    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • Alan FraserA
      Alan Fraser
      Excellent work, Dale. The key to decent spherical mapping lies in a combination of triangular faces (no real surprise there) plus enough of them to do the job. Attached is the standard SU sphere which has been given 2 iterations of Subdivide and Smooth to produce much smaller triangles, then a spherical map of the Earth applied. The result is about as good as it gets.
      My sincere compliments.
      I haven't tried it yet, but it may be possible to raise the resolution of the mesh in just the polar regions and achieve pretty much the same result but with far fewer faces.
      globe.skp
      3D Figures
      • K
        kwistenbiebel
        Nice results Alan!
        I wil give the plugin a spin this weekend. Another cool Whaat piece of work.
        • W
          watkins
          Dear Alan,
          Could you give a little tut to show how you map the texture onto the sphere using the various tool? I cannot quite see how it all hangs together.
          Thanks,
          Bob
          • Alan FraserA
            Alan Fraser
            It's fairly straightforward, Bob.
            I imported the sphere from Shapes and exploded it.
            I then applied Subdivide and Smooth with 2 iterations (it maps reasonably well with just 1, but 2 is better)
            I then resized the sphere to exactly 10' diameter...it's a tad larger than that by default.
            I imported the image and exploded it, then edited its height in the Material Editor to match the sphere's diameter.
            I then applied the image, from the Material browser to the sphere.
            I then right-clicked the sphere and chose UV Tools > Spherical from the context menu....and Bingo!
            That's all there is to it.
            3D Figures
            • W
              Whaat
              Resizing the image before using the plugin is an unecessary step. The plugin will always map the image the full height of the sphere and wrap it exactly once around the sphere.
              • Alan FraserA
                Alan Fraser
                Thanks Dale. I should have figured that with no adjustment controls, it would be set to fit. I've only just taken a look now at the code.
                3D Figures
                • W
                  watkins
                  Dear Alan,
                  Many thanks for the detailed explanation. As I wrote somewhere else, I tend not to texture my models, being content with the default shades, and so I haven't built up any skill in this area.
                  Thanks again, and thanks to Dale for another useful script. The model of the globe is really very impressive. I must have a go at Mars.
                  Kind regards,
                  Bob
                  • Alan FraserA
                    Alan Fraser
                    Bob,
                    You'll find some decent planet maps here.
                    http://planetpixelemporium.com/planets.html
                    The individual planets are linked at the bottom of the page.
                    The maps are distorted because in order to fit a sphere the entire top and bottom edges need to come to a single point at either pole, so you'll appreciate that things get progressively stretched as you move away from the equator.
                    You don't need to start from scratch. You can merely open the Earth globe skp, go to the Material browser...In Model, select the Earth texture then in edit mode replace the earth.jpg with one of the planetary ones you download from the above site. It will map automatically.
                    3D Figures
                    • FrederikF
                      Frederik
                      Thanks for both the tut' and the link to the planet texture maps, Alan..!! 😄
                      Much appreciated..!! 👍
                      Cheers
                      Kim Frederik
                      • W
                        watkins
                        Dear Alan,
                        Many thanks for taking the time to post the link. I will have a go at that when I have a moment. I would also to create a background/sky dome simulation of Mars too. The reason for that is we have a couple of projects which involve instruments for Martian atmosphere monitoring, and it would be rather nice to see the lander in a Martian setting. Alternatively, I could get on with some real work.
                        Kind regards,
                        Bob
                        • RichardR
                          Richard
                          i had a play with the plguin and found if i reduced the texture scale just a bit the mapping at the poles tended to clear.
                          Also exported to Maxwell with no issues!!!
                          Whaat again you do some absolutely amazing stuff mate!
                          BUILTBRAND.COM.AU
                          • FletchF
                            Fletch
                            Thank you, Whaat! 😍
                            Fletch
                              silver_shadow
                              hi there. 💭
                              Is it not possible to re write the plugin to see the mapping box,a way to scale the box or edit and maybe include a box mapping too. Similar to what max is doing.But from me to you...congrats..its super so far.
                              • majidM
                                majid
                                i tried the ruby , but there is a problem when exporting to Kerkythea ..... it converts the shape to lots of faces whit lots of textures!!!!!!!!!!!!!! would be it reviewed to solve this problem?
                                yours majid
                                • FrederikF
                                  Frederik
                                  Majid,
                                  Whaat have already provided an answer to this... 😉
                                  @whaat said:
                                  This seems to be an issue with non-triangular faces. If you can somehow triangulate the geometry prior to exporting, then the UVs should still be correct.
                                  My 'Polyreducer' script triangulates all of the faces of a mesh. However, it will also reduce some polys. (The minimum is 10%). Once I triangulated your spheres, I reapplied the spherical mapping and then exported to Indigo. It worked perfect! I expect it to work with other rendering engines as well.
                                  Another script that will triangulate faces is my 'SubD and Smooth' script (but it's not free)
                                  Below is made using the SubD and Smooth script and exported using SU2KT... 😄
                                  Works like a charm...!! 😍
                                  Cheers
                                  Kim Frederik
                                  • N
                                    nektares
                                    indeed, just 5 mins using it and i got this result, works great
                                    and its so easy to use! congratulations.
                                    http://i249.photobucket.com/albums/gg239/nektares/uvmaps.jpg
                                    • T
                                      topmanblue
                                      😍 😍 thank you!!! good!!!
                                      • GaieusG
                                        Just catching up with all the news here...
                                        Great plugin, thanks a lot!
                                        I discovered however that if you want to UV map something on a reversed face, it gives a bugsplat. No worry about this at all though - at least it will teach everyone the lesson; "always orient your faces correctly"! 😉
                                        • K
                                          kwistenbiebel
                                          I would love to be able to UV-map textures like in this example, to go around (smooth)corners:
                                          (Do mind that a displacement map was added.)
                                          'wrap around' mapping?:
                                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/demoscene_stone-01_1-1.jpg
                                          • W
                                            watkins
                                            That lead flashing must have been rather tricky to fit!!
                                            • 3 / 9
