    Unfold tool for SU models
    extensions
    18 Posts 9 Posters 7.8k Views 9 Watching
      kwistenbiebel
      I am thinking the same thing 😄
      • TIGT Online
        How soon you all forgot Jim's Unfold script... http://sketchuptips.blogspot.com/2007/08/plugin-unfoldrb.html
          I've never forgotten it (what's more, when wabe came in, the first thing I remembere was Jim's script).
          Jim also tested waybe and contributed quite valuably as I remember.
          • ton baetenT Offline
            ton baeten
            Well, my first thought about 'Waybe' was alike Tig's.
            Glad to hear that Jim contributed to 'Waybe'. Let's hope he was/gets payed for his contribution.
            Oké, 'Waybe' seems to be more elaborated, has more tutorials and (maybe) more usefull functionality.
            I have used Jim's plugin quite frequently this year, not to make papermodels, but to break SU models into parts
            to make 3D polystyreen models, aswell to scale as full-size as super-oversize (A SchetchUp tutorial/workdescription
            to create a real football with a diameter of more than 2 meter).
            I have just downloaded the trial-version of 'Waybe'. Now I have 15 days to see if it is worth the money or whether
            I will stick to Jim's free version.
            At least, we have a choise between a free and a payed version.
            At first site, I am not sure the new payed version will win. Jim really created a very nice and usefull ruby some time ago.
            greetings,
            Ton
              sepo
              Tig we have not forgotten Jim's unfold script....It is refold we are after 😉
                Psyco_BoB
                Looks interesting.
                How effective is it with high polygon models?
                Can it be used for laser cutting?
                • EdsonE Offline
                  Edson
                  @psyco_bob said:
                  Looks interesting.
                  it does not work if you try to unfold a whole model. you have to proceed by steps, unfolding groups and/or components.
                  http://www.mahfuz.arq.br
                    Psyco_BoB
                    Grouping complex models will be tedious work. 😕
                    I'll give it a go anyway. 👍
                    • TIGT Online
                      Surely there is no difference. The model doesn't know if it was previously folded or unfolded at the point you start ?
                        sepo
                        I am not sure if I understand.
                        • X Offline
                          xrok1
                          its in ver. 1.3 now i'm go'in in!
                          • X Offline
                            xrok1
                            wow, that seized sketchup pretty good. it won't even start with that plug installed, maybe its not SK7 friendly? 😲
                            • X Offline
                              xrok1
                              try this instead, supports google earth, 3ds, obj ... http://www.tamasoft.co.jp/pepakura-en/download/designer.html
                              so you can use it with all your modelers and its $38
                                lewiswadsworth
                                There is a more professional piece of software available called Lamina which is also designed to unfold geometry. It allows you to input the real thickness of the material being unfolded, and then it prepares a cutting sheet with numbers and even tabs if you want them. You can save the output as a DXF cutting path for use with laser or plasma cutters or a waterjet/waterknife.
                                (laminadesign.com)
                                It's pricy...$395, but it's aimed at fabricators and rapid prototyping shops. I bought a copy after learning that some sculptors were using it for preparing sheetmetal for assembly...it does a nice job making complexly curved surfaces developable (not that's a situation you often see with SketchUp models...with Rhino, it's inevitable).
                                col sporcar si trova
