    Displacement + vray
    44 Posts 26 Posters 10.6k Views 26 Watching
    • 2 Offline
      2myChaGrin
      If you don't mind sharing, what were your displacement settings in Vray? Edge Length(pix) - Max Subdivision - Amount? I've been fighting to get a good grass displacement for the past few weeks and have had not luck. Are you using the new release?
        rufy
        can you give me tutorial step by step? vray material option setting? vray option setting? please πŸŽ‰
        i've try it,but i couldn't make picture like that, you are so awsome πŸ‘
        • StinkieS Offline
          Stinkie
          There's a wealth of info over at Vray 4 SU HQ. Do a search, and you'll find what you're looking for.
          • N Offline
            nomeradona
            displacement in vray will occurs only on grouped area. No Group no displacement.
            if you want to displace a face be sure you have to group it first. (dont know why the manual did not explain this.
            Settings? forget about those settings. just play with your texture size and texture multiplier.
              princedragoncok
              Hmm, I didn't really mean to run away from this thread. I've just moved house recently and so didn't have time. Let me just go over a few points quickly.
              1. As nomeradona said all elements to be displaced should be grouped (it doesn't say this in the manual I think)
              2. Find the texture you want to displace and apply it to the object you want to texture.
              3. Open photoshop and create a 'greyscale' version of the original coloured texture you applied in sketchup.
              4. Create a v-ray linked material based on the coloured texture you want to displace.
              5. Under maps in your material editor check the displacement box and then click on the small 'm' beside displacement.
              6. Once in the displacement screen look under 'common' then 'type' and select 'bitmap'
              7. To your right hand side a bitmap editor will appear - click on the small 'm' button under 'file'.
              8. This is where you link the greyscale image you created earlier.
              9. Under the preview screen in displacement you can change the intensity of displacement by playing with the 'multiplier'.
              10. Remember vray reads white as height and black as depth.
              11. Render
              • MarianM Offline
                Marian
                Thank you Prince dragon cok(? πŸ˜• ) for enlightening us....no wonder i couldn't get it right.
                But i do have a question ...when aplying the material/texture you must apply it by selecting the group or just editing the group and adding the material on the faces directly?
                  princedragoncok
                  Your welcome Marian. I'm pretty sure you edit the group, then apply your texture - create a linked material, and then close the group. If it works please post some examples here πŸ˜‰
                  • MarianM Offline
                    Marian
                    It worked like you said.... πŸ˜„
                      rufy
                      thankss πŸ˜„ ,but i can't do that in grass material, i can't make more sharpen, i don't know why? πŸŽ‰
                      but works in wood or stone material, i will try it again in grass material
                      please can you give your setting, and your pic of material? πŸŽ‰
                      thanks
                        cyan.archnet
                        very NICE indeed! πŸ‘
                          Mr S
                          Can you provide a link to Vray 4 SU HQ?
                          Tried to google this and couldn't find it.
                          Regards
                          Mr S
                          • StinkieS Offline
                            Stinkie
                            Errr ... sorry for the confusion. πŸ˜‰ http://www.asgvis.com
                              Mr S
                              Hi Stinkie,
                              Sorry about that, I made the assumption that Vray 4 SU HQ was some third party site providing tutorials etc.
                              I didn't realise you were refering to the ASGVIS website. Doh!
                              Regards
                              Mr S
                                kevsterman
                                Does Podium support displacement?
                                "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                  remus
                                  No, podium doesnt support displacement but it does support bump maps and clip maps.
                                  • pugz1983P Offline
                                    pugz1983
                                    I've tryed this displacement in Indigo. Works good with stone and wood. Grass is more difficult. But I think it depends on the quality of the texture or greyscale. I think the darker parts are the lowest and the lighter parts higher ( stick out ). So I think it could be a matter of resolution of the texture. I'll post some pics of my attempts soon.
                                      Julius
                                      @frederik said:
                                      I can only repeat what others already have said... Very nice indeed, but what about the render time..??
                                      @pav_3j said:
                                      so what render engines support this displacement mapping then? i want to tinker!
                                      KT2008 doesn't...
                                      But we're working on it...
                                      [attachment=1:e0bstany]<!-- ia1 -->displacedmesh_128.jpg<!-- ia1 -->[/attachment:e0bstany]
                                      [attachment=0:e0bstany]<!-- ia0 -->KT-cube_displaced.jpg<!-- ia0 -->[/attachment:e0bstany]
                                      @maverick83 said:
                                      What is displacement?
                                      Check this out...
                                      😍 😍 😍 i want displacement in KT so much!!! i could also pay for it!
                                      kim, you don't want me to use indigo instead of KT, don't you? πŸ˜• πŸ˜‰
                                      what are you waiting for?
                                        juanjo06
                                        here is a link... maybe usefull
                                        πŸ‘ πŸ‘ πŸ‘
                                          dacad
                                          Frederik
                                          Why do you tease me...πŸ˜›
                                          I want that!!when will it be released?
                                          • 2 / 3
