    Instancing in indigo
    62 Posts 18 Posters 11.6k Views 18 Watching
    • plot-parisP Offline
      plot-paris
      right you are, remus. I just tried again... indigo crashes after my use of ram rises beyond 2,5 Gb (and I have only 2Gb physical Ram).
      I hoped to prevent this by enabling instances. but I am afraid my city has to wait until I got some money left πŸ˜‰
      @remus said:
      Gotta try out proxies again, your tests are pretty inspiring.
      that was my intention! πŸ˜„
      kwistenbiebel, remus; I am looking forward to see what you come up with!
        kwistenbiebel
        I did my share of experiments I believe πŸ˜‰.
        Never had Indigo crashing, even when having millions of polygons.
        I guess the 8Gb Ram I have installed comes to use in this case.
        • StinkieS Offline
          Stinkie
          8 Gb? Wuss! πŸ‘Ώ
            remus
            😒 your making me jealous
              plot-paris
              I simplified the windows component a bit (reduced it from 16 to 5 faces) and tried a render again. now it worked perfectly fine with only 200 Mb Ram used by Indigo.
              I even was able to place another building into the scene (which by itself is 20 times bigger in file size than the whole city).
              granted, this twisted shape may look a bit alien in the otherwise orthogonal city. understand it as a symbol for SketchUp's unique and inovative workflow amidst loads of other applications with their narrow minded interfaces πŸ˜‰
              http://img512.imageshack.us/img512/4910/bigcityjj4.jpg
              (in the model are 1910 buildings plus the twisted one)
              this city is very basic: 5 different building heights (all based on the same storey component), assembled in 10 different block types.
              just imagine, what wonderful and huge cities you can render if you put in a bit more time and effort to create variations...
                Kenny
                I tried the original model and it started loading but I got a run time error. I've got a pretty good spec too with 4GB Ram and a Core 2 duo E6850 processor.
                Kenny
                http://www.townscapesolutions.co.uk/
                  remus
                  I think a run time error is when it runs out of memory, not sure what would cause it though, if jakob can render it on his machine πŸ˜‰
                    plot-paris
                    dear Kenny, thanks for trying out my model. I would very much like to see, what you can get out of it (for your pc seems to be quite capable πŸ˜‰ )
                    well, I was only able to render the whole model after simplifying the windows...
                    here is that version (without the twisted building though - that is more than 4 Mb filesize)
                    city_simplified.skp
                      plot-paris
                      and here another very quick one - 13 680 golden eggs(even with a cube as proxy very slow in SketchUp). quite fast to export though...
                      (thanks to OnSurface, JPP, ComponentSpray tools - model was set up in a second πŸ˜„ )
                      http://img295.imageshack.us/img295/4810/13680eggsxz3.jpg
                      I hope to find the time to do something more fancy soon...
                        plot-paris
                        this image may not look very interesting. the only purpose was to test out polygon limits of indigo.
                        well, I am tempted to believe there are no limits πŸ˜•
                        one of these forms has more than 55.000 polygons. in this scene I had almost 24.000 instances (low-res proxies in SketchUp, automatically replaced with the original by indigo).
                        that means, that indigo had to handle more than 1.3 Billion! polygons(1.300.000.000) 😲
                        only 60 MB of ram were used by indigo for this very small image (exponentially more, when increasing the file size)...
                        http://img165.imageshack.us/img165/8509/13billionpolygonspp5.jpg
                          chango70
                          Would this work with Vray?
                          • I Offline
                            ilay7k
                            no...only plans
                              plot-paris
                              as far as I know, v-ray doesn't support instancing at present.
                              the most amazing tool about indigo in this case is not only that it allowes instancing, but that you can use a low-poly component as proxy in SketchUp, that are replaced with a high polygon component, when exported to indigo. otherwise you would have no chance to handle such a huge scene in SU...
                              I am not aware of any other render-engine, that does that. πŸ˜•
                              • FrederikF Offline
                                Frederik
                                Correct... πŸ˜‰
                                This is not correct... πŸ˜‰
                                It's not that I want to hi-jack your thread, but I need to correct you since Kerkythea also supports instancing and you can use proxies in SU and replace these with instanced objects in KT... πŸ˜‰
                                Please check out this thread, which is a small step-by-step tutorial I've posted at the KT Forum... πŸ˜‰
                                Cheers
                                Kim Frederik
                                  Jon
                                  In fact, Alex once did a test in KT involving a few billion polygons more than that. πŸ˜‰
                                  These are great tests, plot. Keep it up. πŸ˜„
                                  PS. I though Vue6 could export proxy objects ❓
                                  Does anyone know for sure?
                                  Jon
                                  KT Team member
                                  • soloS Offline
                                    Vue 6 has instancing too.
                                    okay...too slow you just mentioned it.
                                      plot-paris
                                      ah, good to know, that there are biased renderers that support instancing as well. I just have to find the time to learn them 😒
                                      but please, post your tests here as well! I want to see loads and loads of instances πŸ˜„
                                      • soloS Offline
                                        I use Vue quite a lot these days for site overview renders, however I have not yet had the need for instancing, but that is about to change as I need to do an animation of a fly over in the near future that involves a very wooded area and I will need to familiarize myself with this feature soon. as soon As I figure it all out I will post an example and maybe a few screen grabs as to how it works.
                                        If anyone out there is familiar with it and can assist my learning curve I would appreciate that ... Chipp I am looking at you. πŸ˜„
                                          chango70
                                          Does anyone know which one of the other instancing renderer is fasster? Has anyone test the them before?
                                          • soloS Offline
                                            Okay!
                                            That was very easy to figure out actually.
                                            I used the Instancing brush in Vue 6 xstream to paint the SCF logo on a very uneven surface, it was extremely quick and smooth and rendered in 11 minutes.
                                            I am impressed at the ease and simplicity of instancing with Vue.
                                            http://img511.imageshack.us/img511/6914/instancingts8.jpg
                                            • 1 / 4
