    Why don't more people use SketchUp to place 3D components?
    30 Posts 17 Posters 10.9k Views 17 Watching
      a4chitect
      one more thing: maybe it would be useful to integrate 3dwarehouse into sketchup since sketchup is the sole purpose of the warehouse at the moment, and then we could browse the warehouse in a 3d environment native to sketchup and wouldn't have to think about switching between sketchup and the browser, and thinking about where to save the downloaded file (then care to delete the file it it doesn't fit)
      ~like using the google-earth streaming technology but not for the GE but for sketchup instead
      [but I know that the web and google earth is more important to google and therefore don't expect the 3dwarehouse concept to remain off-browser]
      • B
        Baker518
        When I am adding a component to a drawing, I usually try to find it in 3D warehouse. If its not there I take the time to research it, as best as I can, and then draw it to suit my needs. My failure is not adding it to the warehouse once I am satisfied with it. That is something I will try to do more of in the future. I know that doesn't answer the main question, just wanted to see my name up in lights, sorry.
        Mike
        Don't worry about things you have no control over. Worry is a lack of Faith!
        • CraigDC
          CraigD
          (Re: Adding back to the 3D Warehouse) Thanks Mike! It's good content that makes all the difference! We appreciate all of the contributors of quality models!
          Cheers,
           - CraigD
          Google SketchUp
            Jim
            I'm short on time, so this is really a rough draft.
            I think it's not so easy to create convincing interiors. It takes more than drawing a box and placing some furniture in it to make it work.
            The models for an interior need to be higher quality than the average 3d warehouse model. Unless you use high-segment arcs, you are going to see individual segments simply because the camera needs to be closer for an interior scene.
            It's hard to "mesh" SketchUp's sketchy style with photo-realistic textures.
            One major deficiency is interior lighting. Lighting is a much larger part of the interior design experience than exterior. On exteriors, there's usually only 1 light source of concern.
            Because of these points, your best option is to generate a photo-realistic render. But that brings another level of complexity to the process.
            I'm not convinced SketchUp is as easy to use as I keep hearing.
            • CraigDC
              CraigD
              Hi Jim, I think you make some good points. My concern with this logic however is that you are mixing "modeling" and "rendering" into the same bucket.
              I believe that you won't find an easier, faster modeler out there, with the accuracy of SketchUp. Add to that the ability to very simply add photo realistic textures to your models and I think that you will find SketchUp is an excellent modeling tool for interiors.
              Many folks here will agree with you in regards to photo realistic rendering and lighting, which is why there is a Rendering section to this forum. There are multiple options to easily take a SketchUp interior, add lights and shadows, and create a breathtaking interior scene. I've glanced upon many amazing interior renders, created in SketchUp and rendered using one of the favorites discussed in the Rendering sub-forum.
              One possible tip I have for those who are creating interiors in SketchUp is to change your camera field of view in the VCB (Value Control Box) box in the lower right corner of the Model window. If you set it to something like 75 degrees, you'll find that it's whole lot easier to work in tight, interior confines.
              Another tip is to use Section Planes/Cuts to remove some interior obstructions and give you a better, more clear view of the work area.
              I hope this helps, and that you truly spend a little quality time playing with SketchUp. There a tons of people here who are more than happy to help you along your path of discovery, so don't give up on us just yet! šŸ˜‰
              Cheers,
              - CraigD
              Google SketchUp
              • syburnS
                syburn
                to study space and make sketchy sketches, then sketch up is fine. it really really needs simple interior lighting though............ and a cheating / magical way to make tranparent/reflective things as one does when one "sketches" with hands
                • C
                  chango70
                  You can get the Lightup plug-in can't you? I've seen some beautiful work done with it. Haven't bought it yet because its a bit pricey atm.
                  • Al HartA
                    Al Hart
                    Here is a reflection example one of our furniture clients created - by making the floor transparent and mirroring the rest of the geometry through the floor to make the floor appear reflective.
                    http://wiki.renderplus.com/images/a/af/Mil08-resized.jpg
                    (Image courtesy of ProjectMatrix)
                    (Rendering created with SketchUp - no third party rendering add ons)
                    Al Hart
                    IRender nXt from Render Plus
                    • C
                      chango70
                      Wow cool! thats what I am talking about! Nice chairs, did you get them from 3D Warehouse?
