    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 185.4k Views 108 Watching
      tomasz
      Moris,
      Thank you very much for this plugin. I believe it will find many applications!
      I haven't tested it yet, but what I have seen in the preview looks VERY promising.
      I will have to add it to SU2KT animation export ๐Ÿ˜„. Now each frame will have to be exported!
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        Shotster
        Will this work on either Windows or Mac?
        • CadFatherC Offline
          CadFather
          Thanks Moris, shall be good fun.. ehm, on holiday ๐Ÿ˜„
          Right on Tomasz, we are waiting for you now!
            kwistenbiebel
            This is amazing ! Thank you very much for this plugin.
            So this actually is object animation for Sketchup right?
            I must try it. It appears to be quite easy to use.
            Now the cheesy question: Will this work with Vray and Indigo to render animations?
            I know making an object animation manually by tweaking the hiding options does not hold in both render apps.....Would be awesome if it could.
              Thank you. Thank you.
              My question, Morris, is this. Can I save the SKP file and send it to someone so they can see the action? Or is there a way to export the animation?
                Daniel S
                Thank you!!! ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                It works Great!!! And the plugin supports position and scale transformations!
                I only have problems with some rotations.. look at the attach video. The simple box is rotated 90ยฐ from the center point but in the animation looks strange.
                Now you can set up to 4 positions. Can you add more?? 4 is not sufficient for this so amazing plugin.
                Thank You!!!
                Daniel S
                rotate video .wmv
                • chrisglasierC Offline
                  chrisglasier
                  @morisdov said:
                  ... full progress of a construction site or assembly procedures... etc
                  Under Way of Working on June 9th I wrote " ... this could mean more Pro versions, more scripts, a new profession of nameset makers, animations in addition to bar charts ..."; so you can imagine I am very happy to see you have come up with this. But unfortuately I cannot open your googlepage from here for some reason; would you be kind enough to upload the zip file or send it to me by PM?
                    digby dart
                    Thank You! Yet another very impressive plug-in. ๐Ÿ˜„
                      bianhai
                      Thank You!!!
                        Jon
                        This looks like a great plugin! ๐Ÿ˜„
                        Jon
                        KT Team member
                        • bigstickB Offline
                          bigstick
                          Any chance of either posting a version of the video we can view on OS X? I get a codec error in Quicktime using the WMV plugin. No Xvid for the Mac AFAIK.
                            morisdov
                            I am glad you like this, now lets see your creativity results.
                            1. this plugin is written only in ruby, so it should be good for both mac & windows.
                            2. when saving your sketchup model the "positions" are saved in it too, so if you email your model to a friend and he downloads this plugin, he should have the same animation functionality.
                            3. this plugin uses the new SU version 6 "observer" class to hook into the "scenes" change, this "observer" is not called by SketchUp "Export -> Animation" so right now you cant standard export this to an AVI - just see it in sketchup.
                              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10926
                              for the mean time hide the axes and use some screen capture utility to export videos.
                            4. later i will add more than 4 positions, start experimenting very slowly.
                            5. Youtube too does not like my wmv9 video - try
                              http://www.metacafe.com/watch/1455250/morisdov_plugin_proper_animation_rb_for_sketchup/
                              the resolution is terrrible but better than nothing
                              i trust you come up with better viedos
                            proper_animation_pics.zip
                              marcosrodrigues
                              Amazing! Thank you!
                              | menos รฉ mais
                                kwistenbiebel
                                @morisdov said:
                                3) this plugin uses the new SU version 6 "observer" class to hook into the "scenes" change, this "observer" is not called by SketchUp "Export -> Animation" so right now you cant standard export this to an AVI - just see it in sketchup.
                                Yes, it would be awesome if that could be supported.
                                Great job on that plugin ๐Ÿ‘
                                • JClementsJ Offline
                                  JClements
                                  Morris:
                                  Great work. I think everyone's hopes have been elevated.
                                  We need to have a way for all .skps using your scripts to have a link embedded that will enable the anyone opening them to easily downloaded and install the proper script.
                                  I suppose it could something as basic as floating text label with instructions if there was not a way to automate the process.
                                  • FrederikF Offline
                                    Frederik
                                    Looks very promissing, but why does the object you animate "shrink" during the animation..?? ๐Ÿ˜•
                                    I.e. a wheel turning on a motorbike will look a bit strange since it constantly change size during the animation... ๐Ÿ˜•
                                    Cheers
                                    Kim Frederik
                                    • Mike LuceyM Offline
                                      Mike Lucey
                                      Morisdov, Wow, this looks amazing and I think the word 'PROPER'
                                      well descibes what you have achieved. This is indeed very generous
                                      of you ๐Ÿ‘
                                      Mike
                                      • erikBE Offline
                                        erikB
                                        Yes, Morisdov great plugin but I also wonder why when rotating (p.e. doors) it isn't rotating but a sort of (as Kim stated)'shrinking, turning and expancing' movement.
                                        greetings,
                                        ErikB
                                          morisdov
                                          please download latest version 1.01 - should fix "shrink" on rotation.
                                          • urgenU Offline
                                            urgen
                                            ....thanks! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                            --pupil forever...------
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
