    Displacement + vray
    44 Posts 26 Posters 12.0k Views 26 Watching
    • orgelfO
      orgelf
      I really like the first hand .and it seems that there is no limits except your imagination with vray and displacement πŸ˜„
      very nice πŸ‘
      http://www.orgelf.com
      • dazzaD
        dazza
        @frederik said:
        @pav_3j said:
        so what render engines support this displacement mapping then? i want to tinker!
        KT2008 doesn't... 😞
        But we're working on it...
        πŸ˜‰
        Cannot wait, Kim any hints as to how long we KT'ers have to wait in pained anticipation? πŸ˜‰
        All people have the right to stupidity but some abuse the privilege.
        • FrederikF
          Frederik
          Sorry... I can't say... 😳
          It's summer holiday season at the moment... It was just to show that we're working on things...
          Might be 3-4 month from now... Mignt be longer... 😐
          But I'm sure you will agree that it will be worth waiting for... πŸ˜‰
          Besides... You need to remember that KT2008 only got released 6 month ago... πŸ˜‰
          Cheers
          Kim Frederik
          • dazzaD
            dazza
            You guys are brilliant, take your time and don't let any of us (the impatient delinquent slaves of the modern world) distract you all on delivering what will undoubtedly be the most anticipated release to date. But till then, I'll be πŸŽ‰ around like a little kid before Christmas. πŸ˜„ πŸ˜‰
              2myChaGrin
              If you don't mind sharing, what were your displacement settings in Vray? Edge Length(pix) - Max Subdivision - Amount? I've been fighting to get a good grass displacement for the past few weeks and have had not luck. Are you using the new release?
                rufy
                can you give me tutorial step by step? vray material option setting? vray option setting? please πŸŽ‰
                i've try it,but i couldn't make picture like that, you are so awsome πŸ‘
                • StinkieS
                  Stinkie
                  There's a wealth of info over at Vray 4 SU HQ. Do a search, and you'll find what you're looking for.
                  • N
                    nomeradona
                    displacement in vray will occurs only on grouped area. No Group no displacement.
                    if you want to displace a face be sure you have to group it first. (dont know why the manual did not explain this.
                    Settings? forget about those settings. just play with your texture size and texture multiplier.
                    • P
                      princedragoncok
                      Hmm, I didn't really mean to run away from this thread. I've just moved house recently and so didn't have time. Let me just go over a few points quickly.
                      1. As nomeradona said all elements to be displaced should be grouped (it doesn't say this in the manual I think)
                      2. Find the texture you want to displace and apply it to the object you want to texture.
                      3. Open photoshop and create a 'greyscale' version of the original coloured texture you applied in sketchup.
                      4. Create a v-ray linked material based on the coloured texture you want to displace.
                      5. Under maps in your material editor check the displacement box and then click on the small 'm' beside displacement.
                      6. Once in the displacement screen look under 'common' then 'type' and select 'bitmap'
                      7. To your right hand side a bitmap editor will appear - click on the small 'm' button under 'file'.
                      8. This is where you link the greyscale image you created earlier.
                      9. Under the preview screen in displacement you can change the intensity of displacement by playing with the 'multiplier'.
                      10. Remember vray reads white as height and black as depth.
                      11. Render
                      • MarianM
                        Marian
                        Thank you Prince dragon cok(? πŸ˜• ) for enlightening us....no wonder i couldn't get it right.
                        But i do have a question ...when aplying the material/texture you must apply it by selecting the group or just editing the group and adding the material on the faces directly?
                        • P
                          princedragoncok
                          Your welcome Marian. I'm pretty sure you edit the group, then apply your texture - create a linked material, and then close the group. If it works please post some examples here πŸ˜‰
                          • MarianM
                            Marian
                            It worked like you said.... πŸ˜„
                              rufy
                              thankss πŸ˜„ ,but i can't do that in grass material, i can't make more sharpen, i don't know why? πŸŽ‰
                              but works in wood or stone material, i will try it again in grass material
                              please can you give your setting, and your pic of material? πŸŽ‰
                              thanks
                              • C
                                cyan.archnet
                                very NICE indeed! πŸ‘
                                  Mr S
                                  Can you provide a link to Vray 4 SU HQ?
                                  Tried to google this and couldn't find it.
                                  Regards
                                  Mr S
                                  • StinkieS
                                    Stinkie
                                    Errr ... sorry for the confusion. πŸ˜‰ http://www.asgvis.com
                                      Mr S
                                      Hi Stinkie,
                                      Sorry about that, I made the assumption that Vray 4 SU HQ was some third party site providing tutorials etc.
                                      I didn't realise you were refering to the ASGVIS website. Doh!
                                      Regards
                                      Mr S
                                      • K
                                        kevsterman
                                        Does Podium support displacement?
                                        "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                          remus
                                          No, podium doesnt support displacement but it does support bump maps and clip maps.
                                          • pugz1983P
                                            pugz1983
                                            I've tryed this displacement in Indigo. Works good with stone and wood. Grass is more difficult. But I think it depends on the quality of the texture or greyscale. I think the darker parts are the lowest and the lighter parts higher ( stick out ). So I think it could be a matter of resolution of the texture. I'll post some pics of my attempts soon.
                                            • 2 / 3
