    20 ruby's you can't live without
    22 Posts 19 Posters 5.5k Views 19 Watching
      JuanV.Soler
      bit tricky
      • ibonI Offline
        ibon
        I use very much 45ºShadows plugin for elevations, it's very fast and you don't have to move shadows and sun for each view 😉
        • EdsonE Offline
          Edson
          @jcdb said:
          FFD ❓
          which one is that?
          SketchyFFD
          http://www.mahfuz.arq.br
          • boofredlayB Offline
            boofredlay
            In no particular order, here are the ones I am grateful for.
            1. Mirror
            2. Purge
            3. Remove Materials
            4. Pipe along path
            5. Podium
            6. Subdivide & Smooth
            7. Sketchy Free Form Deformation
            8. STP Copy
            9. Weld
            10. Tools On Surface
            11. Joint Push Pull
            12. Round Edge
            13. Bevel
            14. Windowizer
            15. Make Faces
            16. Section Cut Face
            • EdsonE Offline
              Edson
              1. Round Edge
              eric,
              i could not find any script called round edge. can you post it, please?
                boofredlay
                It's right here on the first page of the Ruby forum.
                404 Not Found
                (www.sketchucation.com)
                • V Offline
                  viga1978
                  my indispensable Ruby scripts are:
                  1)Bezier Spline
                  2)Tube along path
                  3)Windowizer
                  4)Remove material
                  5)Section Cut Faces
                  6)3d Grid
                    dolphus
                    My most used scripts are
                    1 FFD
                    2 Extrude along path
                    3 Dome
                    4 Calculator
                    5 (CASF) Fun Shapes
                    6 Blezier Curves
                    7 TOOLS ON SURFACE
                      Matt666
                      Hi ! Good idea !
                      1. Purge
                      2. Mirror
                      3. Quick selection
                      4. Tools On Surface
                      5. Joint Push Pull
                      6. Round Edge
                      7. Beziersplines
                      8. FFD
                      9. Ruby panel
                      10. Global material change
                      11. Section Cut Face
                      12. Cut List And Materials
                      13. Vray
                      14. Make faces
                      15. Extrude lines
                      Frenglish at its best !
                      My scripts
                      • N Offline
                        nerz
                        Well i think we could add to this list the script soapskin i use nearly for each of my projects...
                        • FletchF Offline
                          Fletch
                          1 - make faces
                          2 - extrude lines up, extrude lines using 2 points, etc... all them extrude lines commands.
                          3 - Windowizer (creates a curtainwall)
                          4 - select all instances - is that a ruby, or built-in... I forget now...
                          5 - Joint Push Pull (for push-pulling curves)
                          6 - pushpull face in any direction (using 2 points), and other pushpull face commands... along normal, along Z, etc.
                          7 - stair generator
                          8 - SU2KT (SketchUp 2 Kerkythea)
                          9 - Proper Animation - (great for showing diff. options for furniture, or doors swinging open)
                          10 - Scene Exporter pro - once get used to having it... can't live without.
                          11 - Automated 2D Output
                          12 - Mirror Selection
                          13 - Deselect Edges (Deselect Faces) - I think these are rubies...
                          14 - Offset on surface (and tools on surface)
                          15 - Purge (this should be number 2)
                          16 - Layers and Materials plugin by Didier Bur
                          17 - Intersect overlapping lines
                          18 - Selection Memory
                          19 - Soap Skin Bubble
                          20 - Protrude (closest thing we have to greeble plugin for SU)
                          Fletch
                          • 2 / 2