                      • Al HartA
                        Al Hart
                        Are you able to share the girl in this image?
                        It would be a welcome component to many if you could.
                        I contacted the client who made the rendering. She is from the Google 3D Warehouse (from Antics Technologies):
                        http://sketchup.google.com/3dwarehouse/download?mid=a38fd74a5a5900412251f6cc77ae450c&rtyp=lt&ctyp=other&ts=1209601510000
                        Error 404 (Not Found)!!1
                        (sketchup.google.com)
                        Al Hart
                        • Al HartA
                          Al Hart
                          The chairs are from the libraries which come with ProjectSketch - a new office furniture placement application for SketchUp being released by one of our clients - ProjectMatrix.
                          ProjectSketch is free with a generic furniture library. These chairs are from the Herman Miller library. There is an annual fee for use of the manufacturer specific libraries.
                          There are 3D symbol libraries available for more than 60 manufacturers:
                          http://www.projectmatrix.com/mfg/index.htm
                          http://www.projectmatrix.com/images/header.jpg
                          Al Hart
                            dvonhausen
                            If I am going to buy an appliance (or something else), why would I go to my computer to view them before going out to Maytag where I could see the real thing. Thats just more work for me. Manufactures and retailers are not going to invest the time and expense to build components in SU unless they feel it will convert prospects into sales.
                            If I view 3D sketchup components and have a list of retailers who sell the component sorted in order of how close they are to me and then push a button selecting the retailer which makes a call over my computer to the retailer so I can ask all my questions about the component without every leaving my home, then there begins to be some added value. I also may want to buy it without going to the store so with a push of a button, the retailer has all the info needed to write up the order saving me time. I also have to believe that what I see on the screen is an accurate representation of what I will be buying. For a washing machine, color may be important to me so I want to see the available colors from each retailer and it must be accurately displayed on my screen so I can judge confidently. For clothes, forget it for atleast 10 years. There also has to be a critical mass so I get a large selection and I don't feel that I am missing out on a bargain some place else. Price comparisons will also be a plus. Having components displayed in virtual showrooms that I can customize to reflect my surrounds may be helpful so I can build a room at a time instead of an appliance at a time.
                            Dave
                            • Al HartA
                              Al Hart
                              But if you were a kitchen designer, proposing a custom kitchen for a consumer who was not a SketchUp user, you might use SketchUp to layout the new Kitchen and then find components to place in it.
                              If you find a great stove on the 3D Warehouse, you can use it. And you might even decide to prefer furniture items which had great components on the warehouse, because you might be more likely to close the design and sale to the client with better graphics and a better rendering.
                              Manufacturers who think this is a good idea might be willing to spend time to put their components on the 3D Warehouse - or use a program like RpReports which lets them distributes their components only to their dealers and distributors.
                              Al Hart
                              • RichardR
                                Richard
                                CraigD
                                Mate I'm sincerely glad you are listening in on this thread and hearing what is said! And sorry I'm going to give you a bit more to read here.
                                I don't know why but feel I need to give some of my own history to back up my cause?:
                                I started working with SU when i bought my first computer in the days of version 3 and quickly found it suited my limited tech skills - at that time with the limited user base my output gained some notoriety (spelling bad sorry) and Mike (Mayor) Lucey got me invited on to the beta team. from there I got invited onto the beta team for Artlantis R and Studio. And since to the Maxwell Beta team due to my contribution to learning and skills gained in rendering!
                                I mention all this because although I think I have well recognised skills in SU I can't get anythinh out of any other modeller simply because I'm techno DUMB!!!!!!! Heck I bought AutoCAD lite then too and can't even draw a line!! So this is to support your argument that SU really is very simple to use!!!!!
                                All this said I can see some very inherant reasons why some may not find SU the ultimate tool of choice!!! And to agree whole heartedly with Pete why the warehouse for me is a bit of a white elephant - sorry!!!!!
                                I'll list my reasons so to make them clear and I might even try to get away with some harsh language too!!!!
                                SKETCHUP:
                                1. Poly count poly count poly count! It is obvious to look through the gallery here that rendering from SU to external apps is growing at an expediated rate. With the ease and availability of render apps clients have higher expectations and users are introducing this to their workflows to keep pace. SU's inherant issues of dealing with high poly models and scenes requires users to create work arounds to overcome - workarounds are just the first hint that something is wrong!
