    Instancing in indigo
    62 Posts 18 Posters 16.1k Views 18 Watching
    • StinkieS
      Stinkie
      8 Gb? Wuss! πŸ‘Ώ
        remus
        😒 your making me jealous
        • plot-parisP
          plot-paris
          I simplified the windows component a bit (reduced it from 16 to 5 faces) and tried a render again. now it worked perfectly fine with only 200 Mb Ram used by Indigo.
          I even was able to place another building into the scene (which by itself is 20 times bigger in file size than the whole city).
          granted, this twisted shape may look a bit alien in the otherwise orthogonal city. understand it as a symbol for SketchUp's unique and inovative workflow amidst loads of other applications with their narrow minded interfaces πŸ˜‰
          http://img512.imageshack.us/img512/4910/bigcityjj4.jpg
          (in the model are 1910 buildings plus the twisted one)
          this city is very basic: 5 different building heights (all based on the same storey component), assembled in 10 different block types.
          just imagine, what wonderful and huge cities you can render if you put in a bit more time and effort to create variations...
          • K
            Kenny
            I tried the original model and it started loading but I got a run time error. I've got a pretty good spec too with 4GB Ram and a Core 2 duo E6850 processor.
            Kenny
            http://www.townscapesolutions.co.uk/
              remus
              I think a run time error is when it runs out of memory, not sure what would cause it though, if jakob can render it on his machine πŸ˜‰
              • plot-parisP
                plot-paris
                dear Kenny, thanks for trying out my model. I would very much like to see, what you can get out of it (for your pc seems to be quite capable πŸ˜‰ )
                well, I was only able to render the whole model after simplifying the windows...
                here is that version (without the twisted building though - that is more than 4 Mb filesize)
                city_simplified.skp
                • plot-parisP
                  plot-paris
                  and here another very quick one - 13 680 golden eggs(even with a cube as proxy very slow in SketchUp). quite fast to export though...
                  (thanks to OnSurface, JPP, ComponentSpray tools - model was set up in a second πŸ˜„ )
                  http://img295.imageshack.us/img295/4810/13680eggsxz3.jpg
                  I hope to find the time to do something more fancy soon...
                  • plot-parisP
                    plot-paris
                    this image may not look very interesting. the only purpose was to test out polygon limits of indigo.
                    well, I am tempted to believe there are no limits πŸ˜•
                    one of these forms has more than 55.000 polygons. in this scene I had almost 24.000 instances (low-res proxies in SketchUp, automatically replaced with the original by indigo).
                    that means, that indigo had to handle more than 1.3 Billion! polygons(1.300.000.000) 😲
                    only 60 MB of ram were used by indigo for this very small image (exponentially more, when increasing the file size)...
                    http://img165.imageshack.us/img165/8509/13billionpolygonspp5.jpg
                    • C
                      chango70
                      Would this work with Vray?
                      • I
                        ilay7k
                        no...only plans
                        • plot-parisP
                          plot-paris
                          as far as I know, v-ray doesn't support instancing at present.
                          the most amazing tool about indigo in this case is not only that it allowes instancing, but that you can use a low-poly component as proxy in SketchUp, that are replaced with a high polygon component, when exported to indigo. otherwise you would have no chance to handle such a huge scene in SU...
                          I am not aware of any other render-engine, that does that. πŸ˜•
                          • FrederikF
                            Frederik
                            Correct... πŸ˜‰
                            This is not correct... πŸ˜‰
                            It's not that I want to hi-jack your thread, but I need to correct you since Kerkythea also supports instancing and you can use proxies in SU and replace these with instanced objects in KT... πŸ˜‰
                            Please check out this thread, which is a small step-by-step tutorial I've posted at the KT Forum... πŸ˜‰
                            Cheers
                            Kim Frederik
                              Jon
                              In fact, Alex once did a test in KT involving a few billion polygons more than that. πŸ˜‰
                              These are great tests, plot. Keep it up. πŸ˜„
                              PS. I though Vue6 could export proxy objects ❓
                              Does anyone know for sure?
                              Jon
                              KT Team member
                              • soloS
                                Vue 6 has instancing too.
                                okay...too slow you just mentioned it.
                                • plot-parisP
                                  plot-paris
                                  ah, good to know, that there are biased renderers that support instancing as well. I just have to find the time to learn them 😒
                                  but please, post your tests here as well! I want to see loads and loads of instances πŸ˜„
                                  • soloS
                                    I use Vue quite a lot these days for site overview renders, however I have not yet had the need for instancing, but that is about to change as I need to do an animation of a fly over in the near future that involves a very wooded area and I will need to familiarize myself with this feature soon. as soon As I figure it all out I will post an example and maybe a few screen grabs as to how it works.
                                    If anyone out there is familiar with it and can assist my learning curve I would appreciate that ... Chipp I am looking at you. πŸ˜„
                                    • C
                                      chango70
                                      Does anyone know which one of the other instancing renderer is fasster? Has anyone test the them before?
                                      • soloS
                                        Okay!
                                        That was very easy to figure out actually.
                                        I used the Instancing brush in Vue 6 xstream to paint the SCF logo on a very uneven surface, it was extremely quick and smooth and rendered in 11 minutes.
                                        I am impressed at the ease and simplicity of instancing with Vue.
                                        http://img511.imageshack.us/img511/6914/instancingts8.jpg
                                          acatalyst
                                          194.63.248.52 in parked
                                          (www.vray.info)
                                          • soloS
                                            20 000 trees, 208 million polygons, render time 7m24s
                                            http://img46.imageshack.us/img46/4821/instancing1tv6.jpg
                                            • 1 / 4
