    [Tutorial > Modeling] How a Pro Builds a House in SU pt 1
    88 Posts 30 Posters 86.4k Views 30 Watching
      Note that in SU components can only cut an opening on a single face. This means they neither cut through a thick wall nor can cut two adjacent - though coplanar - faces (i.e. if you divide a face with a line and insert a component that should cut both faces, it will only cut one of them).
      To get some ideas about the workarounds to cut thick walls, look at this tutorial (do NOT miss the link to Susan's further enhancement of the tut at the bottom of the first post).
      Also, Didier has come up with a brilliant, new script, see the discussion here.
        Ah yes, I also believe that scripts are only to speed up the workflow and you should be able to do everything by hand also (OK, I know that there are some really tricky scripts like SSB and of course I'm really grateful for the rubiers).
        Nothing beats practice!
          PassUby
          First off, thanks for all the great tutorials and help on here.
          My question to anyone is why am I getting just this screen when I Import this file? I went through every setting i could think of, but to no avail I'm still stuck.
          My video card is a Radeon X1600 with the newest drivers.
          Thank you in advance!
          http://img259.imageshack.us/img259/8237/cantseeso0.th.png
            Aeir
            The APV_Template.skp is just a template which gives you the various tabs and settings. To actually get the picture you need to import either an image of a house plan (which you can find by doing a google search for house plan images) or an actual cad type file (.dwg, .dxf, etc). Once you do that, you will have your plan in the template and be ready to work with it.
            Hope that helps.
              keithwins
              In the tutorial, Chris mentions "be sure to use the right thickness for walls". I can't figure out how to change that, or exactly what he means. Do I draw a rectangle that is 6" "thick" over every wall, or is there a way to set lines to 6" thick? Or would people typically do the outside outline, and then offset the 6"?
              I also don't understand what is meant by "trace the door and window openings". Is that just drawing some short perpendicular lines to break the walls at the door and window locations, or is there something more tricky going on?
              Sorry, I'm not real experienced with Sketchup, AND this is the first tutorial I've looked at. Thanks for any clarifications!
              Warmly, keith
              SU Pro 2014
              Win 7
              There are two kinds of people in the world: those who believe there are two kinds of people, and...
                Yes, exactly. SU is not a "solid" but a "surface" modeler i.e. faces ("lines") don't have thickness at all. We only give "thickness" to bejcts bay drawing two faces of them.
                Notice however that a face has two different sides; a white/beige one that is the front or outside of it and a bluish one that is the back face. Always make sure that the back face "faces" inside the "thickness" of the geometry and you can only see white faces everywhere in your model.
                As for openings (windows, doors) you can either cut their places as Kriss suggests here or use components later. Components with gluing/cutting features can only cut through a single face however so in order to cut the inside face of a fat wall, you need to use some workarounds outlined in this tutorial:
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=20&t=744
                Make sure to follow the link at the bottom of the first post.
                  kikle_123
                  I am currently learning sketchup but I ran across your tutorial and I think it will be a great learning tool to incorporate into my work. -Krystal
                  • troyhomeT Offline
                    troyhome
                    These tutorials are part of what make SketchUp so great to use- we're never at a loss for how to accomplish something with our digital tool of choice!
                    IOviz.com
                    SU Pro 2024 PC
                      smorales02
                      Hello, I am new at SU and am going through this tutorial for practice. A couple of questions though..
                      After applying the image as a material, do I need to keep the original image in the drawing or can I delete it?
                      Also, seeing how we are tracing over and image the measurments of the wall wont be completely accurate, will they?? Seeing how your not snapping to any endpoint or anything...
                      Thank you
                        remus
                        Yep, you can delete the image form your model once youve applied it as a material.
                        As for accuracy, it depends how accurately you draw, as you pointed out. If you know the size of a few elements though, you can draw those in and use hem for size reference, making the whole thing a lot more accurate than just drawing by eye. Probably a bit slower, though, if you havent had a lot of practice with inference.
                        If you want a very accurate drawing youd be bet of starting with some imported linework (if you can get hold of it.) something like a .dxf file which is treated as linework in SU.
                          smorales02
                          Thanks for the reply, I have room sizes that are in my image so I will just use those for reference. If I had a dxf file that would be great but seeing how I am just using an image from the net I dont have one..
                          If anyone has a dxf or dwg of a floor plan and wouldnt mind me using it for some modeling practice, please let me know.
                            smorales02
                            Does step 11 mean just copy it over 4 times?? this being after we trace over the walls and the door/window openings??
                              remus
                              I dont think so, i think your meant to repeat the process a for the different layers of the house (basement, 1st floor etc.)
                              There is a second part to this tutorial btw, just do a search.
                                smorales02
                                Ive seen the second part of the tut which I am going to get to in a bit. I am just wondering why we would repeat a process we already did when we can just copy it??? Im confused on how many "copies" of the floor plan are needed...
                                • I Offline
                                  idraft
                                  Hi all,
                                  A couple of my tricks to speed up the whole process.
                                  1. Copying or overlaying jpeg image. Draw a line around entire perimeter untill it closes in. Delete fill. Then draw the wall into the appropriate position on the plan and use the "followme tool" to create all exterior walls. Done
                                  2. Interior walls. Make standard width wall (in plan only)and group it. make several copies for each wall needed. then group the lot. Grab one grouped wall and place in position, open the group and stretch it as req'd. Do this to all walls then finally ungroup all walls and push / pull to correct height.
                                    3.cut in window openings by scaling off plan.
                                    4.Make all windows on a single plane face and grouped(they dont need to be 3D in most cases) A cad drafting program will do that. Doesnt solve your cutting plane issue but saves a *&^% of time. If you want you can move your windows into the wall of the building by selecting all windows on each elevation then moving them in all at the same time, this gives you additional depth, or you can add cills to your window if needed.
                                  Cheers Jeff.
                                  • W Offline
                                    wildswan
                                    I am a newbie just starting to use SketchUp. Following along with this tutorial I have also encountered the same problem as jvh with Step 6. I right click on my imported plan, then click on "use as material". However, when I do this, the plan is NOT greyed out. Then when I click on the paint bucket and get the materials window, my plan is not in it, so I can't select and drop it in my square. I have tried using both .tif and .jpeg images but it doesn't seem to make any difference which format I import the image in. Can someone please tell me what I am doing wrong?
                                    • Chris FullmerC Offline
                                      When you click on the image and choose "Use as Material", it should add the material to your "In Model" materials list. So make sure you are looking at the In Model materials, or it will not show up.
                                      Another option might be to just right click on the image and choose "Explode" and then activate the paintbucket tool, and hold alt and click on the image. That should select the material so you can then use the paint bucket tool to apply it to the other face.
                                      Does any of that help? By the way, welcome to the forum!
                                        Rose123
                                        oops, appears i posted this in the wrong place ...n/m
                                          Rose123
                                          Hi Gaieus,
                                          You said this: "Notice however that a face has two different sides; a white/beige one that is the front or outside of it and a bluish one that is the back face. Always make sure that the back face "faces" inside the "thickness" of the geometry and you can only see white faces everywhere in your model."
                                          I have noticed that outside or inside faces will take on different hues. For instance, here:
                                          ERROR: The request could not be satisfied
                                          (i83.photobucket.com)
                                          the top and sides are different shades, even though they're both outside faces.
                                          I assumed that was because SketchUp is replicating the effects of light; different planes are given different shades of the same color. Is my assumption correct?
                                            See here to see the colour of front and back faces
                                            • 4 / 5
