    Select last entity
    18 Posts 6 Posters 3.3k Views 6 Watching
    • david_hD
      david_h
      okay. . . je suis perdu . . .comment ca marche? 😕
      • Didier BurD
        Didier Bur
        David,
        Just wait until me or Matt makes it a usable script.
        If you can't wait, 🎉 open the ruby console and when you need to select last entity drawn or inserted, type "entlast" (no quotes).
        DB
          rhankc
          David,
          Last year RickW(http://www.sketchucation.com/forums/scf/memberlist.php?mode=viewprofile&u=370) wrote Selection Memory 2. Fantastic tool. Definite must have.
          Hank
            Matt666
            Hi !
            Here's the code !
            entlast.rb
            Frenglish at its best !
            My scripts
            • david_hD
              david_h
              @rhankc said:
              David,
              %(#0040FF)[yeah . .that's the one I was referring to. Got it. Thanks! 😄]
              Didier and Matt!. . .Merci Mille Fois! I will give this one a test drive.
              %(#801000)[Just as a side note, at the 05 basecamp I went to the Ruby Scripting class to hopefully learn somewhat how to do it. Was totally blown out of the room. So I am glad there are you guys around for us dum dums. 💚]
              • david_hD
                david_h
                works great. Thank you!
                • Didier BurD
                  Didier Bur
                  Here is another one, with context menu. Adds last entity to selection or select last entity only.
                  entlast.rb
                  DB
                    RickW
                    You could also create this as a method for the Entities and Selection classes:
                    class Sketchup;;Entities
                     def last
                      return self[-1]
                    end #class
                    class Sketchup;;Selection
                     def lastent
                      add Sketchup.active_model.entities.last
                     def lastentonly
                      clear
                    end #class
                    then add your user interface/dialog/menu item, whatever.
                    This also allows the methods to be called by other scripts in a predictable manner.
                    RickW
                    www.smustard.com
                      Matt666
                      Wouah !!
                      I wanted to do same thing but I but I didn't know how to...
                      How can you do that : Sketchup.active_model.entlast please ???
                      My scripts
                        Matt666
                        Like that ?
                        class Sketchup;;Model
                        	def entlast
                        		nb = self.active_entities.length
                        		return self.active_entities[nb-1]
                        My scripts
                          RickW
                          Or like this:
                          def entlast
                            return entities[-1]
                          end #class
                          Using entities or active_entities depends on whether you want the absolute last entity created, or the last entity created in that space (ie within a group or component).
                          RickW
                          www.smustard.com
                            msaryyev
                            This is quite useful for selecting the last object extension. Could there be a variation of this that selects and zooms into the last object?
