    [Plugin] SketchyBevel 0.1(Updated May 11)
    142 Posts 84 Posters 124.2k Views 84 Watching
      CPhillips
      May 11 update.
      -Fixed hang bug if input box canceled.
      -Beveling now works inside of groups and components.
      -Bevel amount should now be in the set unit format (meters, cm, feet, etc)
      -Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
      301 Moved Permanently
      (www.sketchucation.com)
        remus
        Cheers chris, good to see cotinued development 😄
        • utilerU Offline
          utiler
          champion, Chris!!!
          Just Curious...
          • erikBE Offline
            erikB
            Thanks very much for the input in metric. !!
            erikB
              mike d
              thanks chris
              The grass is always GREENER on the roof.
              • CadFatherC Offline
                CadFather
                fantastic, i used to get some persistent error message at times - end task being the only way out - i'll report if any.. Thank You
                now i bevel just about anything.. 🤓
                  bubbalove
                  This may be a dumb question but when I try to download the file I keep getting it in text format... do I just the delete the .txt from the end of it or just put it in the script folder and it knows what to do? Ohh.. and I am using Safari as my internet browser.
                  "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                    remus
                    You'll need to change the file extension to .rb for it to work. Not sure why its downloading it as a .txt though 😉 perhaps some of the more apple savy have an answer?
                      bubbalove
                      Figured it out... for some reason Safari downloads it as a txt file for some reason. Worked like a charm in IE even though I don't like using IE. Thanks Remus!
                      • soloS Offline
                        I use safari on my Mac and .rb's save normally, must be a setting.
                          bubbalove
                          I looked at my preferences... everything is the way it is supposed to be. Maybe it is because I'm using Safari on Windows or something. Do they automatically save to your desktop or does it give you an option on where you want to save it?
                          • soloS Offline
                            Yup to the desktop unfortunately, I hardly use the Mac so it's no big deal really. every now and again I have to clean it all up as I run out of space on desktop.
                              REGIS
                              with safari 2 it saves on the desktop but with safari 3 and 10.5 it saves where you want and you can check this in safari's preferences
                              Never tried safari 3 with 10.4
                                rzadwg
                                woah, awesome, cheers for this one. its gunna save me a lot of time!
                                • JClementsJ Offline
                                  JClements
                                  The bevel to the top surface (red) should be "concave" shouldn't it?PNG image
                                  Sketchy Bevel with v0-1.skp
                                    CPhillips
                                    Its a known bug. I haven't figured out how to detect those faces yet. You can fix it by erasing the face and redrawing it using a clockwise line.
                                    • W Offline
                                      Whaat
                                      As I was playing around with my own beveling script, I found this method to be useful:
                                      edge.reversed_in?(face)
                                      The EdgeUse class also has some useful methods that may help fix this bug.
                                      Great script, BTW
                                        CPhillips
                                        I'll try that. Thanks Whaat!
                                        BTW. I understand you lost your bevel script in a HD crash. SketchyBevel was almost doomed as well. My Ruby editor crashed (the only time in years of use) taking the only version of the almost finished plugin with it. Nothing was left. I was despondent. But I manage to pull a half digested version of the Ruby code out of a Sketchup core dump. Whew! I would have never had the strength to redo the code without that.
                                        • Y Offline
                                          Yup_done
                                          DELETED FOR BREVITY
                                          We're all in your debt for that heroic effort.
                                          Has NBC heard of you yet? Maybe a spinoff of
                                          heroes...
                                          Heroes... The CAD team?
                                          Saving the world, one bezel at a time!? 🤣
                                          Your efforts are appreciated by all who don't dare put words to paper...
                                          errr.. make that:
                                          font to blog 😲
                                            twharvey
                                            Super useful!!
                                            Thanks a million.
                                            Tom
                                            Tom
                                            • 5 / 8