                                2. Texture mapping! SU limited texturing tools are getting more and more attention as the user base and fields of use increase again the user preference to render output highlights these limitations...
                                3. Import Compatability! tons of good content for the 3d industry is available out there free or in collections yet the import capabilities of SU for good 3DS, OBJ etc are a real downfall here, so much clean up or remapping is required to make much of this content usable. Poly crunching external to SU is also often a must due to the before mentioned poly limitations.
                                4. Illumination! I know and to some degree support the idea that SU is only aimed at being a modeller not for rendered tours etc but a growing expectation to export to game engines and the like to permit better environment for view shows this to be an underlying issue and possibly one of the main reasons 3d Max maintains much of this market.
                                5. Viewing options! I normally aim to do all my scene compliation in SU for obvious reasons though when polycount becomes an issue I'm forced into Maxwell Studio - although component or object placement is hindered somewhat I find the ability to view placement in more than one camera view sometimes an absolute god sent. Something I wish was optional in SU would be the ability to view more than one scene window at a time.
                                3D WAREHOUSE
                                1. Model consistancy! As Pete inferred I see a real issue with the warehouse around consistancy where any search will bring up so many varied quality models and one doesn't know till opening it up.
                                2. Lost! probably the same as above but as suggested earlier Good High Poly models are required for good render export and many of the models (may in fact most) are not useable for export to render.
                                3. Separation! I feel separartion of the warehouse content would be a worthwhile endeavour! One warehouse level for the weekend hackers and one for good professional level content where the user or their contributions need to have proven levels of quality - possibly even a "Certified User" registry or something akin to that. manufacturer's content to make it to this level may also need to comply! I look at something I downloaded the other day a Whirlpool Cooktop - nothing more than an image plane with nobs - what use is that for anyone! Whirlpool probably paid someone to do that without the knowledge the resulting model would be unusable!
                                Generally I'm not sure a rating system works - I've seen high rated models on the warehouse that when opened are pretty crooke! I'm not sure who voted and what are the aspects on which people are voting. i look at the voting of threads on the PushPullBar - threads are often voted on based on the image quality or the quality of the design but for me I vote on the quality of the thread content which could be based on the arguments raised and what value therefore the thread had to me!
                                I think therefore some other way of distinguishing good content from bad is essential - afterall the content on the warehouse continues to grow and as a result more and more any quality content will continue to be lost amongst the hoards of substandard models.
                                I hope I didn't loose you or sound too harsh!
                                Regards Richard
                                BUILTBRAND.COM.AU
                                • T
                                  twharvey
                                  I'd like to echo/underline much of what Pete and Richard have said. I've often thought that 3DW is a lot weaker than it should be. One thing I think would help would be a system of clasification for models, e.g. geo-located buildings, other buildings, vehicles, guns, etc. etc. I'm not particularly interested in guns, so I could skip it.
                                  I'm also bambuzeled by the Popular Models section. It's a complete mystery what Popular means. Then you can sort any collection by Popularity. I don't know what this is either.
                                  Then there is my on-going frustration with Google's review program. I've had a model clearly marked "Work in progress" that was included in Best of 3D Warehouse. Other models are left for months in Waiting for Review" with no indication of whether they have been rejected or even looked at. If they have been rejected for inclusion in GE, Witing should change to "Rejected". It would be helpful to know why as well, but maybe that would take too much manpower on Google's part.
                                  Tom
                                  Tom
                                  • pbacotP
                                    Hello,
                                    Perhaps this is a good place to post my SU Kitchen Modeling Consortium idea. I am not concerned here in opening the SU door to the masses as facilitating SU use for professional designers and architects.
                                    With residential remodel design being a large part of my work, I'd like to use SU to present 3d kitchen models in something comparable to that provided by cabinet makers. If professionals worked together online to glean, vet, and share models and systematic modeling methodology, we might make something that is useful to everybody.
                                    Agreeing on the quality and impetus of work might be the hardest part among designers. But at least you are not leaving it up to non-designers to ferret out as in 3d Warehouse. The process could start out informally, but of course, it needs a place online to happen.
                                    Hope this is not too OT
                                    With your input, this post could be even better šŸ’—
                                    • 2 / 2
