    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.2k Views 153 Watching
      dolphus
      Thanx Rremus it is working now 😍
        dolphus
        thanx gren Toaster i will start workijng with it and let you know how i progress 👍
        • FletchF
          Fletch
          Thanks for the update with locking edges, Chris! A thousand blessings upon you for your work and generosity to this community!
          Fletch
            remus
            Hey chris, would it be possible to incorporate a subdivision element in to FFD? i reckon itd be really useful to be able to subdivide geometry before using FD, as you often dont get good results otherwise.
            No pressure though, im sure i cna manage using whaats subd for the moment 😛
              remus
              Wow, this is liek on demand ruby! cheers chris, im sure this will be even more useful than it was before!
                Daniel S
                Thank you Chris!!! 😄 😄 It´s fantastic!!!
                A bug... the 2x2 FFD or 3x3FFD is not working:
                Error: #<ArgumentError: wrong number of arguments(2 for 3)>
                C:/Archivos de programa/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13:in startFFD' C:/Archivos de programa/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13 C:/Archivos de programa/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13:in call'
                Daniel S
                • C
                  CPhillips
                  Daniel S
                  Ooops. Fixed now.
                  • C
                    CPhillips
                    Alright. Now when you do a NxN there is an option to subdivide.
                    See first post for download link.
                    • K
                      kwistenbiebel
                      Chris,
                      You're Da Man! 😎
                      Kudos! 👍
                      • C
                        CPhillips
                        Updated with another bug fix.
                          Daniel S
                          The new added option to subdivide the mesh when doing a NxN deformation it´s amazing! 😍 😍
                          Only this feature can be a standalone plugin by itself 😍
                          Thank you,
                          Daniel S
                          • CadFatherC
                            CadFather
                            THIS IS INSANE! 😍
                              REGIS
                              Thanks Cphilllips.
                              Your pluggin is excellent.
                              I agree with Daniel S for a standalone plufin who can do that subdivide plugin request
                              subdivid plugin request
                              I would like to have the option to subdivide a loop in sketchup, really it'll be very cool.
                              Thanks a lot for your hardwork
                              • JClementsJ
                                JClements
                                Interesting results by subdividing the top surface of the cylinder first before apply FFD. I was surprised that a convcave cone was not formed; however, the "symetrical wavey pattern" is nice. I'm not sure why the one surface/facet of the cyliner got flipped.
                                ********* One minor enhancement might be to the name the FFD point group automatically, for instance "FFD Point Group". This could help in selecting the FFD group via the Outliner.
                                Thanks for the great work Chris. You script has evolved nicely.
                                Regards, John
                                  REGIS
                                  Hi Jclements
                                  The question : Where can I find the Dale Martin's plugin "subivide selection" ❓
                                  I've made a google search and no result.
                                  Thanks a lot
                                  Regards
                                    remus
                                    Regis, youll need to download the wole subdiide and smooth plugin from smustard. Te subdiide selection is part of this plugin.
                                      REGIS
                                      Thanks remus
                                      I understand : Whaat is Dale Marten.
                                      I know this plugin and perhaps it's the best plugin with FFD i've never seen before.
                                      Unfortunately I've no cash to buy it at the moment.
                                      Perhaps Cphillips can make a subdivide plugin if he wants.
                                      Regards
                                        remus
                                        There is a subdivide aspect to the current version of FFD, although it differs from whaats subd, it probably doesn't make much/any difference when your using it for FFD stuff, though.
                                          REGIS
                                          Yes remus, I had made a try but the result isn't what I want to have, see the skp file attached some post before.
                                          I don't know the result of whaat's subdivide plugin.
                                            remus
                                            Heres what i got after putting a similar shape through whaats subd:
                                            http://farm4.static.flickr.com/3232/2481919278_dee1dbabc3_o.jpg
                                            not very good either really, i did get better results on more regular shapes, though.
                                            • 20
                                            • 21
                                            • 7 / 21
