    $ versus @
    20 Posts 11 Posters 3.6k Views 11 Watching
    • tbdT Offline
      tbd
      never, ever use globals in Ruby - beside name clash conflicts (as Didier said) you will have a lot of problems debugging it when someone else (your script or other) changes and you don't know why. of course you can use trace variable and see the caller stack, but why shoot yourself in the foot ?
      http://plugins.ro
      • PixeroP Offline
        Pixero
        I admit I have done it. 😳
        Simply because I don't know how not to.
        A simple tutorial with example code would be of tremendous help. β˜€
        By the way I've seen the use of double @@. What's that for?
        • tbdT Offline
          tbd
          I think everyone use it πŸ˜‰
          Pixero: give me an example when you really need a global and I will make an example on not using it
          @ - instance variable
          @@ - class variable
          see http://railstips.org/2006/11/18/class-and-instance-variables-in-ruby
          http://plugins.ro
          • PixeroP Offline
            Pixero
            All these globals in the script below for example:
            (By the way if I would need a variable that was remembered even after leaving the plugin and re entering. Should that be a global?
            Like if I set a $currentFrame variable and wanted it to be recalled later when using the script again? Hope I make myself clear.)
            # Name; 		jsMoveTool
            # Author; 	Jan Sandstrom   www.pixero.com
            # Description; 	Moves a selection with the arrow keys.
            # Usage; 	1. Select a object or group of objects.
            # 		2. Select the JS MoveTool and enter a distance in the VCB. Press Return/Enter.
            # 		3. Now move with arrow keys.
            # 		4. Use Alt + Up/Down to move in Z axis.
            # 		5. You can enter a new distance at any time.
            #		Version 1.1
            #		Added;
            #		6. Press Ctrl (Apple Key on Mac) for distance * 0.1
            #		6. Press Shift for distance * 10
            require 'sketchup.rb'
            class JS_MoveTool
            def activate
                # This sets the label for the VCB
                Sketchup;;set_status_text "Distance", SB_VCB_LABEL
              model = Sketchup.active_model
              entities = model.active_entities
              ss = model.selection
            if RUBY_PLATFORM == "i386-mswin32" then                 # Win XP
                $leftArrow = 37          # Arrow Left Key
                $upArrow  = 38           # Arrow Up Key
                $rightArrow  = 39        # Arrow Right Key
                $downArrow = 40          # Arrow Down Key
                $altKey = 18		# Alt Key
                $shiftKey = 16		# Shift Key
                $controlKey = 17		# Control Key
            elsif RUBY_PLATFORM == "powerpc-darwin" then            # Mac OSX
                $leftArrow = 63234       # Arrow Left Key
                $upArrow  = 63232        # Arrow Up Key
                $rightArrow  = 63235     # Arrow Right Key
                $downArrow = 63233       # Arrow Down Key
                $altKey  = 524288        # Alt/Option Key
                $shiftKey = 131072		# Shift Key
                $controlKey = 1048576	# Command (Apple) Key
            end #if
              def onUserText (text, view)
                # The user may type in something that we can't parse as a length
                # so we set up some exception handling to trap that
                begin
                    $value = text.to_l
                rescue
                    # Error parsing the text
                    UI.beep
                    puts "Cannot convert #{text} to a Length"
                    $value = nil
                    Sketchup;;set_status_text "", SB_VCB_VALUE
                return if !$value
                Sketchup;;set_status_text $value.to_s, SB_VCB_VALUE
                  def onKeyDown(key, repeat, flags, view)
                     # puts key   # For debug - finding the right keycodes
                     if (key == $altKey)
                     	$altDown = true;
                     end #if
                      if (key == $shiftKey)
                     	$shiftDown = true;
                     end #if
                     if (key == $controlKey)
                     	$controlDown = true;
                     end #if
            				@distance = $value
                  	Sketchup.active_model.selection.each {|e|
            				# X axis
            				if (key == $rightArrow) # Right
            					dist = Geom;;Point3d.new [@distance, 0, 0];
            				end#if
            				if ($controlDown == true && key == $rightArrow) # Right * 0.1
            					@distance = @distance * 0.1;
            				end#if
            				if ($shiftDown == true && key == $rightArrow) # Right * 10
            					@distance = @distance * 10;
            				end#if
            				if (key == $leftArrow) # Left
            				  	dist = Geom;;Point3d.new [-@distance, 0, 0];
            				end#if
            				if ($controlDown == true && key == $leftArrow) # Left * 0.1
            				end#if
            				if ($shiftDown == true && key == $leftArrow) # Left * 10
            				end #if
            				# Y axis
