    Instancing in indigo
    62 Posts 18 Posters 11.5k Views 18 Watching
    • plot-parisP Offline
      plot-paris
      I simplified the windows component a bit (reduced it from 16 to 5 faces) and tried a render again. now it worked perfectly fine with only 200 Mb Ram used by Indigo.
      I even was able to place another building into the scene (which by itself is 20 times bigger in file size than the whole city).
      granted, this twisted shape may look a bit alien in the otherwise orthogonal city. understand it as a symbol for SketchUp's unique and inovative workflow amidst loads of other applications with their narrow minded interfaces πŸ˜‰
      http://img512.imageshack.us/img512/4910/bigcityjj4.jpg
      (in the model are 1910 buildings plus the twisted one)
      this city is very basic: 5 different building heights (all based on the same storey component), assembled in 10 different block types.
      just imagine, what wonderful and huge cities you can render if you put in a bit more time and effort to create variations...
        Kenny
        I tried the original model and it started loading but I got a run time error. I've got a pretty good spec too with 4GB Ram and a Core 2 duo E6850 processor.
        Kenny
        http://www.townscapesolutions.co.uk/
          remus
          I think a run time error is when it runs out of memory, not sure what would cause it though, if jakob can render it on his machine πŸ˜‰
            plot-paris
            dear Kenny, thanks for trying out my model. I would very much like to see, what you can get out of it (for your pc seems to be quite capable πŸ˜‰ )
            well, I was only able to render the whole model after simplifying the windows...
            here is that version (without the twisted building though - that is more than 4 Mb filesize)
            city_simplified.skp
              plot-paris
              and here another very quick one - 13 680 golden eggs(even with a cube as proxy very slow in SketchUp). quite fast to export though...
              (thanks to OnSurface, JPP, ComponentSpray tools - model was set up in a second πŸ˜„ )
              http://img295.imageshack.us/img295/4810/13680eggsxz3.jpg
              I hope to find the time to do something more fancy soon...
                plot-paris
                this image may not look very interesting. the only purpose was to test out polygon limits of indigo.
                well, I am tempted to believe there are no limits πŸ˜•
                one of these forms has more than 55.000 polygons. in this scene I had almost 24.000 instances (low-res proxies in SketchUp, automatically replaced with the original by indigo).
                that means, that indigo had to handle more than 1.3 Billion! polygons(1.300.000.000) 😲
                only 60 MB of ram were used by indigo for this very small image (exponentially more, when increasing the file size)...
                http://img165.imageshack.us/img165/8509/13billionpolygonspp5.jpg
                  chango70
                  Would this work with Vray?
                  • I Offline
                    ilay7k
                    no...only plans
                      plot-paris
                      as far as I know, v-ray doesn't support instancing at present.
                      the most amazing tool about indigo in this case is not only that it allowes instancing, but that you can use a low-poly component as proxy in SketchUp, that are replaced with a high polygon component, when exported to indigo. otherwise you would have no chance to handle such a huge scene in SU...
                      I am not aware of any other render-engine, that does that. πŸ˜•
                      • FrederikF Offline
                        Frederik
                        Correct... πŸ˜‰
                        This is not correct... πŸ˜‰
                        It's not that I want to hi-jack your thread, but I need to correct you since Kerkythea also supports instancing and you can use proxies in SU and replace these with instanced objects in KT... πŸ˜‰
                        Please check out this thread, which is a small step-by-step tutorial I've posted at the KT Forum... πŸ˜‰
                        Cheers
                        Kim Frederik
                          Jon
                          In fact, Alex once did a test in KT involving a few billion polygons more than that. πŸ˜‰
                          These are great tests, plot. Keep it up. πŸ˜„
                          PS. I though Vue6 could export proxy objects ❓
                          Does anyone know for sure?
                          Jon
                          KT Team member
                          • soloS Offline
                            Vue 6 has instancing too.
                            okay...too slow you just mentioned it.
                              plot-paris
                              ah, good to know, that there are biased renderers that support instancing as well. I just have to find the time to learn them 😒
                              but please, post your tests here as well! I want to see loads and loads of instances πŸ˜„
                              • soloS Offline
                                I use Vue quite a lot these days for site overview renders, however I have not yet had the need for instancing, but that is about to change as I need to do an animation of a fly over in the near future that involves a very wooded area and I will need to familiarize myself with this feature soon. as soon As I figure it all out I will post an example and maybe a few screen grabs as to how it works.
                                If anyone out there is familiar with it and can assist my learning curve I would appreciate that ... Chipp I am looking at you. πŸ˜„
                                  chango70
                                  Does anyone know which one of the other instancing renderer is fasster? Has anyone test the them before?
                                  • soloS Offline
                                    Okay!
                                    That was very easy to figure out actually.
                                    I used the Instancing brush in Vue 6 xstream to paint the SCF logo on a very uneven surface, it was extremely quick and smooth and rendered in 11 minutes.
                                    I am impressed at the ease and simplicity of instancing with Vue.
                                    http://img511.imageshack.us/img511/6914/instancingts8.jpg
                                      acatalyst
                                      301 Moved Permanently
                                      (www.vray.info)
                                      • soloS Offline
                                        20 000 trees, 208 million polygons, render time 7m24s
                                        http://img46.imageshack.us/img46/4821/instancing1tv6.jpg
                                        • FrederikF Offline
                                          Frederik
                                          Dang, Pete... You're smoking hot... πŸ˜„
                                          But that terraine would be impossible to orbit in SU... 😞
                                          I know zip about Vue, but how is your workflow..?? Do you import models from SU to Vue and take it from there, or...?!? πŸ˜•
                                          @Adam - can't see the video... 😐 Guess YouTube needs to get it through their verification system or something, so I will check it later... πŸ˜‰
                                          This is obviously a new plug-in/script you're working on - or.??
                                          Cheers
                                          Kim Frederik
                                          • AdamBA Offline
                                            AdamB
                                            Realtime instancing is the only way to go.. πŸ˜‰
                                            And a very short vid too is here
                                            (Should just say that on my old laptop it runs at silky smooth 30Hz comfortably - its the vid capture/youtube compression that drops the framerate)
                                            Adam
                                            • 1 / 4
