    Displaying SketchUp 3D models on a website
    23 Posts 13 Posters 6.8k Views 13 Watching
    • P
      Pagan
      Here's my attempt...a bunch of photo in flash file.
      http://dhost.info/pagan/voyager.html
        smileychirk
        I looked into displaying a SketchUp model on a website, but got completely lost in the world of codecs, plugins and file wrappers.
        I would follow nizamuddin approach and go for the simple solution without any additional plugins or user intervention. Ease of use is key.
        Anything that takes more than 5 seconds to display will annoy a user and they will give up. So I abandoned the 3D interactive route and went for an animated video.
        One of the simplest user interfaces is YouTube.
        I exported a SketchUp model animation and uploaded it to Youtube.
        Moving a reasonably sized model around in real time via a website is likely to be cumbersome.
        But. I was disappointed.
        The quality has dropped significantly, to an unacceptable degree.
        There is a trade off, the file I uploaded was 96.5 MB, YouTube processed this file to 824 KB ( !!! ) for display. So for instant display there is a quality drop.
        I tried getting a higher playback quality but without success.
        Does anyone know a way to improve quality ?
        Or a site similar to YouTube that does not drop the quality so much ?
        Gaieus's input was comprehensive, as usual, I didn't know .pdf files could display 3d models, shame there is no Mac version.
        Regards
        Smiley.
        http://www.youtube.com/watch?v=ELApvRSVhI0
        http://www.youtube.com/watch?v=JF3EdwJR1TY
        This would be the minimum quality I would like.
        http://www.coleg.me.uk/pics/dunster_movie_3.avi
        • GaieusG
          Hi Smiley,
          Yes, YouTube reduces file size as well as converts the video into flash. The only solution is to create your video in flash already, with the same resolution as YouTube uses and carefully plan what compression you will use. This time YouTube "might" not resize your video and it may maintain its original quality.
          Another solution is Google Video (you can even "combine" your YouTube account with Google Video account as I understand that Google has acquired YouTube or something). As I noticed, the compression in quality is not as bad as in YouTube - but I have surely not experimented too much with it to say something certain.
          • Al HartA
            Al Hart
            Here is a sample page with an embedded 3D PDF.
            You just drag the mouse across the embedded image to watch it spin.
            http://www.renderplus.com/pdf/pdf_sample.htm
            Al Hart
            IRender nXt from Render Plus
            • TaffGochT
              TaffGoch
              Alan, I like your SWF idea, but I'm not keen to spend the amount of money being asked for Dreamweaver and other SWF editors I've found through web searches.
              Can anyone suggest an alternative that they've actually used, and found to be capable and reliable.
              I'm currently stuck with the old standby - animated GIFs.
              Taff
              "Information is not knowledge." -- Albert Einstein
              • T
                todd burch
                Rumor has it that this works.
                To any youtube link, append &fmt=18 to get a higher quality version. I haven't tried it. I read it on another forum.
                Todd
                • E
                  ever
                  I did try this Renderplus 3D pdf. It's working, but doesn't recognise sections - so for most of my work, I cannot use it.
                  Isn't there something better?
                    remus
                    Todd, just gave that trick a go and i couldnt see any noticeable difference, perhaps mi just blind 🤓
                    • P
                      Pagan
                      Here's another intresting way of viewing 3d model...
                      http://www.yofla.com/flash/3d-rotate/examples.php?exampleId=1
                        Jim
                        This uses a series of images to create the illusion of rotation.
                        We briefly discussed using this method, along with a free javascript program to animate 3d models in a web page as an educational community ruby project We could revive the project if anyone is interested.
                        404 Not Found
                        (www.sketchucation.com)
                        • Alan FraserA
                          Alan Fraser
                          Just doing what Coen suggests and trying out the posting of the Space Marine swf directly.
                          I see it just attaches; I guess I was half expecting embedding, but that might be a bit dangerous as some people might post ones of several MB which would slow page-loading down enormously and have fairly hefty impact on bandwidth.
                          spacemarine.swf
                          3D Figures
                          • GaieusG
                            Yeah, but this way a lot of people cannot see the file because they don't have a standalone flash viewer. I have one at home but haven't got it here in the office for instance.
                            • Alan FraserA
                              Alan Fraser
                              You should be able to associate it with your browser. I associated swf files with IE...even though I use Firefox...so when I click on the link it just opens an IE window (use Properties/General/Opens with). You get all the usually nannyish warnings about opening up ActiveX controls; and it displays virtually fullscreen, but at least you can see it.
                              3D Figures
