    Windowizer4 now available!
    55 Posts 12 Posters 16.2k Views 12 Watching
      Okay, I think the mising file was the culprit. I copied the Hungarian html file to the main Plugins folder, renamed it to ...en-US.html and the window pops up just fine. (in Hungarian). I'll start testing my translation immediately.
      Thanks Rick! 👍
        RickW
        Somehow, the windowizer4-en-US.html file was omitted from the .zip download. I've uploaded a new .zip file with the missing file included. Try re-downloading and let me know what you get.
        Thanks,
        RickW
        www.smustard.com
          Downloading...
          In the previous zip file there was a "Program files" folder as well. It is missing from this one; is it not needed? There were deeply nested subfolders in it but eventually all empty).
          OK, downloaded but it's not working.
          The window appears but whatever I do (trying to apply the default settings) and press "Apply" (still testing with the US version) nothing happens.
            Wait. Me stupid. I looked at the script and it says requires sketchup.rb and I don't have it in the folder at the moment. 😳
              RickW
              No, that was some strange anomaly in the old .zip file, and was unnecessary. You should have the following files in the Plugins folder:
              array_to.rb
              arraysum.rb
              getMaterials.rb
              offset.rb
              windowizer4.rb
              windowizer4stylemanager.rb
              The first 4 are "library" files that are used by other scripts. The last 3 are unique to Windowizer4. You should also have a subfolder called "windowizer4languages" in your Plugins folder. The localized .html files go in here, and you can safely delete all but your language's .html file.
              Does anything appear in the Ruby Console when you click "Apply"?
              RickW
              www.smustard.com
                RickW
                The sketchup.rb file should be in the Tools folder, not the Plugins folder.
                RickW
                www.smustard.com
                  BTW - where do I get sketchup.rb? I don't seem to have it at all! 😲
                  Me stupid agan. It's in the Tools folder by default.
                  Now copied to the Plugins folder but still no avail.
                    RickW
                    It should stay in the Tools folder. Any messages in the Ruby Console?
                    RickW
                    www.smustard.com
                      seasdes
                      Hooray thank you so much for this plugin Rick. So far it works as expected. It even cuts both sides of a wall.
                      Trully amazing.
                      Walter
                      Using Sketchup Pro 2019
                        I left a copy there...
                        Nope.
                          Okay, I have figured it out.
                          On my "European" keyboard layout the decimal separator is comma. All the sizes appear with commas except the max wall thicknes which is separated bz a dot (period / full stop - call it as you wish) by default in the webdialog. If I manually change that to a comma, the script works.
                          I guess this will be an issue with other localisations, too.
                          Now I will get into the translation at last.
                            RickW
                            Gai,
                            Glad you figured that out. I'll have to make some notes for using it and humbly ask the great volunteers who helped with the dialog to help once again with translating the documents.
                            Thanks,
                            RickW
                            www.smustard.com
                              thinkbuild
                              Dear Rick -
                              I haven't downloaded W4 yet (but I will soon) and I was just thinking - I've got a small project in Sweden, and there, we have triple-glazed windows. Do you think it would be possible to add an option, "# of panes of glass"? In Germany, we also use double-glazing and so on...I was thinking, I could perhaps just make a "thick" single pane but there might be situations in which it would be useful to model the "real" situation...
                              I imagine it might at some point get a bit much, but since you are already working at such a high level of detail...
                              Just a thought.
                              best wishes,
                              Jason
                              • david_hD Offline
                                david_h
                                RICK. I just purchased and am using it. It is awesome. Anyway to put it in a context menu rather than the pull down?
                                It's much more friendlier that way> . . . 💚
                                  cheffey
                                  I just purchased it as well, and that's my only request is to add to a right-click dialog as David mentions.
                                  Works flawless though, going to be such a time saver.
                                  BROS RŌMAN BRÄUN
                                    chango70
                                    Rick I can't get it to work for some reason. I've unzipped everything into the plugins folder. When I use the Windowizer4 dialogue it creates a single group. Am I doing something wrong?
                                    • utilerU Offline
                                      utiler
                                      Thanks so much Rick, bought it and loving it!!!
                                      A few questions:
                                      1. Great to see it cuts both faces; when deleting a window, the hole still remains. Is this normal? I just assumes that the whole window would act like a component but it appears that the opening is separate from the window [if grouped]...
                                      2. When extracting Windowizer4, i over-road a few rubies, I assume were part of windowizer30b5. Which files do I delete from the plugins folder that are only associated with windowizer30b5? I want to get rid of what i don't need...
                                      3. Color selection - there is 7 options for coloring both the frame and glass, is there a way to access the materials palette?
                                      Way 😎
                                      Just Curious...
                                        RickW
                                        Sounds like I need to put a right-click menu item in place... 😄
                                        No problem - I'll add it to my list.
                                        RickW
                                        www.smustard.com
                                          RickW
                                          For metric, you need a dot between the number and the units, i.e. 50.mm
                                          Hope that helps.
                                          EDIT: I looked again at the image you posted. My first answer is still correct, but I see something I need to try to fix for default metric users: the default settings are 2" and 4", which are being converted to '~51mm' and '~102mm' without the dot, so that's my problem to fix. But, at least there's an easy workaround - make sure there's a dot. 😉
                                          Thanks for making me aware of that issue.
                                          RickW
                                          www.smustard.com
                                            RickW
                                            @thinkbuild said:
                                            Dear Rick -
                                            Just a thought.
                                            best wishes,
                                            Jason
                                            I could add that if there's enough interest. We use double-glazed windows here, too. I just arbitrarily decided (for the sake of lower poly counts, primarily) that only the outside faces of the glass would be modeled, so I use 1" thick glass (which in reality would be two panes of 1/4" glass with a 1/2" airspace) for my models. The only other option right now is zero-thickness glass, which will draw a single face only. But, like I said, if there's enough interest, I could add it.
                                            RickW
                                            www.smustard.com
                                            • 1 / 3
