    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • fredo6F Offline
      Does it happen with all tools?
      Does it happen before, while or after you did the drawing?
      Any other 64-bits Windows user having the same problem?
      • Chris FullmerC Offline
        I'm on 64bit Vista and I use the script with no problems.
        • marleusM Offline
          marleus
          Thanks Fredo...
          Your tools are really big help for me when making furniture models
          Thanks 👍
          Markus Sillander
          Vantaa, Finland
          I'm on FormFonts now
          http://www.formfonts.com
          • U Offline
            urs0815
            wow! that´s real 3D !!!
              linea
              Hi Fredo
              I was late finding this thread and didn't know about this ruby. Awesome!Thanks.
              • fredo6F Offline
                At the moment, I am struggling around all the bugs that the Sketchup API has on Mac.
                So unless I release just for Windows....
                • plot-parisP Offline
                  plot-paris
                  I would be happy with that 😄
                  great to hear, that you are still on it Fredo. I am looking forward to the new release
                  • fredo6F Offline
                    As a hint, it will be 27 working days before the release of SU7 😄 😄
                      And then you can start re-writing the whole script for compatibility issues 😄
                        tulacong
                        thank very much 😍
                        • utilerU Offline
                          utiler
                          Big call Fredo!!!!!
                          Just Curious...
                          • fredo6F Offline
                            Coen,
                            You can testify that my NDA with big G is as thin as a face in a Sketchup model, that is, I have absolutely no knowledge whatsoever of what is going on and did not sign anything by the way.
                            I am working on ToolsOnSurface, but actually wanted to clean up and structure a little bit the script so that it is easier to write additional functionality. Part of it was using Web dialog, to avoid the Function keys, another part was to manage the releasing, the proliferation of icons and having a cleaner shared libraries. It just happened that on my way, I had this problem with Web Dialog on Mac, for which I hope to get some help from big G.
                            Anyway, as an additional hint, let's say that it will be on a Thursday.
                            • Y Offline
                              yonic
                              Hey, the toolbar not appears.
                              What happend? The icons.. not work, there aren´t buttons, I just search on Ruby Console...
                              I WANT A SOLUTION!!!!!!!
                                Daniel S
                                "you need to activate the script via the menu Windows->Preferences->Extension."
                                Daniel S
                                  Click Draw
                                  Hi Peeps,
                                  Do I have to delete the old toolbar icons first before I drop the new incons done by Cadfather into the TOS dir?
                                  Thanks,
                                  Jeff
                                  Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                    Gjenio
                                    Fredo I find your script a real Sketchup improvement, thank you for developing it!
                                    It's really interesting the construction line circle. It reminds me a suggestion I've had some time ago
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=3610
                                    The possibility to take a real construction circle you can refernece on it to draw with accurance. For example, now in sketchup I can't draw an arc with given radius tangent to two circles; I can't draw a circle (with a random point center) tangent to another existing one.
                                    Would Such as request be possible to seen developed in your script, sooner or later? Or it's something Sketchup cant support?
                                    • fredo6F Offline
                                      This is possible, and actually only On Surface in the general case (otherwise you need the 2 tangents to be in the same plane).
                                      Will think about it, as this may simply be an adaptation of the Arc tool.
                                      The only issue is that I don't have much time to be very active on my scripts at the moment, so it may take a while.
                                      The alternative is that someone writes a dedicated script for that specific function.
                                        tulacong
                                        Thank you verymuch, i love you
                                        • Q Offline
                                          Qpernick
                                          Hello,
                                          I am new here. My name is Filip. Nice to meet you.
                                          I wonder if this plugin works with Sketchup 7?
                                          I unzipping but no Tos-Dir-13 directory is created. Why?
                                          • fredo6F Offline
                                            The script should work in SU7.
                                            For your problem, be careful in Winzip to do a SELECT ALL, and then an EXTRACT in the Sketchup Plugins directory, in order to have Winzip to recreate the folder structure.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 31
                                            • 32
                                            • 21 / 32