            				if (key == $upArrow) # Up
            				 	dist = Geom;;Point3d.new [0, @distance, 0];
            				end #if
            				if ($controlDown == true && key == $upArrow && $altDown == false) # Up * 0.1
            				end #if
            				if ($shiftDown == true && key == $upArrow && $altDown == false) # Up * 10
            				end #if
            				if (key == $downArrow) # Down
            				 	dist = Geom;;Point3d.new [0, -@distance, 0];
            				end #if
            				if ($controlDown == true && key == $downArrow && $altDown == false) # Down * 0.1
            				end #if
            				if ($shiftDown == true && key == $downArrow && $altDown == false) # Down * 10
            				end #if
            				# Z axis
            				if ($altDown == true && key == $upArrow) # Alt + Up
            				 	dist = Geom;;Point3d.new [0, 0, @distance];
            				end #if
            				if ($controlDown == true && $altDown == true && key == $upArrow) # Alt + Up * 0.1
            				end #if
            				if ($shiftDown == true && $altDown == true && key == $upArrow) # Alt + Up * 10
            				end #if
            				if ($altDown == true && key == $downArrow) # Alt + Down
            				 	dist = Geom;;Point3d.new [0, 0, -@distance];
            				end #if
            				if ($controlDown == true && $altDown == true && key == $downArrow) # Alt + Down * 0.1
            				end #if
            				if ($shiftDown == true && $altDown == true && key == $downArrow) # Alt + Down * 10
            				end #if
            				# Now move it!
            		  	tr = Geom;;Transformation.new (dist);
            				Sketchup.active_model.entities.transform_entities(tr, e);
                		} #each
                  end #onKeyDown
                end #onUserText
                def onKeyUp(key, repeat, flags, view)
                     if (key == $altKey)
                     	$altDown = false;
                     end #if
                     	$shiftDown = false;
                     end #if
                     	$controlDown = false;
                     end #if
                end #def
            end # end of jsMoveTool
            if( not file_loaded?("jsMoveTool.rb") )
                plugins_menu = UI.menu("Plugins")
                plugins_menu.add_item("JS MoveTool") { Sketchup.active_model.select_tool JS_MoveTool.new }
            • tbdT Offline
              tbd
              • replace all arrow codes with constants - e.g. $leftarrow -> LEFTARROW
              • replace rest of globals with class variables - e.g. $value -> @@value
              tested and it works (retains distance between calls of tool)
              http://plugins.ro
              • AdamBA Offline
                AdamB
                The original question was about why bother using anything but globals.
                Given at the end of the day its just bytes in memory, why do all these pesky computer scientists keep harping on about using locals and scoping stuff?
                Well, at the end of the day, it is just memory somewhere. But as programs became more and more complex the opportunities to shoot yourself in the foot and introduce bugs into the logic of your programs became more and more common.
                So rather than have to make correctness assertions about a million lines of code, computer scientists started breaking down large programs into small self-contained pieces of a tens of lines of code that were guaranteed to have no 'side effects' outside themselves. Having shown the individual functions were correct, they could then move up and start making correctness assertions about groups of functions and so on. Its called a 'hierarchy of confidence' and without it you'd simply never be able to get big software projects out the door.
                So, ensuring that variables are only accessible and changeable by certain well known bits of your program is just to make your life easier.
                Ditto laying out your (Ruby) code with rigid rules about formatting/indentation. It just helps spot errors. Ditto naming variables that give a hint about the meaning of the variable. Ditto naming functions to reflect what they actually do and not having 'hidden magic' they do on the side..
                So, if you want to use globals, and put all your Ruby code on a single line with no spaces. Go knock yourself out - you are free to do so. Its just making things hard for yourself - but each to his/her own. πŸ˜‰
                Thinking about who needs to be able to access variables is a good exercise before you even approach a keyboard to ensure you've thought things through.
                Having said all that, if you're writing a 10 line program and want to use globals because you've got a few minutes to bang some code out - don't have a guilt trip about - we've all done it.
                The flip side is that those who have worked on multi-million line projects adopt these ways or working for a good reason and not just for the hell of it.
                And lastly, for compiled code in C++/C# etc, using locals and avoiding globals will often results in the compiler generating faster code for you because it can rely on just the small set of local variables changing not anything and everything.
