizer should automatically select the proper dialog language file based on the Sketchup localization. It works in theory (and it works for selecting US English), but I can't test it on other localizations. If you continue to have problems after verifying all the files are located correctly, let me know and I'll see if some international ruby gurus (Didier? TBD?) can help solve the problem.
        RickW
        www.smustard.com
        • GaieusG
          I haven't changed anything in the folder and name structure. Note however that I don't have windowizer4-en-US.html anywhere; neither in the main plugins folder nor in the subfolder.
          I tried it with the ruby console but nothing appears in there.
          I removed all other scripts but still no avail.
          • GaieusG
            Okay, I think the mising file was the culprit. I copied the Hungarian html file to the main Plugins folder, renamed it to ...en-US.html and the window pops up just fine. (in Hungarian). I'll start testing my translation immediately.
            Thanks Rick! 👍
              RickW
              Somehow, the windowizer4-en-US.html file was omitted from the .zip download. I've uploaded a new .zip file with the missing file included. Try re-downloading and let me know what you get.
              Thanks,
              RickW
              www.smustard.com
              • GaieusG
                Downloading...
                In the previous zip file there was a "Program files" folder as well. It is missing from this one; is it not needed? There were deeply nested subfolders in it but eventually all empty).
                OK, downloaded but it's not working.
                The window appears but whatever I do (trying to apply the default settings) and press "Apply" (still testing with the US version) nothing happens.
                • GaieusG
                  Wait. Me stupid. I looked at the script and it says requires sketchup.rb and I don't have it in the folder at the moment. 😳
                    RickW
                    No, that was some strange anomaly in the old .zip file, and was unnecessary. You should have the following files in the Plugins folder:
                    array_to.rb
                    arraysum.rb
                    getMaterials.rb
                    offset.rb
                    windowizer4.rb
                    windowizer4stylemanager.rb
                    The first 4 are "library" files that are used by other scripts. The last 3 are unique to Windowizer4. You should also have a subfolder called "windowizer4languages" in your Plugins folder. The localized .html files go in here, and you can safely delete all but your language's .html file.
                    Does anything appear in the Ruby Console when you click "Apply"?
                    RickW
                    www.smustard.com
                      RickW
                      The sketchup.rb file should be in the Tools folder, not the Plugins folder.
                      RickW
                      www.smustard.com
                      • GaieusG
                        BTW - where do I get sketchup.rb? I don't seem to have it at all! 😲
                        Me stupid agan. It's in the Tools folder by default.
                        Now copied to the Plugins folder but still no avail.
                          RickW
                          It should stay in the Tools folder. Any messages in the Ruby Console?
                          RickW
                          www.smustard.com
                            seasdes
                            Hooray thank you so much for this plugin Rick. So far it works as expected. It even cuts both sides of a wall.
                            Trully amazing.
                            Walter
                            Using Sketchup Pro 2019
                            • GaieusG
                              I left a copy there...
                              Nope.
                              • GaieusG
                                Okay, I have figured it out.
                                On my "European" keyboard layout the decimal separator is comma. All the sizes appear with commas except the max wall thicknes which is separated bz a dot (period / full stop - call it as you wish) by default in the webdialog. If I manually change that to a comma, the script works.
                                I guess this will be an issue with other localisations, too.
                                Now I will get into the translation at last.
                                  RickW
                                  Gai,
                                  Glad you figured that out. I'll have to make some notes for using it and humbly ask the great volunteers who helped with the dialog to help once again with translating the documents.
                                  Thanks,
                                  RickW
                                  www.smustard.com
                                  • T
                                    thinkbuild
                                    Dear Rick -
                                    I haven't downloaded W4 yet (but I will soon) and I was just thinking - I've got a small project in Sweden, and there, we have triple-glazed windows. Do you think it would be possible to add an option, "# of panes of glass"? In Germany, we also use double-glazing and so on...I was thinking, I could perhaps just make a "thick" single pane but there might be situations in which it would be useful to model the "real" situation...
                                    I imagine it might at some point get a bit much, but since you are already working at such a high level of detail...
                                    Just a thought.
                                    best wishes,
                                    Jason
                                    • david_hD
                                      david_h
                                      RICK. I just purchased and am using it. It is awesome. Anyway to put it in a context menu rather than the pull down?
                                      It's much more friendlier that way> . . . 💚
                                      • C
                                        cheffey
                                        I just purchased it as well, and that's my only request is to add to a right-click dialog as David mentions.
                                        Works flawless though, going to be such a time saver.
                                        BROS RŌMAN BRÄUN
                                        • C
                                          chango70
                                          Rick I can't get it to work for some reason. I've unzipped everything into the plugins folder. When I use the Windowizer4 dialogue it creates a single group. Am I doing something wrong?
                                          • utilerU
                                            utiler
                                            Thanks so much Rick, bought it and loving it!!!
                                            A few questions:
                                            1. Great to see it cuts both faces; when deleting a window, the hole still remains. Is this normal? I just assumes that the whole window would act like a component but it appears that the opening is separate from the window [if grouped]...
                                            2. When extracting Windowizer4, i over-road a few rubies, I assume were part of windowizer30b5. Which files do I delete from the plugins folder that are only associated with windowizer30b5? I want to get rid of what i don't need...
                                            3. Color selection - there is 7 options for coloring both the frame and glass, is there a way to access the materials palette?
                                            Way 😎
                                            Just Curious...
                                            • 1 / 3
