    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 32.7k Views 49 Watching
    • soloS Offline
      Fredo, your offset tools are amazing, this recent one is just crazy, I can do things with SU that I only was able to with MOI and such.
      Thanks a bunch,
      "My skills are not improving, it's my tools that are"
      • soloS Offline
        If I may make a request for a 'draping' tool that can drape over a group. (let me try explain)
        Say you have a table component and you want a cloth to drape over it, you lock the table component and you create a mesh above it, you then select all connected of the mesh and click on (lets say) "Cloth" button and the mesh drops down stopping at the locked component surface and any parts of the mesh that overlaps the table drapes vertically down.
        Would this be possible?
        • H Offline
          HFM
          You are saving lives and time here, thanks a bunch πŸ‘
          • soloS Offline
            Just gave me another toy, I mean tool. πŸ‘
            3 minutes to make.
            http://img174.imageshack.us/img174/9439/crackedupyc4.jpg
            • erikBE Offline
              erikB
              fredo,this is unbelievable, but drawing lines on surfaces is just the tool I needed !!!!
              What can I say, thanks veryyyyyyyy much. 😍
              erikB
                remus
                always nice to come home to another plugin, especially a surprise one. Cheers fred, keep up the good work.
                  Daniel S
                  Awesome like always!!! 😍 😍 😍
                  Thank You!!!
                  Daniel S
                    remus
                    http://farm4.static.flickr.com/3151/2486502204_190c833716_o.jpg
                    if you squint a lot it almost looks like the great wall fo china πŸ‘
                    Anywya, it was 5 mins and made entirely using ferd06 plugins.
                    p.s. i reckon theres reasonable call for having a seperate menu in SU called fred06 πŸ˜„
                      remus
                      Wheres the file macs?
                        Macs
                        ops, I've lost the attachment on previous post.. now it's there
                          Macs
                          Hi Fredo! Your tools are fantastic! πŸ‘
                          I think i found a problem while I was playing with the line tool:
                          I've attcached this simple model
                          draw a plane line with your tool from the lower vertex of the segment
                          up in vertical. The result line will be connected to the upper circle
                          and not to the starting vertex.
                          The same does not happen with the costruction line.
                          cylinder.skp
                          • I Offline
                            ilay7k
                            Wonderful magic of tools, thank you!!!
                            • fredo6F Offline
                              I am not totally clear on what happened to you.
                              What is sure is that when the surfaces contains planes which are perpendicular, the interpretation of a path on the surface is always ambiguous.
                              • MALAISEM Offline
                                MALAISE
                                😍 Ausgezeichnet, excellent, great what y've done.
                                MALAISE
                                La Connaissance n'a de valeur que partagΓ©e
                                • fredo6F Offline
                                  3 minutes to make.
                                  Solo,
                                  very nice illustration of what you can do by combining JPP and the Tools on Surface.
                                  Would you mind if I take the picture and put it in the documentation?
                                    Macs
                                    Here 2 images of what I'm tring
                                    first one select plane tool and tring to draw a verical line, before mouse click
                                    second one is what i get after the mouse click
                                    • fredo6F Offline
                                      Macs,
                                      I understand. This is due to a problem in Sketchup when you create a curve made of edges on an existing edge (you can check this is the case when you generate in a group and then explode). I'll try to fix it.
                                      By default, the script generates curves for each line drawn. If you deactivate this option (key F9), it works correctly.
                                      • soloS Offline
                                        Absolutely fred.
                                          mateo soletic
                                          Fred, Thanks a lot, great tool.πŸ‘
                                          Concept Illustrations
                                          • MarianM Offline
                                            Marian
                                            😍 REALLY COOOL TOOL
                                            • 1 / 5
