    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 160.2k Views 83 Watching
      dolphus
      Thanx for the ruby much appreciated i will use it a great deal in my drawings 😍
        BorgMan
        Allright, I have this BIG model (6.79mb per half) on which I want to unleash the tool. Will the filesize (and thus the controlability) suffer under it when I do so? Attached is a screencap of the model. Note that it's only half of it, and that the bridge and nacelles are addad after I'm done, which would mean a further increase in filesize. Next to that, it's probable that I will be deleting some of it's interior (yeah, it's got interior, I went completely nuts with it) to tone down the filesize.
        So, people have been saying that adding a bevel to the model would be wise. But would it be in this case? Or would the model become uncontrolable? Some advice would be appreciated πŸ˜„
        More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
        You've gotta love Slivers.
          remus
          Depends more on the face count of the thing really.
          My suggestion would to be quite select on your use of the bevel tool, using it only where its needed to add to the realism of the model.
          Its also possible to control the number of segments the tool uses in the bevel, so i suppose if your careful with that you could go pretty wild with it.
          Bottom line: bevel everything and it will become very unwieldy, try and go half way between beveling and no beveling.
            PRSS
            Fantastic Fredo! The script is great - straight away started using it.
            It'll become my most used script.
            Thank you for the script
            With best regards
            PRSS
              javy
              wowo~~ this is just what i want!
              thanks! 😍
              • V Offline
                Venom
                Thank you very much~
                  botkill
                  Hope this is useful to my models.
                  • RayOchoaR Offline
                    RayOchoa
                    Is each half of your model a component? If not that may be why your model is suffering the big file[ness]
                    CaR DeSiGnS bY mE
                    http://ray-ochoa.com
                      ken114
                      thank you fred,i am a student from china.and my english is not good enough to understand all of you said,anyway after some try,i found someway to use it
                      coooooooooool πŸ˜„
                      • V Offline
                        Vicspa
                        GREAT Plug-in Thanks
                          I was sitting yesterday with a model where I wanted to bevel the edges, but follow me wasn't very practical due to to complex shape. Then I happen to come across this plugin today. It did the job great. Only had to clean up two vertexes. Now I got a nice edge which picks up the highlights when I render in V-Ray. πŸ˜„
                          Love your work man.
                            One feature request: Allow the operation to be undone.
                            • fredo6F Offline
                              Unfortunately, the only thing you can do today is to 'UNDO' right after the operation.
                              But your idea is interesting, assuming the development of another macro, say, SharpEdges, where you would select the side faces and then asks for joining them (as plane intersection), removing any round junctions.
                                BorgMan
                                RayOchoa, I didn't make eacht half a component because I wanted to delete each and every line that is a result of pasting the two halves together and because of some non-symetrical parts. It's all done now, with the model being 20.9MB, but she renders quite nice πŸ˜‰
                                Fredo, do you have paypal? I would like to make a small contribution for your efforts πŸ˜„
                                  tomot
                                  Fredo! This is a great script. I really thought I could get along without it,
                                  boy was I wrong!
                                  [my plugins](http://thingsvirtual.blogspot.ca/)
                                  tomot
                                    If I undo right after the operation it only undo each drawing operation the script did. I'd have to press undo many times to restore the mesh.
                                      Copy the mesh before and if you don't like the result, just delete it and paste the original in place (of course it's just a workaround but in case it is not programmable...)
                                      • fredo6F Offline
                                        Do you mean that each Undo will cancel a call to the Round Edge script, or that you need several Undos for a single Round Edge operation ? (in this latter case, this is strange, because I don't have the problem).
                                        Thanks to advise
                                        • fredo6F Offline
                                          Thanks very much for your appreciation of the script, and for your intention to reward the effort. I am not familiar with Paypal, but I do have an account at my email address fredosix@hotmail.com. Don't feel obliged, I am glad already with your kind recognition!
                                            KustuRA
                                            thank you!
                                            • 5 / 9
