    Select last entity
    18 Posts 6 Posters 3.3k Views 6 Watching
    • david_hD
      david_h
      Is anyone aware of a selection ruby that allows one to select the Last Entity Drawn or Placed? similar to the selection option in . .. dare I say it. . .Autocad?
      Thx,
      David
      • Didier BurD
        Didier Bur
        I wonder if it would be possible in Ruby to get the equivalent of "entlast" in Autolisp ???
        I guess no 👎
        DB
        • david_hD
          david_h
          M. Didier. .. If there is anyone in the universe who could figure this out, it would be you. So, Hopefully. . ..
          I was thinking. . .a script that Selects last, or Selects previous would be awesome. I have the Seelction Memorize tool and that works okay mosto f the time, but . .. anyway, think about it.
          Thx
          D
            Matt666
            Or (ssget "_p"), or tool "select", and Key "P" (in AutoCAD)...
            You could do smth Perhaps with the last entity in the active entities selection list ?
            def entlast
            	model = Sketchup.active_model
            	sel = model.active_entities
            	ss = model.selection
            	n = sel.length - 1
            	ss.add(sel[n])
            I have not tested yet...
            Frenglish at its best !
            My scripts
            • Didier BurD
              Didier Bur
              He Matt ça marche !!! (Hey it works !)
              DB
                Matt666
                My scripts
                • david_hD
                  david_h
                  okay. . . je suis perdu . . .comment ca marche? 😕
                  • Didier BurD
                    Didier Bur
                    David,
                    Just wait until me or Matt makes it a usable script.
                    If you can't wait, 🎉 open the ruby console and when you need to select last entity drawn or inserted, type "entlast" (no quotes).
                    DB
                      rhankc
                      David,
                      Last year RickW(http://www.sketchucation.com/forums/scf/memberlist.php?mode=viewprofile&u=370) wrote Selection Memory 2. Fantastic tool. Definite must have.
                      Hank
                        Matt666
                        Hi !
                        Here's the code !
                        entlast.rb
                        My scripts
                        • david_hD
                          david_h
                          @rhankc said:
                          David,
                          %(#0040FF)[yeah . .that's the one I was referring to. Got it. Thanks! 😄]
                          Didier and Matt!. . .Merci Mille Fois! I will give this one a test drive.
                          %(#801000)[Just as a side note, at the 05 basecamp I went to the Ruby Scripting class to hopefully learn somewhat how to do it. Was totally blown out of the room. So I am glad there are you guys around for us dum dums. 💚]
                          • david_hD
                            david_h
                            works great. Thank you!
                            • Didier BurD
                              Didier Bur
                              Here is another one, with context menu. Adds last entity to selection or select last entity only.
                              entlast.rb
                              DB
                                RickW
                                You could also create this as a method for the Entities and Selection classes:
                                class Sketchup;;Entities
                                 def last
                                  return self[-1]
                                end #class
                                class Sketchup;;Selection
                                 def lastent
                                  add Sketchup.active_model.entities.last
                                 def lastentonly
                                  clear
                                end #class
                                then add your user interface/dialog/menu item, whatever.
                                This also allows the methods to be called by other scripts in a predictable manner.
                                RickW
                                www.smustard.com
                                  Matt666
                                  Wouah !!
                                  I wanted to do same thing but I but I didn't know how to...
                                  How can you do that : Sketchup.active_model.entlast please ???
                                  My scripts
                                    Matt666
                                    Like that ?
                                    class Sketchup;;Model
                                    	def entlast
                                    		nb = self.active_entities.length
                                    		return self.active_entities[nb-1]
                                    My scripts
                                      RickW
                                      Or like this:
                                      def entlast
                                        return entities[-1]
                                      end #class
                                      Using entities or active_entities depends on whether you want the absolute last entity created, or the last entity created in that space (ie within a group or component).
                                      RickW
                                      www.smustard.com
                                        msaryyev
                                        This is quite useful for selecting the last object extension. Could there be a variation of this that selects and zooms into the last object?
