    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 28.7k Views 49 Watching
      Fredo, this is just crazy. You guys open new horizons in SU (they should simply concentrate on the core engine now).
      A question: what do you mean by "Drepa on surface"? The Sandbox Drape tool is already applied on a surface!
      Another question; how about a texture positioning (with multiple pins and the ability to dustort the image) on surface? All those organic modelers (like kwistenbiebel) are crying for something like that! ๐Ÿ˜‰
        johnsenior1973
        Awesome. Thanks so much for making fantastic improvments to Sketchup.
          matt77
          Top stuff... thank you....
          very impressive....
          all the best
          matt
          • fredo6F Offline
            @gaieus said:
            A question: what do you mean by "Drape on surface"? The Sandbox Drape tool is already applied on a surface!
            Unlike the native Sandbox, DrapeOnSurface would not use projection, but reconstruction of geometry on the surface with respect of distance. Typically, you should be able to draw text (or any shape) fully around a cylinder (and possibly extrude it with JPP).
            DrapeOnSurface is also an easier way to produce drawings on Surface. Actually, you draw on a plane (where you have all Sketchup tools and can be accurate), and then you drape on the surface.
            Interesting idea, but it would need to be described in more details
            • soloS Offline
              Fredo, your offset tools are amazing, this recent one is just crazy, I can do things with SU that I only was able to with MOI and such.
              Thanks a bunch,
              "My skills are not improving, it's my tools that are"
              • soloS Offline
                If I may make a request for a 'draping' tool that can drape over a group. (let me try explain)
                Say you have a table component and you want a cloth to drape over it, you lock the table component and you create a mesh above it, you then select all connected of the mesh and click on (lets say) "Cloth" button and the mesh drops down stopping at the locked component surface and any parts of the mesh that overlaps the table drapes vertically down.
                Would this be possible?
                • H Offline
                  HFM
                  You are saving lives and time here, thanks a bunch ๐Ÿ‘
                  • soloS Offline
                    Just gave me another toy, I mean tool. ๐Ÿ‘
                    3 minutes to make.
                    http://img174.imageshack.us/img174/9439/crackedupyc4.jpg
                    • erikBE Offline
                      erikB
                      fredo,this is unbelievable, but drawing lines on surfaces is just the tool I needed !!!!
                      What can I say, thanks veryyyyyyyy much. ๐Ÿ˜
                      erikB
                        remus
                        always nice to come home to another plugin, especially a surprise one. Cheers fred, keep up the good work.
                          Daniel S
                          Awesome like always!!! ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                          Thank You!!!
                          Daniel S
                            remus
                            http://farm4.static.flickr.com/3151/2486502204_190c833716_o.jpg
                            if you squint a lot it almost looks like the great wall fo china ๐Ÿ‘
                            Anywya, it was 5 mins and made entirely using ferd06 plugins.
                            p.s. i reckon theres reasonable call for having a seperate menu in SU called fred06 ๐Ÿ˜„
                              remus
                              Wheres the file macs?
                                Macs
                                ops, I've lost the attachment on previous post.. now it's there
                                  Macs
                                  Hi Fredo! Your tools are fantastic! ๐Ÿ‘
                                  I think i found a problem while I was playing with the line tool:
                                  I've attcached this simple model
                                  draw a plane line with your tool from the lower vertex of the segment
                                  up in vertical. The result line will be connected to the upper circle
                                  and not to the starting vertex.
                                  The same does not happen with the costruction line.
                                  cylinder.skp
                                  • I Offline
                                    ilay7k
                                    Wonderful magic of tools, thank you!!!
                                    • fredo6F Offline
                                      I am not totally clear on what happened to you.
                                      What is sure is that when the surfaces contains planes which are perpendicular, the interpretation of a path on the surface is always ambiguous.
                                      • MALAISEM Offline
                                        MALAISE
                                        ๐Ÿ˜ Ausgezeichnet, excellent, great what y've done.
                                        MALAISE
                                        La Connaissance n'a de valeur que partagรฉe
                                        • fredo6F Offline
                                          3 minutes to make.
                                          Solo,
                                          very nice illustration of what you can do by combining JPP and the Tools on Surface.
                                          Would you mind if I take the picture and put it in the documentation?
                                            Macs
                                            Here 2 images of what I'm tring
                                            first one select plane tool and tring to draw a verical line, before mouse click
                                            second one is what i get after the mouse click
                                            • 3 / 5
