    Select last entity
    18 Posts 6 Posters 3.2k Views 6 Watching
    • david_hD Offline
      david_h
      Is anyone aware of a selection ruby that allows one to select the Last Entity Drawn or Placed? similar to the selection option in . .. dare I say it. . .Autocad?
      Thx,
      David
      • Didier BurD Offline
        Didier Bur
        I wonder if it would be possible in Ruby to get the equivalent of "entlast" in Autolisp ???
        I guess no 👎
        DB
        • david_hD Offline
          david_h
          M. Didier. .. If there is anyone in the universe who could figure this out, it would be you. So, Hopefully. . ..
          I was thinking. . .a script that Selects last, or Selects previous would be awesome. I have the Seelction Memorize tool and that works okay mosto f the time, but . .. anyway, think about it.
          Thx
          D
            Matt666
            Or (ssget "_p"), or tool "select", and Key "P" (in AutoCAD)...
            You could do smth Perhaps with the last entity in the active entities selection list ?
            def entlast
            	model = Sketchup.active_model
            	sel = model.active_entities
            	ss = model.selection
            	n = sel.length - 1
            	ss.add(sel[n])
            I have not tested yet...
            Frenglish at its best !
            My scripts
              Didier Bur
              He Matt ça marche !!! (Hey it works !)
              DB
                Matt666
                My scripts
                • david_hD Offline
                  david_h
                  okay. . . je suis perdu . . .comment ca marche? 😕
                    Didier Bur
                    David,
                    Just wait until me or Matt makes it a usable script.
                    If you can't wait, 🎉 open the ruby console and when you need to select last entity drawn or inserted, type "entlast" (no quotes).
                    DB
                      rhankc
                      David,
                      Last year RickW(http://www.sketchucation.com/forums/scf/memberlist.php?mode=viewprofile&u=370) wrote Selection Memory 2. Fantastic tool. Definite must have.
                      Hank
                        Matt666
                        Hi !
                        Here's the code !
                        entlast.rb
                        My scripts
                        • david_hD Offline
                          david_h
                          @rhankc said:
                          David,
                          %(#0040FF)[yeah . .that's the one I was referring to. Got it. Thanks! 😄]
                          Didier and Matt!. . .Merci Mille Fois! I will give this one a test drive.
                          %(#801000)[Just as a side note, at the 05 basecamp I went to the Ruby Scripting class to hopefully learn somewhat how to do it. Was totally blown out of the room. So I am glad there are you guys around for us dum dums. 💚]
                          • david_hD Offline
                            david_h
                            works great. Thank you!
                              Didier Bur
                              Here is another one, with context menu. Adds last entity to selection or select last entity only.
                              entlast.rb
                              DB
                                RickW
                                You could also create this as a method for the Entities and Selection classes:
                                class Sketchup;;Entities
                                 def last
                                  return self[-1]
                                end #class
                                class Sketchup;;Selection
                                 def lastent
                                  add Sketchup.active_model.entities.last
                                 def lastentonly
                                  clear
                                end #class
                                then add your user interface/dialog/menu item, whatever.
                                This also allows the methods to be called by other scripts in a predictable manner.
                                RickW
                                www.smustard.com
                                  Matt666
                                  Wouah !!
                                  I wanted to do same thing but I but I didn't know how to...
                                  How can you do that : Sketchup.active_model.entlast please ???
                                  My scripts
                                    Matt666
                                    Like that ?
                                    class Sketchup;;Model
                                    	def entlast
                                    		nb = self.active_entities.length
                                    		return self.active_entities[nb-1]
                                    My scripts
                                      RickW
                                      Or like this:
                                      def entlast
                                        return entities[-1]
                                      end #class
                                      Using entities or active_entities depends on whether you want the absolute last entity created, or the last entity created in that space (ie within a group or component).
                                      RickW
                                      www.smustard.com
                                        msaryyev
                                        This is quite useful for selecting the last object extension. Could there be a variation of this that selects and zooms into the last object?
