    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • RichardR
      Richard
      i had a play with the plguin and found if i reduced the texture scale just a bit the mapping at the poles tended to clear.
      Also exported to Maxwell with no issues!!!
      Whaat again you do some absolutely amazing stuff mate!
      BUILTBRAND.COM.AU
      • FletchF
        Fletch
        Thank you, Whaat! 😍
        Fletch
          silver_shadow
          hi there. 💭
          Is it not possible to re write the plugin to see the mapping box,a way to scale the box or edit and maybe include a box mapping too. Similar to what max is doing.But from me to you...congrats..its super so far.
          • majidM
            majid
            i tried the ruby , but there is a problem when exporting to Kerkythea ..... it converts the shape to lots of faces whit lots of textures!!!!!!!!!!!!!! would be it reviewed to solve this problem?
            yours majid
            • FrederikF
              Frederik
              Majid,
              Whaat have already provided an answer to this... 😉
              @whaat said:
              This seems to be an issue with non-triangular faces. If you can somehow triangulate the geometry prior to exporting, then the UVs should still be correct.
              My 'Polyreducer' script triangulates all of the faces of a mesh. However, it will also reduce some polys. (The minimum is 10%). Once I triangulated your spheres, I reapplied the spherical mapping and then exported to Indigo. It worked perfect! I expect it to work with other rendering engines as well.
              Another script that will triangulate faces is my 'SubD and Smooth' script (but it's not free)
              Below is made using the SubD and Smooth script and exported using SU2KT... 😄
              Works like a charm...!! 😍
              Cheers
              Kim Frederik
              • N
                nektares
                indeed, just 5 mins using it and i got this result, works great
                and its so easy to use! congratulations.
                http://i249.photobucket.com/albums/gg239/nektares/uvmaps.jpg
                • T
                  topmanblue
                  😍 😍 thank you!!! good!!!
                  • GaieusG
                    Just catching up with all the news here...
                    Great plugin, thanks a lot!
                    I discovered however that if you want to UV map something on a reversed face, it gives a bugsplat. No worry about this at all though - at least it will teach everyone the lesson; "always orient your faces correctly"! 😉
                    • K
                      kwistenbiebel
                      I would love to be able to UV-map textures like in this example, to go around (smooth)corners:
                      (Do mind that a displacement map was added.)
                      'wrap around' mapping?:
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/demoscene_stone-01_1-1.jpg
                      • W
                        watkins
                        That lead flashing must have been rather tricky to fit!!
                        • W
                          Whaat
                          You can already do this to a limited degree in SU by positioning a texture using the right-click context menu. Then, sample that texture with the ink-dropper prior to painting on an adjacent face. The UV mapping will then be continuous around the edge.
                          The sample image you posted can already be done in SU. I am sure of it. I will try to recreate a similar scene using displacement mapping with only SU and Indigo to test my theory.
                          • K
                            kwistenbiebel
                            Oh cool!
                            You weren't referring to the projected method are you?
                            ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
                            • StinkieS
                              Stinkie
                              Like, turning on "hidden geometry", then sample the texture, and paint it on the faces that have appeared due to turning on "hidden geo"? ❓
                              • soloS
                                If you smooth the corners (bevel) and apply that awesome arroway texture, would it not work?
                                • StinkieS
                                  Stinkie
                                  Maybe. Another way, I guess, might be drawing vertical lines between the corner (which would have to be, errrr, "arc-ular" 😄 )and the walls it connects. Then use cylindrical mapping on the "corner part". You'd have to sample the texture from the "corner" part prior to painting it to the rest of the walls, I think, as Whaat's plugin seems to mess alittle with the scale of the textures. Hope this makes sense.
                                  • soloS
                                    I do not have the right texture, however the one I used should do, I used standard SU mapping (not projected) and got the following result.
                                    http://img242.imageshack.us/img242/6005/smoothtextestok7.jpg
                                    http://img518.imageshack.us/img518/7982/2008062116515420spx5.jpg
                                    • StinkieS
                                      Stinkie
                                      Looks good. Another problem solved. 👍
                                      • K
                                        kwistenbiebel
                                        Thanks my friends.
                                        So the easiest texturing tool of all takes care of this. Sometimes Sketchup surprises me 😄
                                        • W
                                          Whaat
                                          Here's the test I promised.
                                          I only used the built-in SU texture tools as I described in previous post.
                                          Rendered in Indigo 1.1.5 using displacement mapping. Current beta version of SkIndigo may not produce this same result. (This is my unreleased working version)
                                          One extra step that I had to do to keep the edge from 'ripping' apart with the displacement mapping was to 'soften' the edges first in SU.
                                          EDIT: I also should point out that I did not bevel or round the edges at all to get this result.
                                          • StinkieS
                                            Stinkie
                                            Cool. The "soften" thing's a good tip! Thanks.
                                            • 3 / 9
