    Hardware recommendations
    409 Posts 97 Posters 163.4k Views 97 Watching
    • soloS Offline
      rparsons,
      Firstly welcome to GSCF.
      Your rig as noted above is a great choice I do not see you having any problems with it.
        remus
        As solo said, that rig sounds like it should be pretty solid. Get a good motherboard to go with it and you should have a good setup which should be good for some expansion, as well, if you ever feel the need.
          rparsons
          Thanks Solo for your quick response. I feel more confident now about my decision. Any input from others would be also be appreciated.
          Ron
            sadz
            Dear all,
            I have only been using SU for a couple of months now but I have upgraded to working on a desktop as aposed to my laptop which was struggling.
            I went for a triple core processor with 4GB RAM and an NVidia GForce 9600. However it was still not giving me the result I had hoped for. When orbiting the model, many of the components were still being shown as a boundary box and the animation was jerky and sluggish.
            So I upgraded the graphics card to an NVidia Quadro 1700. Surely this would do the trick.
            Afraid not. What I thought was a hardware issue may well be human error. The model I am working on at the moment is 28.9MB. I feel the answer may lie with layers? Am I right? Any tips?
              rparsons
              Thanks Remus and so I am not repeating myself I want to say thanks in advance to all who choose to respond to my earlier post. This forum is fantastic!
              Ron
                remus
                Sadz, the first thing to check is whether you have hardware acceleration on.
                window->preferences->openGL and then turn on hardware acceleration and fast feedback.
                If that doesnt work, how many faces are there in your model? this is the main thing that slows down a model in SU.
                  chango70
                  Has anyone had experience with SU on some of the GTX 200 class NVidia chips? like the GTX 260 and the GTC 280? I still haven't bought that desktop yet as I am waiting for the new i7Core to come out. Just read somewhere that the slowest one on release will be marginally slower that then QX9775 Extreme edition CPU ๐Ÿ˜ฎ, in benchmarks anyway. I can't wait.
                    bubbalove
                    Does anyone have an idea what causes this? I updated my video driver so I could get the antialias feature to work but not I get these little white spots when I zoom in on the model and they flash when I rotate it... any help is greatly appreciated!
                    "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                      scloud
                      My company set me up with a Intel E6750 (2.66 GHz) dual-core, 2 GB RAM, 64-bit Vista, and a powerful 1GB video card (ATI FireGL V7350). However, after importing a site grading file, it was really sluggish. So I worked on my laptop (not nearly the powerhouse of my work pc) to get the file to where I wanted it, finishing up at 47MB. When trying to edit on my work desktop, orbiting posed no problems, but drawing was very sluggish and caused my pc to freeze on a number of occasions. I think that if my card would not try and render absolutely everything (must be cocky with it's 1GB capacity) and I could tune down the graphics specific to sketchup, I would have no problems. I've already configured Vista to minimize what the OS requires, though I don't see a way to configure my card's settings for specific applications. Any thoughts?
                        mirjman
                        bub-
                        I have the same video card and recently updated the drivers like you. I ended up with all sorts of strange flickering and other effects when i used any of the style settings etc. I ended up rolling back the driver just so I could use SU. annoying
                        • AnssiA Offline
                          Anssi
                          BubbaLove,
                          It is most probably a display driver issue. Things you can try:
                          • check that the card driver settings are set to the SU-recommended values (most important is Antialiasing, it should be set to "Application-controlled")
                          • turn off "Fast Feedback" in the SU OpenGL settings
                          • turn off "Use HArdware Acceleration" in the SU OpenGL settings to verify that your problem is display-driver related (this will slow down SU for all but the smallest models, so it is not a permanent solution)
                          • try to download and install a newer (or different) version of the display driver
                          • buy a Nvidia-based card instead
                          Anssi
                            bubbalove
                            Thanks guys, I was afraid that it might be the video card... just was hoping that it was something stupid I did. Anssi... this isn't the computer I usually do my modeling, I will be doing all my renders on this one but I just wanted to text if antialias worked cause this computer used to have Vista on and it didnt work at all! We put XP on it and Sketchup runs fine but just with those white spots... I can deal with it! Mirjman, I didn't realize this when I bout this damned computer from Dell... I've learned my lesson, I won't be jumping into a new OS like Vista anymore!
                            • H Offline
                              herodes
                              Its an ATI thing. I saw this happening in a number of occasions on a number of systems.
                              Either ATI isn't doing proper OpenGL implementation either the Sketchup Core (the rendering part) is not handling the OpenGL extensions in a nice way in order to achieve the "100%-same-output-on-all-graphics-cards" principle of usability and software quality.
                              %(#BFBFBF)[http://arhitektonas.blogspot.com
                              I know me,... I am that guy...
                                BTM
                                My computer (mac) runs anti-aliasing, but it can only be turned on/off. Anyone know Why?
                                • soloS Offline
                                  Herodes, I think it's on ATI's side as I see the same complaints on other 3D app forums.
                                    rcossoli
                                    Hello everyone, I wanted to know if now that I will change my computer equipment should buy, the idea is to buy a Phenomx4 9600 with 4 GB of RAM and a video card GForce 512 or 1 gb memory. I have an Athlon 64x2 4800 with 2 GB of RAM and a video card GForce 7200 256.
                                    is nothing more than to be used with SketchUp, and kerkythea, of course it also by other programs such as Vue, AutoCAD, PhotoShop, 3dMax and the like.
                                    believe that this team well with the official SketchUp or have any particular recommendation?
                                    greetings
                                    THREEDIMENSIONSWEB dot COM
                                      Charlie__V
                                      From what I have read:
                                      Intel i7 is a smart chipset, that will devote all of its power to one application...should that application demand it, providing it is the only [demanding] application running[otherwise it shares].
                                      Would this be an accurate assesment of the i7?
                                      Would this lessen the importance of GSU 7 & other apps to be multi core compatible?
                                      Thanks,
                                      Hardware Greenhorn,
                                      C
                                        remus
                                        Charlie, i think that is largely correct, although i dont think it can increase the clock speed on a single core enough to make a huge difference to SUs speed.
                                        • sk.lionS Offline
                                          sk.lion
                                          Hey Guys, i'm looking for a new computer this week, since my old one is getting well... old. So i think it was about time for an upgrade, after all my existing computer only has 60GB HD lol. There is only one problem... i only want to be spending less than $1000 on it for now, with hopes of upgrade to a better one by the end of the year, or perhaps sooner. Regardless, some suggestions would be nice.
                                          Thanks,
                                          -Darcy Cardinal
                                            j3nsen
                                            @chango70 said:
                                            I believe that now the i7 Cores are released there is no reason other than cost to go AMD anymore. The benchmarks are amazing! The slowest i7 Core 920 is faster than the fastest last generation Quad (the QX9775)which is incredable! Plus they apparent can overclock relatively easily according to Tom's Hardware (http://www.tomshardware.co.uk/). It was worth the wait. Now I am going to specify a system with the following hardware:
                                            Intel Core i7-920 2.66Ghz
                                            6Gb DDR3 Ram
                                            WD velociRaptor 10000Rpm HD
                                            Samsung 1TB Spinpoint 7200rpm HD
                                            Asus P6T Desluxe Intel X58 Motherboard
                                            Quadro FX 1700 Graphics Card
                                            That should do the trick ๐Ÿ˜„ for modelling and rendering
                                            Any improvement welcome.
                                            WOAOW!!! ๐Ÿ˜ฎ
                                            • 11
                                            • 20
                                            • 21
                                            • 9 / 21
