    Select last entity
    18 Posts 6 Posters 3.5k Views 6 Watching
    • david_hD
      david_h
      M. Didier. .. If there is anyone in the universe who could figure this out, it would be you. So, Hopefully. . ..
      I was thinking. . .a script that Selects last, or Selects previous would be awesome. I have the Seelction Memorize tool and that works okay mosto f the time, but . .. anyway, think about it.
      Thx
      D
        Matt666
        Or (ssget "_p"), or tool "select", and Key "P" (in AutoCAD)...
        You could do smth Perhaps with the last entity in the active entities selection list ?
        def entlast
        	model = Sketchup.active_model
        	sel = model.active_entities
        	ss = model.selection
        	n = sel.length - 1
        	ss.add(sel[n])
        I have not tested yet...
        Frenglish at its best !
        My scripts
        • Didier BurD
          Didier Bur
          He Matt ça marche !!! (Hey it works !)
          DB
            Matt666
            My scripts
            • david_hD
              david_h
              okay. . . je suis perdu . . .comment ca marche? 😕
              • Didier BurD
                Didier Bur
                David,
                Just wait until me or Matt makes it a usable script.
                If you can't wait, 🎉 open the ruby console and when you need to select last entity drawn or inserted, type "entlast" (no quotes).
                DB
                  rhankc
                  David,
                  Last year RickW(http://www.sketchucation.com/forums/scf/memberlist.php?mode=viewprofile&u=370) wrote Selection Memory 2. Fantastic tool. Definite must have.
                  Hank
                    Matt666
                    Hi !
                    Here's the code !
                    entlast.rb
                    My scripts
                    • david_hD
                      david_h
                      @rhankc said:
                      David,
                      %(#0040FF)[yeah . .that's the one I was referring to. Got it. Thanks! 😄]
                      Didier and Matt!. . .Merci Mille Fois! I will give this one a test drive.
                      %(#801000)[Just as a side note, at the 05 basecamp I went to the Ruby Scripting class to hopefully learn somewhat how to do it. Was totally blown out of the room. So I am glad there are you guys around for us dum dums. 💚]
                      • david_hD
                        david_h
                        works great. Thank you!
                        • Didier BurD
                          Didier Bur
                          Here is another one, with context menu. Adds last entity to selection or select last entity only.
                          entlast.rb
                          DB
                            RickW
                            You could also create this as a method for the Entities and Selection classes:
                            class Sketchup;;Entities
                             def last
                              return self[-1]
                            end #class
                            class Sketchup;;Selection
                             def lastent
                              add Sketchup.active_model.entities.last
                             def lastentonly
                              clear
                            end #class
                            then add your user interface/dialog/menu item, whatever.
                            This also allows the methods to be called by other scripts in a predictable manner.
                            RickW
                            www.smustard.com
                              Matt666
                              Wouah !!
                              I wanted to do same thing but I but I didn't know how to...
                              How can you do that : Sketchup.active_model.entlast please ???
                              My scripts
                                Matt666
                                Like that ?
                                class Sketchup;;Model
                                	def entlast
                                		nb = self.active_entities.length
                                		return self.active_entities[nb-1]
                                My scripts
                                  RickW
                                  Or like this:
                                  def entlast
                                    return entities[-1]
                                  end #class
                                  Using entities or active_entities depends on whether you want the absolute last entity created, or the last entity created in that space (ie within a group or component).
                                  RickW
                                  www.smustard.com
                                    msaryyev
                                    This is quite useful for selecting the last object extension. Could there be a variation of this that selects and zooms into the last object?