                Phew,
                Adam
                  Jim
                  So, should we be creating new instances of a Tool each time, or referencing the already existing instance? (Instance level variables will also continue to exists for the life of the session, if you don't instantiate a new class every time the tool is activated.)
                  • AdamBA Offline
                    AdamB
                    I'd suggest always re-instance a Tool unless there is a compelling reason to make it persist.
                    As a general rule, releasing resources as soon as possible is a GoodThing, and secondly - and probably more importantly in a Ruby context, to ensure you don't carry references to Ruby objects and therefore stop garbage collection happening - worse still carry stale references to objects that have subsequently been deleted which tends to make SU jump into the azure blue sea of unallocated heap store and commit hare-kiri.
                    Adam
                      tomot
                      @didier bur said:
                      But it is a lazy way of retaining values for your dialog boxes for instance, so user get the last values used.
                      One can avoid globals when using classes and methods, classes variables (@@) and objects variables (@).
                      I'm sorry but I cant let this topic die just yet. I have carefully reread all the
                      comments. Does this quote offer a solution to retaining values in Dialog Boxes?
                      my plugins
                      tomot
                        For a dialog's default values that you want keeping from session to session within a particular model, I write them as attributes to the model itself: when the dialog initialises it looks for their values, if they are not there it takes defaults - otherwise you have them saved on a model by model basis... For an example see my TextTag.rb.
                          RickW
                          So, there you have it - three solutions that avoid globals:
                          1. Sketchup.read_default and Sketchup.write_default (persistent across SketchUp sessions and models)
                          2. Attributes (persistent within a given model, between sessions)
                          3. Class variables (@@variable) (persistent only within a SketchUp session)
                          RickW
                          www.smustard.com
                            todd burch
                            For persistent data for Dialog Boxes, you should use Sketchup.write_default and Sketchup.read_default. The keys and values are stored in the registry (Windows) and the plist (Mac).
                            Todd
                              tomot
                              Thanks everyone; I took a quick look at TIG's, TextTag.rb. It appears to take a little bit more understanding of Ruby then just simply banging out a mass replacement of @ to $ or vise versa. πŸ˜„ Nevertheless I will try to implement
                              these attributes on an exisitng Ruby of mine.
                              my plugins
                              tomot
                                Matt666
                                Hi all !
                                Just one question : How can you do when you have that :
                                class ToolsObsTest < Sketchup;;ToolsObserver
                                	def onActiveToolChanged (tools_object, toolname, toolid)
                                		[b]@t[/b] = toolid
                                and this variable @t is used here :
                                module
                                  def
                                    [b]@t[/b]
                                So the variable is not used inside the first class section, but inside the instance of a module section ???
                                To find variable, I use $....
                                How can I preserve variable value ????
                                Frenglish at its best !
                                My scripts
                                • AdamBA Offline
                                  AdamB
                                  Just define your Observer class in the scope of your Module
                                  module Foo
                                        @t = toolid
                                  instance = Foo;;ToolsObsTest.new
                                    Matt666
                                    Hi AdamB !
                                    Thak you for your answer...
                                    I tried it but it didn't work for me... @toolID (variable name in the code) always returns nil....
                                    here is the real "tree" of the code (including your advice)
                                    module Toto
                                    			@toolID = toolid
                                    	def self.act
                                    		model.tools.add_observer(Toto;;ToolsObsTest.new)
                                    	def self.obs(id)
                                    		@toolID
                                    Do you know why your method doesn't work ?
                                    Thank you ! πŸ˜„
                                    My scripts
                                    • fredo6F Offline
                                      Matt,
                                      The two @toolid are different. One is a Class instance variable, the other a Module variable.
                                      If you want to track the toolid in module Toto, then use a method to set its value, which you can call from the class.
                                      Note that normally, you might use a Module variable, with @@, (since module instance variables do not really have real application)
                                      def Toto.set_toolid(toolid)
                                         @@toolid = toolid
                                      def Toto.get_toolid()
                                         @@toolid
                                        Matt666
                                        Hello Fredo6 !
                                        Thank you for your answer ! It works great ! get_toolid & set_toolid are perfect !
                                        Just one thing, @@variable doesn't work. Just @variable...
                                        Thank you Fredo ! πŸ˜‰ πŸ˜„ πŸ˜„
                                        My scripts
