    [Plugin] Global_Material_Change
    19 Posts 16 Posters 15.2k Views 16 Watching
    • TIGT Online
      This script [Global_Material_Change.rb] works on everything in a selection [or if there is no selection it uses all active entities]...
      You can choose any material that's loaded in the model to be replaced - you can also choose <Default>, or << ALL >> - 'ALL' will change all materials in the selection to the new one - that's useful if you want to remove all materials from something and go for say the <Default> material to replace it... You can likewise choose any 'new' material from those currently available. You are warned about processing 'ALL' materials and also 'ALL' active entities...
      The end result is everything in the selection (or active_entities) that uses the chosen material is globally changed to the chosen new one. I works on entities, groups or component definitions - mining down into them to change any nested things too...
      It's one step undoable...
      PayPalButton
        mateo soletic
        Tig
        Thanks a lot, I just tried it , Great script. 👍
        Concept Illustrations
          Matt666
          Hi Tig !
          Excellent Plug-in !!
          I have translated it in French language...
          I tried to create similar script... It works differently, and I have some problems...
          1- Select a face with the old texture
          2- Choose the new texture in the 'paint' palette
          3- Apply "Add to the model" in the right click context menu in the palette
          4- Run the script.
          The third stage is a problem. I can't add the texture directly with the code... And if you don't do that, the texture is not saved. Do you have any method ??
          #Replace texture definition of a face with the active texture in the palette
          def process_textures(entities, anctxt, newtxt)
          	entities.each do |entity|
          		case entity.typename
          		when 'Group'
          			process_textures entity.entities, anctxt, newtxt
          		when 'ComponentInstance'
          			if entity.material == anctxt
          					entity.material = newtxt
          			edef = entity.definition
          			process_textures edef.entities, anctxt, newtxt
          		when 'Face'
          			if entity.back_material == anctxt
          					entity.back_material = newtxt
          def reptxt
          	model = Sketchup.active_model
          	ss = model.selection
          	model.start_operation "Remplacer textures"
          	if model.materials.current !=nil
          		active_material = model.materials.current.name
          		puts "Texture active = " + active_material
          		if ss.empty?
          			UI.messagebox("Aucune selection.")
          			return nil
          		else
          			ent = ss[0]
          			if ent.typename == "Face"
          				puts "\nL'entité sélectionnée est de type Face."
          				if ent.material !=nil
          					process_textures model.active_entities, ent.material, active_material
          					model.commit_operation
          			else
          				UI.messagebox("\nL'entité sélectionnée n'est pas de type Face (" + ss[0].typename + ").")
          	else
          		UI.messagebox("Aucune texture active.")
          		return nil
          if not file_loaded?("reptxt.rb")
          	UI.menu("Plugins").add_item("Replace texture definition"){reptxt}
          Thank you !
          fr_Global_Material_Change.rb
          Frenglish at its best !
          My scripts
          • PixeroP Offline
            Pixero
            Thanks, I know I'll have great use of it.
            • TIGT Online
              Here's v1.1...
              Usage:
              1. Select entities.
                [IF there's no selection ALL active entities are used]
              2. Activate the script from the Plugins Menu.
              3. Choose Old Material [to be replaced].
                [<< DEFAULT >>=NO Material, << ALL >>=ALL Materials &
                then Alphabetical list]
              4. Choose the desired New Material.
                [<< DEFAULT >> = No Material]
                To access Materials that are off the visible list type the first letter - e.g. 'W' and use up/down arrow-keys to move to the one you want e.g. 'W'hite...
              History:
              1.0 20080522 First issue.
              1.1 20080523 Lists alphabetical & guidance on arrows.
              Progress 'ticker' added...
              • CadFatherC Offline
                CadFather
                Thank you TIG - i'll give it a try - it's a plug in i've been thinking about for some time.. 😛
                  Julius
                  really useful!
                  • JClementsJ Offline
                    JClements
                    So far, so good. I can see it being a big time saver.
                    Thanks, John
                    • boofredlayB Offline
                      boofredlay
                      Very useful, thanks.
                      • plot-parisP Offline
                        plot-paris
                        may be I am stupid. but I cant find the ruby (I pasted it in the SketchUp Plugin folder. but it doesn't show up in the plugins window (neither does it in any context menu or the paint bucket window)...
                        is there something I dont know?
                          boofredlay
                          Here it is on my screen.
                            plot-paris
                            thanks Boofredlay,
                            I deleted it, copied it in the pluginsfolder again and it worked... no idea what happend.
                            now it shows up in the plugins tool bar and is doing a great job! 😍
                              perk
                              Thanks Tig
                              Huge time saver!!
                                Dan
                                My thanks too, Tig!
                                Very useful script.
                                  Morpeth
                                  very useful.. ☀
                                    sepo
                                    Thanks.. It works like charm.
                                      bassie
                                      Just what I needed. Thanks!!
                                      • X Offline
                                        xrok1
                                        bravo!!
                                        • F Offline
                                          fewltu
                                          Thank you so much!!! This is a huge help to me for setting up renderings for export. One huge improvement I would suggest is the ability to select multiple "old" materials to be replaced with one "new" material all at once. Thanks again!
