    Select last entity
    18 Posts 6 Posters 3.2k Views 6 Watching
    • Didier BurD Offline
      Didier Bur
      David,
      Just wait until me or Matt makes it a usable script.
      If you can't wait, 🎉 open the ruby console and when you need to select last entity drawn or inserted, type "entlast" (no quotes).
      DB
        rhankc
        David,
        Last year RickW(http://www.sketchucation.com/forums/scf/memberlist.php?mode=viewprofile&u=370) wrote Selection Memory 2. Fantastic tool. Definite must have.
        Hank
          Matt666
          Hi !
          Here's the code !
          entlast.rb
          Frenglish at its best !
          My scripts
          • david_hD Offline
            david_h
            @rhankc said:
            David,
            %(#0040FF)[yeah . .that's the one I was referring to. Got it. Thanks! 😄]
            Didier and Matt!. . .Merci Mille Fois! I will give this one a test drive.
            %(#801000)[Just as a side note, at the 05 basecamp I went to the Ruby Scripting class to hopefully learn somewhat how to do it. Was totally blown out of the room. So I am glad there are you guys around for us dum dums. 💚]
            • david_hD Offline
              david_h
              works great. Thank you!
                Didier Bur
                Here is another one, with context menu. Adds last entity to selection or select last entity only.
                entlast.rb
                DB
                  RickW
                  You could also create this as a method for the Entities and Selection classes:
                  class Sketchup;;Entities
                   def last
                    return self[-1]
                  end #class
                  class Sketchup;;Selection
                   def lastent
                    add Sketchup.active_model.entities.last
                   def lastentonly
                    clear
                  end #class
                  then add your user interface/dialog/menu item, whatever.
                  This also allows the methods to be called by other scripts in a predictable manner.
                  RickW
                  www.smustard.com
                    Matt666
                    Wouah !!
                    I wanted to do same thing but I but I didn't know how to...
                    How can you do that : Sketchup.active_model.entlast please ???
                    My scripts
                      Matt666
                      Like that ?
                      class Sketchup;;Model
                      	def entlast
                      		nb = self.active_entities.length
                      		return self.active_entities[nb-1]
                      My scripts
                        RickW
                        Or like this:
                        def entlast
                          return entities[-1]
                        end #class
                        Using entities or active_entities depends on whether you want the absolute last entity created, or the last entity created in that space (ie within a group or component).
                        RickW
                        www.smustard.com
                          msaryyev
                          This is quite useful for selecting the last object extension. Could there be a variation of this that selects and zooms into the last object?
