    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 474.3k Views 153 Watching
      CPhillips
      Here is a quick attempt at locked edges. Its clumsy but seems to work.
      How:
      -Create a FFD as usual.
      -Open the FFD group and select the edges you want to lock. If you select a face it will lock all edges.
      -Right click FFD->Lock edges. FFD->Unlock edges speaks for itself.
      Now locked edges shouldn't move when you FFD.
      Get the latest version from the PluginStore...
        kwistenbiebel
        @cphillips said:
        I am not sure about the the other problem. The kink in the chair looks strange but not unexpected given the FFD groups you used. The FFD only moves entities inside the group.
        How would you have liked it to work?
        Just like it works now 😄
        The ability to lock edges combined with a good triangulation before applying FF will solve it.
        I will remake that chair once S+D is out, so we can have a clean triangulated mesh before applying FF.
        Great work on that 'lock edges' option. Very useful upgrade chris 👍 .
          dolphus
          i downloaded and installed FFD but when i go to use it it does not ask if i want 2d or 3d if i continue it generated a flat matrix which i cannot do anything with what am i doing wrong?
            remus
            Did you group your geometry, right click and navigate thorugh the ffd menu to the bit where it has the option to change mesh size?
              GreenToaster
              For others who may be new to this
              1 - put the script in the following directory/folder (or find the equivalent):
              C:\Program Files\Google\Google SketchUp 6\Plugins
              2 - create some geometry
              3 - create a group from the geometry
              4 - select the group, right click, FFD, select a suitable option
              I've also found to it necessary to create a new FFD "box of control points":
              A - delete the existing "box of control points"
              B - explode the group
              C - create the group again - this is ultra-quick & easy b/c the entities in the group will remain selected when you explode the group - leave them selected so creating the group again is a simple & quick shortcut
              D - do step 4 (above)
              Hope this helps - love that script.
              If you really want something you won't ever stop pursuing it.
                dolphus
                Thanx Rremus it is working now 😍
                  dolphus
                  thanx gren Toaster i will start workijng with it and let you know how i progress 👍
                  • FletchF Offline
                    Fletch
                    Thanks for the update with locking edges, Chris! A thousand blessings upon you for your work and generosity to this community!
                    Fletch
                      remus
                      Hey chris, would it be possible to incorporate a subdivision element in to FFD? i reckon itd be really useful to be able to subdivide geometry before using FD, as you often dont get good results otherwise.
                      No pressure though, im sure i cna manage using whaats subd for the moment 😛
                        remus
                        Wow, this is liek on demand ruby! cheers chris, im sure this will be even more useful than it was before!
                          Daniel S
                          Thank you Chris!!! 😄 😄 It´s fantastic!!!
                          A bug... the 2x2 FFD or 3x3FFD is not working:
                          Error: #<ArgumentError: wrong number of arguments(2 for 3)>
                          C:/Archivos de programa/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13:in startFFD' C:/Archivos de programa/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13 C:/Archivos de programa/Google/Google SketchUp 6/Plugins/SketchyFFD.rb:13:in call'
                          Daniel S
                            CPhillips
                            Daniel S
                            Ooops. Fixed now.
                              CPhillips
                              Alright. Now when you do a NxN there is an option to subdivide.
                              See first post for download link.
                                kwistenbiebel
                                Chris,
                                You're Da Man! 😎
                                Kudos! 👍
                                  CPhillips
                                  Updated with another bug fix.
                                    Daniel S
                                    The new added option to subdivide the mesh when doing a NxN deformation it´s amazing! 😍 😍
                                    Only this feature can be a standalone plugin by itself 😍
                                    Thank you,
                                    Daniel S
                                    • CadFatherC Offline
                                      CadFather
                                      THIS IS INSANE! 😍
                                        REGIS
                                        Thanks Cphilllips.
                                        Your pluggin is excellent.
                                        I agree with Daniel S for a standalone plufin who can do that subdivide plugin request
                                        subdivid plugin request
                                        I would like to have the option to subdivide a loop in sketchup, really it'll be very cool.
                                        Thanks a lot for your hardwork
                                        • JClementsJ Offline
                                          JClements
                                          Interesting results by subdividing the top surface of the cylinder first before apply FFD. I was surprised that a convcave cone was not formed; however, the "symetrical wavey pattern" is nice. I'm not sure why the one surface/facet of the cyliner got flipped.
                                          ********* One minor enhancement might be to the name the FFD point group automatically, for instance "FFD Point Group". This could help in selecting the FFD group via the Outliner.
                                          Thanks for the great work Chris. You script has evolved nicely.
                                          Regards, John
                                            REGIS
                                            Hi Jclements
                                            The question : Where can I find the Dale Martin's plugin "subivide selection" ❓
                                            I've made a google search and no result.
                                            Thanks a lot
                                            Regards
                                            • 20
                                            • 21
                                            • 6 / 21
